Avez-vous de l'expérience avec ce câble HP vendu par Audiophonics entre autres?
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Hoian, nevik et 27 invités
https://www.physis-research.com/
Physis story goes way back.
In 1980, a researcher at the Dutch Laboratory of the Dutch Broadcasting Corporation (NOB) began his development with experimental research in search of improved sound quality, One of the tasks was to find out if the electrical components affect the quality of the sound produced. Initially, the attention of the researcher was focused only on audio signals, after that, the field of study expanded to include optical signals.
That was on both empirical and subjective performance. In other words, we wanted to find out what makes cables sound the way that they do. Long research led to the possibility of creating a specific product based on carbon, after a series of painstaking experiments, the researchers of Physis found the right modification and all errors were taken into account and corrected.
The effect of the developed product is unparalleled and can delight people who are versed in the audio field. Ludic uses pure copper as the main conductor, but the carbon furthermore has a structural effect on music which is not available with any other cables. With Silenos especially the lowest signal levels are maintained where they are all lost with only pure metal conductors, so also here lies the secret of this exceptional cable, what Physis is doing here we cannot explain in detail, that is the magic trick.
So what’s so special about our Silenos?
Lots of things, read also the 11 points. but I don’t care about your 11 points, I care what it sounds like!
Yes, and some people care about something to read and we like that also..
but still, please read the 11 points!
1. An unusually deep sound comparable to the real presence, not the audio version of the performance.
2. The sound source with its accompanying effects does not change its position, both when playing through the speakers and in headphones.
3. The center of the delivered sound, using this innovation, no longer depends on the position of the listener or on the position of the speakers, which was a big problem before.
4. The presence of a third person between the sound source and the listener no longer interferes and does not change either the quality or the presentation of the sound.
5. The sound is delivered equally loudly throughout the space in which it is played.
6. Loudspeakers are no longer sound sources.
7. Low notes are reproduced with natural lightness and extraordinary fullness, even with relatively small speakers. High notes are reproduced with a clarity and lack of harshness that distracts the listener on many modern recordings. In addition, analog tape recording loses a certain degree of sharpness. This mainly concerns the reproduction quality of stringed instruments.
8. The influence of “treble” and “slope” filters on sound, even if they are clearly measurable, is greatly reduced in the perception of the listener.
9. The measured signal ratio of the noise signal in the circuit before and after the modification remains identical, but, nevertheless, when listening to the modified circuit, the noise appears softer and less obvious.
10. When listening through headphones, sounds are perceived not only from left to right, as in conventional systems, but also from the front and back, and from above and below. In addition, the source of the sound is no longer felt as inside the head, but as if it occurs outside of it, around.
11. When listening to this system, some are faced with the impression that they themselves are part of the sound, while others take part in it. For many, this feeling of “presence” was shocking, and moreover, it was impossible to get rid of this experience, during subsequent auditions, without this development, the sound was no longer satisfying. Some were left with the impression of participating in two realities, on the one hand, sitting in a room, listening to a composition with a pair of speakers, on the other hand, being present at a musical performance. Illusion has a unique sense of reality, an unrealistic event under existing conditions.
Source: Van der Heide, H.J., Perception and experience of sound: natural or electro-acoustic? Prana 113, June/July 1999, p 75 & 76.
Wow, you guys are being pretty serious. What happened?
You gotta be kidding!
No, seriously, I don’t believe this, Wait a second, my head just exploded.
We at Ludic know how you feel.
Ludic provides fun, affordable audio products. We’re not interested in “race to the top” price wars, we want to bring products to the market that are accessible to everyone…Nor are we worried about some who might think our products are less capable just because they’re less expensive.
Maybe it would be better to ask the other companies how they can charge so much for their products?
But It looks and sounds great, and offcourse, we’re biased.
Try it for yourself, we don’t have to convince you, you have to do it for yourself!
Specifications:
CROSS-SECTIONAL AREA
2.5 mm2 (without Physis carbon layer shield and jacket)
WIRE GAUGE
10 AWG (999.997% pure copper)
LOOP RESISTANCE
13.4 mΩ/m
CAPACITANCE
75.0 pF/m
LOOP INDUCTANCE
0.52 μH/m
DISSIPATION FACTOR
@ 10 kHz 0.0001
MAXIMUM CURRENT
38A INSULATION 300V
JACKET
FLEXIBLE NEOPRENE
Specifications:
WIRE GAUGE
LOOP RESISTANCE
13.4 mΩ/m
CAPACITANCE
75.0 pF/m
LOOP INDUCTANCE
0.52 μH/m
DISSIPATION FACTOR
@ 10 kHz 0.0001
MAXIMUM CURRENT
38A INSULATION 300V
JACKET
FLEXIBLE NEOPRENE
- stephane092
- Inscription Forum: 31 Mai 2012 7:36
Merci, et une expérience avec ces câbles?
- maillotp
- Inscription Forum: 16 Avr 2007 9:36
Pour du pipeau, c'est du pipeau !
- MickeyCam
4 messages
