Alors ni une ni deux on écoute le petit ils avaient pas le gros. Et bien ce petit sonne remarquablement bien. Alors voilà je vous mets ces caracteristiques et puis je vous mets aussi celle du gros. Avis aux amateurs s'il y en a qui connaissent.
BLUE SPARK VBS2X Receiver:
Features:
Amplifier:
- 2 Optical inputs
- 2 Coaxial input
- S-video switching 2 in 1 out
- Composite 3 in 1 out
- 5.1 analogue inputs for DVD Audio and SACD
- Auto input sensing
- Composit to S video conversion
- Overload protection
- Active cooling
- Gold plated RCA’s
Processor:
- DTS
- Dolby Digital
- Analogue bass manager
- 5 channel stereo mode
Tuner:
- RDS
- 20 FM/AM Presets
Other:
- Auto power on and stand-by
- Detachable power cord
Specifications:
Output power:
- One channel
- Front: 90W @ 8 ohm /0,1% THD
- Center: 90W @ 8 ohm /0,1% THD
- Surround: 90W @ 8 ohm /0,1% THD
- Two channels driven
- Front L+R: 100W @ 6 ohm / 0,7% THD
- Five channels driven
- All: 60W @ 6 ohm / 0,7% THD
- Distortion: 0,04 % @ 1 kHz / 90 W
- Frequency response (analog input): 18 Hz to 45 kHz +1 -3 dB
- Input sensitivity (analog input): 250 mV
- S/N Ratio (digital input): 88 dB w. A-weighted filter
- FM tuner: 87 MHz – 108 MHz
- Tuner S/N (stereo): 55 dB
- Power supply: 115V or 230V switchable
- Power consumption: 380W max
- Dimensions (W x D x H): 435 x 418 x 150 mm
- Weight: 11.5 Kg
Et maintenant voici pour le grand frere
REFERENCE VR8X Receiver:
Features:
Amplifier:
- 4 Optical inputs
- 3 Coaxial inputs
- Component video switching 3 in 1 out
- S-video switching 3 in 1 out
- 6.1 analogue inputs for DVD Audio and SACD
- Active cooling
- Gold plated RCA’s
Processor:
- DTS, DTS-ES
- Dolby Digital, Dolby Digital EX
- Direct mode
- 5 and 6 channel stereo mode
Tuner:
- RDS
- 20 FM Presets
Other:
- Auto stand-by
- OSD
Specifications:
Output power:
- One channel
- Front: 140W @ 8 ohm / 0.1% THD
- Center: 140W @ 8 ohm / 0,1% THD
- Surround: 140W @ 8 ohm / 0,1% THD
- Front L + R: 140 W @ 6 ohm / 0.7% THD
- Six channels driven
- All: 100 W @ 6 ohm / 0.7% THD
- Distortion: 0.06 % @ 1 kHz / 90 W
- Frequency response (analogue input): 18 Hz to 80 kHz +1 -3 dB
- Input sensitivity (analogue input): 300 mV
- S/N Ratio (digital input): 92 dB w. A-weighted filter
- Tuner S/N (Stereo): 55 dB
- Power supply: 115 V or 230 V switch able
- Power consumption: 650 W max
- Dimensions (W x D x H): 432 x 452 x 160 mm
- Weight: 20.5 Kg
Je vous mettrai bien des photos mais je n'en ai pas trouvé.
Enfin le petit lien http://www.vifa.dk
Voilà a vos claviers
