Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Alkinos, barney gumble, Bavuong, BiancoXCV, biosphere44, boston, BRASIL, Clyde Blaireau, coucouse, cubitusmetz, danywilde36, dedelynks, djinn77, DLeguille, gilmour, Greg675, HenzoMU, Irikte, JMINCONNU, julienctr, kapo60, kawaced, Kenshiro49, Manson79, michael63, nicowboy, octodurus, ozonestrike777, passager57, philboun, pkoka, pops91, shiryu73, Supernaz, syster, trekSL8, will76, wuger91, xjr1300 et 356 invités
2023 - Samsung S95C & S90C QD-OLED 4K en 55/65/77”
» 26 Mai 2024 13:39
C’est bien expliqué dans le (très) long article que tu as partagé (merci !), et qu’à j’avais commencé à lire il y a quelque temps (et toujours pas fini) :
A simple example would be that a display that reaches 1000 nits peak white luminance would not look twice as bright to a viewer as a display that measures 500 nits white luminance. Our visual system does not perceive it in the same way as these raw luminance measurements.
This is important as you will often see displays marketed based on their “peak brightness” spec, which is actually just the peak luminance of white as we discussed earlier. But statements like how the new 1300 nits WOLED panels are “30% brighter” than the previous generation of 1000 nits WOLED panels are only true from a raw luminance point of view. They will not look and feel 30% brighter in reality to the user.
https://tftcentral.co.uk/articles/exploring-oled-brightness-improvements-woled-vs-qd-oled-and-the-need-for-new-metrics-and-specs
![Avatar de l’utilisateur](./download/file.php?avatar=238105_1619728873.jpg)
hyperspace
![Membre HCFR Membre HCFR](./images/ranks/membre2.gif)
- Inscription Forum: 05 Mai 2018 22:40
» 26 Mai 2024 17:08
Rappel à l'ordre
Merci de vous conformer à la charte que vous avez validée en vous inscrivant sur HCFR et notamment l'article IV.B.13 concernant les prix.
Tous les prix affichés sur HCFR doivent comporter un lien ou une photo.
Teybb
- Inscription Forum: 12 Mai 2024 16:11
» 27 Mai 2024 14:38
Il me semble logique qu'en passant d'un ensemble Pana JZ1500 (ancienne gen de 2021) + Xbox Séries (comme lecteur bluray) à un Samsung QDoled 77S95C (haut de gamme de 2023) + un Panasonic ub 820 , le bond qualitatif en terme d'image pure sera forcément présent et prégnant.
qtip66
- Inscription Forum: 19 Aoû 2019 14:48
» 27 Mai 2024 14:39
Le S95C offre des performances techniques bien superieures au Pana JZ1500, que ce soit sur la retranscription du HDR grâce à la luminosité accrue du Samsung ( 880nits à 10% pour le Pana contre 1350nits à 10% pour le Samsung, et 300nits à 100% pour le Samy contre 150nits à 100% le Pana) , sur la couverture colorimétrique BT2020 (85% pour le S95C contre seulement 72% pour le Pana) sans parler du processeur vidéo du S95C mais aussi de la platine Panasonic UB820, qui est bien meilleur que celui de la Xbox. Donc en terme de traitement de l'image, ça va être le feu
Xbo comparé à mon actuel ensemble TV/lecteur Xbox.
qtip66
» 27 Mai 2024 15:37
J'ai rarement vu des specs et mesures se traduire dans les mêmes proportions à l'oeil nu sur du contenu du quotidien
Depuis quelques années je trouve que le critère n°1 d'effet spectaculaire dans l'upgrade d'une TV haut de gamme c'est l'augmentation de la taille de l'écran, tout autre critère arrive très loin derrière (sauf de passer d'une TV "bas de gamme" à du haut de gamme)
Une autre façon de voir les choses :
Si on me donnait le choix entre un 77JZ1500 et un 65S95C (ou même un S95D 2024 ou même son successeur en 2025), je choisirais sans aucune hésitation le 77 pouces
passager57
- Inscription Forum: 05 Avr 2016 12:39
» 27 Mai 2024 15:42
Je partage assez ton avis.
Certes, les téléviseurs ont encore progressé, mais je trouve que le pallier significatif a été franchi avec l'OLED puis avec les OLED à forte luminosité (le Pana GZ2000 a ouvert la marche).
![Avatar de l’utilisateur](./download/file.php?avatar=20488_1712148765.jpg)
Fafa
- Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV
![Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV](./images/ranks/membre2.gif)
» 27 Mai 2024 15:59
qtip66 a écrit:Il me semble logique qu'en passant d'un ensemble Pana JZ1500 (ancienne gen de 2021) + Xbox Séries (comme lecteur bluray) à un Samsung QDoled 77S95C (haut de gamme de 2023) + un Panasonic ub 820 , le bond qualitatif en terme d'image pure sera forcément présent et prégnant.
Certes, mais le saut ne sera pas si important qu'imaginé ... Le changement de taille apportera clairement le plus.
Après entre une surface de 100% sur à 65" à 150 nits et 300 nits sur 77". La surface en m² va clairement donner un plus en sensation lumineuse ... Mais pour une même diagonale se serait moins impressionnant
![;)](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
Esscobar
- Inscription Forum: 27 Sep 2016 18:10
» 27 Mai 2024 16:00
qtip66 a écrit: mais aussi de la platine Panasonic UB820, qui est bien meilleur que celui de la Xbox. Donc en terme de traitement de l'image, ça va être le feu
Sans preuve concrète, aucune certitude
![:grad: :grad:](https://www.homecinema-fr.com/forum/images/smilies/graduation.gif)
Esscobar
» 27 Mai 2024 16:01
passager57 a écrit:J'ai rarement vu des specs et mesures se traduire dans les mêmes proportions à l'oeil nu sur du contenu du quotidien
Et c'est logique, à moins d'avoir un œil vraiment averti et les écrans côte à côte pour comparer
Esscobar
» 27 Mai 2024 16:04
Esscobar a écrit:qtip66 a écrit: mais aussi de la platine Panasonic UB820, qui est bien meilleur que celui de la Xbox. Donc en terme de traitement de l'image, ça va être le feu
j' ai les 2 platines, et je te confirme que sur une grande base. la différence se voit.
![:bravo: :bravo:](https://www.homecinema-fr.com/forum/images/smilies/thumbs_up.gif)
![Avatar de l’utilisateur](./download/file.php?avatar=90393_1709276178.jpg)
SEGA team
- Contributeur HCFR & Modérateur Univers TV
![Contributeur HCFR & Modérateur Univers TV Contributeur HCFR & Modérateur Univers TV](./images/ranks/membre_contributeur.gif)
- Inscription Forum: 14 Oct 2007 12:01
» 27 Mai 2024 16:18
Ce qui n'a rien de très important.
Le matos est acheté, Qtip nous fera certainement un CR et il sera bien à même de juger l'apport qu'il constate.
Fafa
» 27 Mai 2024 16:19
SEGA team a écrit:Esscobar a écrit:Sans preuve concrète, aucune certitude
Même sur ma 65".
Et niveau audio HDMI il y a des différences.
Fafa
» 27 Mai 2024 18:08
Certains ont leur 77 pouces s95 ou s90 sur un meubles ? Si oui quel meuble tv avez vous ?
J’etais partis pour la mettre au mur mais comme j’ai la changinite aigu je vais la laisser sur un meuble pour le moment et le mien est un peu trop petit à mon goût , il fait 150cm ( esthétiquement c’est pas terrible car la tv dépasse
Samsung 77S95C ,yamaha cx-A5100+parasound 5250v2, oppo 203 eu, shield pro , Apple TV 4K ,sonance Thx ,caisson dy peerless 4*10’ ,jvc NZ7 ,2nas synology1010+,accuphase E600 , Dac 3 D lab, davis sisley hd tweaké
alcine
- Inscription Forum: 19 Jan 2006 13:08
» 27 Mai 2024 18:35
Super merci de confirmer ce qui me semble de tu te façon etre une évidence car comment une console de jeu pourrait rivaliser, pour ce qui de la lecture de bluray films/séries, avec une platine dédiée de très bonne gamme comme la Panasonic UB820 (qui en terme de traitement d'image offre les mêmes performances que la platine la plus haut de gamme de la marque, la UB9000) .
Sans parler de tous les réglages d'image auxquels le Panasonic 820 nous donnes acces (là où sur la Xbox on n'a acces à aucun réglage d'image) et son processeur HCX Pro qui forcément permet d'offrir un traitement de l' image de bien meilleur qualité que la Xbox , donc logiquement la platine devrait faire mieux que la Xbox.
En tout cas forcément qu'en passant d'un White Oled ancienne génération Pana JZ1500 à un Oled new gen Samsung S95C, avec en plus une augmentation de 12pouces sur la taille de l'écran (soit 30cm de diag en + ) et cerise sur le gâteau, passer en plus d'une simple Xbox séries pour la lecture de BR à une vraie platine bluray dédiée Panasonic UB820 ('une des meilleures du marché) , la différence sera au moins convaincante voir carrément flagrante .
qtip66
