Test_CR utilisateur HCFR : JVC DLA-RS3100 (NZ8), projecteur 4K laser, e-shiftX 8K
Caractéristiques officielles
8K. laser. HDR.
The New Ultimate
Significant progress has been made to our proprietary 8K/e-shift technology – which combines “e-shift” high-resolution display technology, that doubles the resolution by shifting a pixel by 0.5 pixels, and 0.69-inch native 4K D-ILA device. Shift direction has increased from the conventional two diagonal directions to four directions of up, down, left, and right, to enable display of 8K signal information in its entirety.
The result is an 8K resolution, enhancing the sense of three-dimensionality and immersion.
  • Newly developed 8K/e-shiftX technology reproduces 8K image quality
  • BLU-Escent Laser Light Source
  • High brightness of 3,000 lm provides vibrant and dynamic images
  • Native Contrast Ratio of 100,000:1 translates to a spectacular Dynamic Contrast Ratio of ∞ :1
  • 2x HDMI (48 Gbps, HDCP 2.3) inputs, supporting 8K60P and 4K120P input signals
  • HDR10+ contains the metadata of the producer’s intentions for each scene, and with such data, the projector is able to automatically reproduce images as the creator intended.
  • Frame Adapt HDR* dynamically tone maps any HDR10 content frame-by-frame or scene-by-scene and automatically performs adjustment to achieve optimal images close to reality as seen by human eyes. As a part the Frame Adapt HDR, the projector offers improved gamma processing accuracy from 12- to 18-bit equivalent to reproduce smoother and finer gradation
  • Le projecteur passe automatiquement en mode d’image HDR lorsque des signaux HDR10 sont reçus.
  • Auto Tone Mapping function automatically adjusts settings for optimum HDR10 image quality
  • Compatible avec HLG (Hybrid Log-Gamma) qui devrait être largement utilisé dans les futures diffusions
  • Nouvelles matrices D-ILA 4K natives 0.69” (4096 x 2160) x3
  • Lentille haute résolution intégralement en verre avec 18-éléments et 16 groupes dans un barillet en aluminium
  • Nine settings of Installation Mode include Lens Control, Pixel Adjustment, Mask, Anamorphic on or off, Screen Adjust, Installation Style, Keystone, Pincushion, and Aspect; stored installation modes for various environments can be called up.
  • Large gamme de couleurs supérieure au DCI P3 permettant d’avoir des images vives et colorées
  • Low Latency Mode suppresses display delay for faster response when receiving signals from PC and game co
Caractéristiques techniques
Nouvelle matrice D-ILA 0.69″ 4K native (4096 x 2160 pixels) x 3
Résolution : 8192 x 4320 pixels
Technologie 8K e-shiftX pour une image projetée en résolution UHD 8K (8192 x 4230 pixels)
Fonction de décalage de l’axe optique : +/-80% vertical & +/-34% horizontal, motorisé (données indiquées en mode 16:9)
Lentille : Lentille intégralement en verre de 65 mm de diamètre avec 17 éléments en 15 groupes
Zoom : Zoom motorisé 2x avec mise au point motorisée
Luminosité : 2500 lm
Rapport de contraste :
– Natif : 80 000:1
– Dynamique : infini
Format vidéo compatibles :
– 480p, 576p, 720p 60/50, 1080i 60/50
– 1080p 120/100/60/50/30/25/24
– 3840 x 2160p 120/100/60/50/30/25/24
– 4096 x 2160p 120/100/60/50/30/25/24
– 7680 x 4320p 60/50/30/25/24
Signal d’entrée PC (HDMI) : VGA, SVGA, XGA, WXGA, WXGA+, SXGA, WSXGA+, UXGA, WUXGA, WQHD(60), WQHD(120)
Fonctions avancées
Deux entrées HDMI 8K 48 Gbit/s avec HDCP 2.3
Nouvelle technologie 8K/e-shiftX 240 Hz
Couverture à 100% de l’espace colorimétrique DCI-P3
HDR10, HDR10+, HLG
Frame Adapt HDR : mappage tonal dynamique (soit image par image, soit scène par scène)
Theater Optimizer : mappage tonal optimal en fonction de l’environnement d’installation. Le traitement gamma de niveau 18 bits supprime les gradations tonales dans les zones claires et les noirs dans les zones sombres, et reproduit les gradations lisses avec une grande précision.
Optique à très haut contraste
Clear Motion Drive : compensation de mouvement
Motion Enhance : optimisation de l’entraînement de la matrice D-ILA en fonction du mouvement de l’image
Certification ISF
Jusqu’à 10 types de configurations d’installation mémorisables : mémoire de position de l’objectif, réglage des pixels et des masques d’écran, gain et taille de l’écran, rapports hauteur/largeur
Auto-étalonnage : optimisation des caractéristiques optiques qui varient en fonction des conditions d’installation et d’utilisation
Mode d’optimisation en fonction des caractéristiques de la toile d’écran : corrige le déséquilibre des couleurs dû aux caractéristiques de l’écran
Entrée d’air à l’arrière et sortie d’air à l’avant facilitant l’installation près d’un mur
Lampe
Laser BLU-Escent
Durée de vie de la lampe : Environ 20000 heures en mode basse consommation
Contrôle dynamique de la source lumineuse
Bruit de fonctionnement
24 dB (mode lampe faible)
Connectique
Entrées vidéo (panneau arrière) :
– HDMI : 2 (48 Gbit/s, HDCP2.3, pas de prise en charge CEC)
Connecteurs de sortie (arrière) :
– Sync. 3D : 1 (mini DIN à 3 broches)
– Déclencheur : 1 (mini jack, CC 12 V/100 mA)
Connecteurs de contrôle :
– RS232C : 1 (Sub-D 9 broches)
– LAN : 1 (RJ-45)
Connecteur de service :
– USB Type A : 1 (pour mise à jour du firmware uniquement)
3D
Format 3D :
Frame Packing : 720p 60/50, 1080p 24
Side-by-Side (horizontal) : 720p 60/50, 1080p 60/50/24, 1080i 60/50
Top-and-Bottom (vertical) : 720p 60/50, 1080p/24
Données énergétiques
Alimentation : tension secteur AC100V-240V, 50/60Hz
Consommation :
– Projecteur en fonction : 440 W
– Mode veille réseau : 1,21W (LAN), 0,94W (RS-232C), 1,22W (LAN + RS232C)
– Mode éco : 0,3 W
Données logistiques
Dimensions (L x H x P) : 500 x 234 x 505 mm
Poids : 23,1 kg
Prix public : 15 000  euros
– lien vers le sujet HCFR dédié au projecteur JVC DLA-RS3100 (NZ8) : https://www.homecinema-fr.com/forum/projecteurs-uhd-4k/2021-jvc-dla-nz7-nz8-rs2100-rs3100-voir-post-1-t30116417.html
Partager :
