non le tampon ne se remplit pas à fond la moitié environ
pour les décodages bah je sais pas trop
![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
Modérateurs: Modération Forum Oeuvres & Multimédia, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
Will current-generation consoles support UHD Blu-ray?
The question of console support is going to be important to UHD Blu-ray’s long-term uptake. But right now the picture is murky: Neither Sony or Microsoft have publicly stated that their respective consoles would support the new standard. Based on what we know about the hardware, however, I’d say they probably won’t — at least, not with the PS4’s and Xbox One’s you can buy today.
The hardware itself isn’t really the problem. Even the Xbox 360 and PS3 could likely handle H.265 decoding with proper software optimization, and the eight-core Jaguar CPUs in both modern consoles are robust enough to do the job. The problem is the discs themselves. The multi-layer discs that UHD relies on likely aren’t compatible with the Blu-ray players in either machine.
Assuming that’s true, it’s the kind of feature both companies could add when they inevitably overhaul their platforms for a new process node and lower power consumption. It might even be possible to add H.265 decode support to the GPU hardware with AMD’s help. Neither company has announced plans to roll out a new console variant as yet, but we’d be surprised if there weren’t second-generation Xbox One’s and PlayStations on store shelves by Christmas, 2016. Conventional player hardware should be available at retail within the next few months, given that Panasonic already demonstrated its prototype player at CES 2015.
PS3 on - Green light - Yellow light - 3 Beeps - Flashing Red Light = YLOD.
PS3 on - Ps3 Shuts Down/3 Beeps - Flashing Red Light = Internally Overheating.
PS3 Off, then switched on - 3 Beeps - Flashing Red Light = Component
Failure/Overheating*/Harddrive Failure.
PS3 on Standby, Red Light, sensor/button pressed, brief Green Light, no lights, Red Light - Internal Component Failure(Similar to YLOD).
PS3 stuck on standby/Alternate Flashing Red/Green lights - Component Failure/Overheating*.
*=obviously not overheating from cold.
Also, the Error Codes are explained here: http://us.playstation.com/support/answe ... m?a_id=939
Enter a Code, and the description should give some idea of the problem.
Retourner vers Univers Playstation
