Bonjour à tous.
J'ai commandé en chine deux paires de pads hybrides d'upgrade Moondrop EP-100A (velours, cuir peau de mouton), vu le prix 10 fois moins cher que les pads de remplacement d'un Focal Utopia, par exemple.
J'attends de les recevoir, pour savoir si ils sont encore meilleurs que les pads stock hybrides du PARA, pour voir si j'ai fait un bon investissement.
https://shenzhenaudio.com/products/moon ... ack-earpad![Image](https://nsm09.casimages.com/img/2024/04/26//24042606415423553818395119.jpg)
Bon WE.
EDIT: pour info, sonorité du PARA avec les pads stock hybrides appelés dans cette revue "pads velours"
"5.1 Sound with velour earpads
With the velour earpads, the PARA deliver a lively and realistic sound with balance and airness for key properties.
Subbass is extended and perfectly smooth by ear without ‘narrow’ accents in any section. It’s really very dense and powerful, and at high volume, the earpads even vibrate noticeably. In this area of the frequency range, the PARA don’t add anything that isn’t in the track, but modestly and carefully reproduce the recording.
The bass is also speedy and pretty technical. No dirt, mumbling or detail omission: the lower frequencies are sterile (in a good sense).
The mid-frequency range goes on with the trend: it’s full of details, a bit ‘lightweight’, and a little brighter and ‘dry’ than I’m used to. Just in case: I’m only talking about the sound signature and personal preferences – not about that frankly clumsy tuning. The upper section of the mid-range is slightly emphasized, the area of about 8 kHz is highlighted (as in many models).
The ultra-high frequencies live their best life, so to speak. They are full-fledged and extend up to 20 kHz without any dips along the way. I can hear a curb at the 13 kHz, but this is exactly that part of the spectrum where different people can hear completely different things, so it’s extremely subjective here.
What’s the verdict? Formally, it’s a fantastically smooth (compared to the IEF curve) sound delivery, almost devoid of tuning flaws, and only slightly shifted towards the upper middle and increased airiness. You can define the sound as accurate, realistic, balanced, or sterile, dead, expressionless – it all depends on what you normally like or what you’re used to.
I’d personally say that this one is practically a neutral benchmark.
As for the sound stage, at such tuning, only one thing can be said about the instrument positioning, the width and depth of the stage, the recording quality retranslation: the PARA play it exactly how the track was recorded and mixed. The sound stage is only larger than usual because of the full range from 10 kHz and above.
The subjectively perceived amount of details is simply magnificent. On the other hand, the musical material should be perfectly mixed, because any tiny shit in the recording can be heard right away. If anyone bets you to distinguish mp3 from flac, choose PARA with standard earpads for this. "Source :
https://boizoff.com/language/en/moondro ... es-review/
