Jean-Pierre Lafont a écrit:Je ne vous oublie pas, mais je dois m'occuper des études payantes en priorité, le forum venant après. Sitôt l'étude en cours terminée je m'y attèle.
N.B. On ne peut pas mesurer le niveau du LFE avec un sonomètre.
Bien sûr.
Juste pour détailler un peu plus ma question, voici les indications fournies avec le disque de calibrage :
Levels
Pink noise is playing from a single speaker to allow you to check correct speaker hookup and to calibrate volume level. To change speaker, use the left and right arrows on your Blu-ray player remote. For volume calibration, use an SPL meter set to C weighting, slow. Point the meter directly upwards, at head height where you normally sit.
If your receiver main volume has a reference (0 dB) mark, set it to that mark. Then use the individual speaker volume controls on the receiver to adjust each speaker to 75 dB on the SPL meter.
If your receiver has no reference mark, use the main volume control to adjust the center speaker to 75 dB. Then use the individual speaker volume controls to make all the other speakers measure 75 dB.
![Image](https://spearsandmunsil.com/wp-content/uploads/2013/03/screenshot001-e1365740170564.png)
