Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alex928gt, Chromatic, david555, dm, Driggs, hugo ver, Jake Sully, Jef_13, mazouzi3131, micka70, mlg33, Mr Dus, novine321, pgcs_atz, Richard Lemesle, Seb2908, Sonic69, topvince31, xavlgx et 68 invités
Viewsonic LX700-4K Laser DMD 0,65" / LS710-4KE / RGB
LX700-4K RGB/LX710-4KE
Site officiel : https://www.viewsonic.com/global/produc ... s/LX700-4K
- 3rd generation laser phosphor technology with up to a 30,000-hour lifespan
- Designed for Xbox with 1440p @ 120Hz for an unrivaled gaming experience
- True 4K HDR immersive visual experience with up to a 300" screen
- 3,500 ANSI Lumens offering bright images in any environment
- High native contrast ratio through 0.65" DMD chip
- Installation flexibility: V lens shift, 1.36x optical zoom, H/V keystone
Tarif indicatif :1199€
"ViewSonic LX700-4K | 4K HDR High Brightness Laser Home Projector | Designed for Xbox"
EDIT :
Le LX700-4K sera disponible en France sous la référence LS710-4KE
Lien du site officiel :
https://www.viewsonic.com/fr/products/p ... /LS710-4KE
Guide utilisateur (en français) :
https://www.viewsonicglobal.com/public/ ... N.pdf?pass
Tests (liens) :
"Test ViewSonic LX700-4K: Xbox-Gaming-Beamer"
https://www.prad.de/testberichte/test-v ... ng-beamer/
"ViewSonic LX700-4K 4K UHD Laser Gaming Projector Review"
https://www.projectorreviews.com/viewso ... or-review/
EDIT 2 :
LX700-4K RGB/LX710-4KE RGB (source lumineuse triple-laser RGB)
https://pcs.vsi.viewsonic.com/admin/product/view/1498
"Viewsonic launches LX700-4K projector with tri-color laser, 4K resolution, 240Hz refresh rate, ideal for Xbox gaming"
https://www.gizmochina.com/2024/05/13/v ... ecs-price/
EDIT :
Tests (liens) :
EDIT 2 :
Salle dédiée 7.1.4 3D 4K :Onkyo TX-RZ50, Emotiva BasX A3, SVS Prime Bookshelf + Center + Satellite + Elevation, Ultra Surround, SVS PB-2000 Pro, LG Oled CX, BenQ W4000i, Oray cadre, Panasonic UB820, PS5, Xbox Series X, Zidoo Z9X, Shield TV Pro,M9702 V3
evangelion77 - Membre HCFR Contributeur
- Inscription Forum: 19 Oct 2010 23:15
On va attendre les premiers tests mais il a l'air pas mal, ce petit 4K XPR avec sa puce 0,65", son lenshift vertical et son petit zoom optique.
A voir comment ça va se traduire sur le plan du contraste et s'il n'y a pas de speckle en raison de la source laser.
Mais à moins de 1200 euros, ça semble être une sacrée affaire.
- Dirty Vincent
- Inscription Forum: 24 Juil 2000 2:00
Il a l'air ciblé Gaming ce projo prudent d'attendre un test en Homecinéma ....
HT76
HT76
- HT76
- Inscription Forum: 24 Oct 2001 2:00
HT76 a écrit:Bonjour,
HT76
Oui, clairement. Après, on n'est jamais à l'abri d'une bonne surprise. BenQ a sorti plusieurs projos orientés gaming ces dernières années et qui étaient très bien calibrés en sortie de carton pour du HC.
Mais comme tu dis, wait and see.
Après, même un PJ gaming, avec les réglages de base, en principe, il y a toujours moyen d'en tirer un truc potable.
- Dirty Vincent
Effectivement des vidéoprojecteurs estampillés gaming offrent de belles performances pour visionner des films. Je pense notamment au Benq X3100i ou au Viewsonic X1-4K.
https://post.smzdm.com/p/akkvr2e4/
https://post.smzdm.com/p/arqx9z0z/
https://post.smzdm.com/p/akl6vm99/
https://post.smzdm.com/p/a0qow3vw/
Difficile de se faire une idée. Il n'y a pas de mesures, à part le gamut qui n'atteint pas les 100% du Rec.709.
Ou alors j'ai mal regardé. Rien vu au sujet du contraste natif, par exemple...
- maxlam
- Inscription Forum: 02 Mai 2012 12:34
https://www.heimkino.de/viewsonic/views ... n#farbraum
Contraste mesuré en natif à 1200:1.
Dynamique un peu au dessus de 2000:1
Il semble par contre bien lumineux.
Par contre il serait intéressant d'avoir plus de détails en ce qui concerne la mise en oeuvre du HDR.
La couverture du DCI-P3 n'est que de 73%, ça part mal
- maxlam
maxlam a écrit:https://www.heimkino.de/viewsonic/viewsonic-lx700-4k-4k-hdr-laser-beamer-heimkino-de-tuning-edition#farbraum
Pas si mal, le contraste. Il y a des effets de pompage avec le contraste dynamique ?
- Dirty Vincent
C'est pas précisé dans le "test".
Cependant mon expérience du Dynamic Black avec laser est que ça fait illusion, pour autant que tu ne visionnes pas des films ou séries sous-titrées...
Il y a également des changements de colorimétrie en fonction de la luminosité des scènes...
Bref, le natif est passable. A voir ce que ce projecteur peut offrir après un "vrai" test.
- maxlam
je comprends pas comment en natif on stagne à ces valeurs sur des puces 0.65, c'est peut-être une fausse impression mais il me semblait qu'avec l'ancienne 0.66, notamment celle qui était en xpr*2, on montait plus haut. Et par quel miracle, des 0.47 en alpd peuvent dépasser les 3000:1.
c'est un souci optique, d'implantation ou logiciel ?
- Régis
En 3'000:1, APLD et 0.47, il n'y a guère que les UST qui montent aussi haut.
La wobulation semble effectivement faire perdre du contraste. J'en veux pour preuve le Viewsonic X1 1500:1 par rapport au X1-4K.
Ou alors le TH690ST par rapport au W4000i...
- maxlam
le contraste à 3000:1 serait lié à la focale utilisée dans le projecteur ?
- Régis
Il y a certainement un lien.
Par exemple le Dangbei Mars Pro 4K utilise un ALPD de troisième génération et possède un contraste natif bien en dessous des UST qui utilisent la même technologie.
De même pour le Xiaomi MIJA ALPD 3.0
- maxlam
Le LX700-4K ou plutôt devrais-je dire le LS710-4KE sera commercialisé chez nous en février.
Il semblerait que le prix serait plus proche de 1599-1699 euros (d'après une source).
EDIT :
MAJ du premier post du topic.
EDIT :
