Danico a écrit:Ce logiciel permet de créer un fichier HD sur un DVD. Mais ça reste un DVD. Cela n'a strictement rien à voir avec le HD-DVD.
Un extrait de "Late-Breaking News - About DVD Studio Pro 4.1" que tu peux "google" sur le Net.
DVD Studio Pro 4.1 Complies With the HD DVD-Video Specification
HD DVD projects authored with DVD Studio Pro 4.0.3 and DVD Studio Pro 4.1 fully
comply with the 1.0 version of the HD DVD-Video specification, which defines the new
HD DVD standard. DVD Studio Pro versions 4.0, 4.0.1, and 4.0.2 complied with the
0.9 version of the HD DVD-Video specification, which was the most current available at
that time.
The 1.0 version of the HD DVD-Video specification includes some changes that will
affect how you create HD projects in DVD Studio Pro.
Important:
HD discs created with DVD Studio Pro versions 4.0, 4.0.1, and 4.0.2 are not
compatible with any DVD players that conform to version 1.0 of the HD DVD-Video
specification.
Note:
You can open the older projects in DVD Studio Pro 4.1 and use its Build and
Format features to create discs that are compatible with DVD players that conform to
version 1.0 of the HD DVD-Video specification. Build files (in HVDVD_TS folders) created
with DVD Studio Pro versions 4.0, 4.0.1, and 4.0.2 cannot be formatted directly—you
must create them again using the Build function.
