stephane092 a écrit:Le Mogami W3103 est un câble avec 4 conducteurs, le fabriquant Canare qui fabrique aussi des câbles avec 4 conducteurs, il donne sont avis technique sur ce type de câbles:
Speaker cable must accommodate relatively high signal levels, typically tens to hundreds of watts of RMS power. Electromagnetic interference (EMI) can radiate from these speaker lines directly into adjacent low voltage cables (i.e. microphone, video, lines, etc.). Canare solves this problem by using a 4-conductor “Star Quad” configuration in all of our 4S-series speaker cables. Because every conductor is located the same distance from center, the opposing magnetic fields are cancelled out. Attenuation of magnetic field radiation is superior when compared to a standard 2-conductor speaker wire.
https://www.canare.co.jp/en/products/ca ... ?tid=4_008
https://mogamicable.com/category/bulk/s ... iguration/
3103 est un 2 conducteurs. C’est le 3104 le 4 conducteur
Gil
