![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: choufleuri et 22 invités
azertyui123 a écrit:Dans quelle boutique sera t'il en vente en priorité ?...pour ma part je parle de vitrine sur le net
azertyui123 a écrit:j'ai quand meme une question a poser a jacko...es que le edje sera capable de donner satisfaction a une clientele qui utilise la projection?
02fx4dude a écrit:
IMO, <drum roll.......................>
It's OK.
I would say it looks about as good as my XA2 for DVD upconversion, but others have different opinions. We're hoping scaling can be improved in software, but it doesn't blow the XA2 upscaling out of the water, as some suggested.
It makes a nice AV Hub, lots of inputs, seperate HDMI outputs for audio and video is pretty handy. There are discreet codes, but good luck getting them into your Harmony remote. Also, it curently has issues with HTPC video cards which is my main problem at this point.
Some of the others will be able to write volumes on their thoughts.
Brian
aaronwt a écrit:I have replaced my VP50pro with the EDGE in my main setup. I see similar results between the two. Except the EDGE has no problems bitstreaming the advanced codecs with my Denon 3808..
I'm using 12 components with HDMI going through the EDGE using a combination of switches and splitters and have no problems.
I am very pleased with the performance of my EDGE.
For me it works as well as my VP50pro and has all the features I need while the VP50pro was overkill for my setup.
I only use 1080P60 and 1080P24 output.
Having video from my components go straight to my Toshiba set or Samsung sets looks like crap compared to having the EDGE/VP50pro in the video chain.
Although the EDGE does have a more modern interface and a much easier firmware upgrade method using USB.
Bottom line is for the money you get a very good scaler/video processor. The VP50pro retails for $3499 while the EDGE retails for $799. The VP50pro would be typically for a different crowd.
Although I think you get alot of value for the money with the EDGE.
rh83733 a écrit:My general feelings of the EDGE are it does an ok job for me, but only ok, certainly nothing WOW from my experience.
Scaling could be a lot lot better, the deinterlacing seems good.
I tend to not use Edge Enhancement/Detail Enhancement, I find it very hard to establish exactly what is a good value to use for these, and they dont make much difference until they introduce artifacts which you probably wont want. Mosquito (LOW) is quite useful on Satellite broadcasts for me.
The Brightness/Color/Contrast/Tint settings arent that useful, the changes they make occur in way too large steps to be that good for getting a specific setup for each of my video inputs.
1080p24 output from film material is quite stuttery for me (unless the source itself is 1080p24 of course) I tend to not get EDGE to make 1080p24 unless the source is recorded at it.
I wish it was possible to define the colour space you want EDGE to output, but this isnt possible on my oneIts always RGB.
Game mode works nicely, although it would be great to be able to switch it on and off with one press of the remote.
My EDGE works nicely as an AV Hub although I consistently have a problem with it dropping DVD audio when Im using the coaxial digital input, optical digital outThe auto input priority is useful.
Overall my feelings on the EDGE right now are its pretty average. I dont plug it in and see an amazing change at all.
Audiophile20 a écrit:So based on your experience, would you say if one has a LCD that has decent Faroudja processor built-in, does it make sense to get EDGE as an outboard processor? I have pre-ordered as well. Wondering if it is worth adding another component into my A/V mix.
rh83733 a écrit:Difficult to answer.
Do you need an AV Hub? Do you need to do a lot of scaling?
Based on my experience with EDGE at the moment, Id wait and see how the product develops with software updates.
VPete a écrit:Hi everyone!
I was one of the beta testers and the process was a blast! It had both its share of frustrating and joyous moments.
I was really most interested in it's ability to vertical stretch source material for use in CIH systems... particularly at 1080p24hz. (Yes, it works great, by the way.) If you're interested in that aspect of the edge, feel free to visit the CIH forum where I'll post a review.
-Pete
Richard Lemesle a écrit:
Quelques retours sont déjà disponibles sur avs.
Richard.
Richard.
et qu'est ce qui en ressort (les grosses lignes) S.T.P (je ne sais pas lire l'anglais) ?
je pense donc que les premiers "bébés" vont arrivé cette semaine?
Patrice
Retourner vers Processeurs Vidéo
