Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AxleM, bebel56, bon1410, christian.vuil, coucouse, dat, f_lorian, fz, gag67, gallak, gwendal55, Inside, Julio13, patlermite, Polosport, RagnarLothbrock, Sebos13, shenos, TALION, warrior1300, wincoach, xav28270, zeh et 109 invités
Dune HD Pro One 8K Plus (S928X media processor)
Message » 25 Déc 2023 12:52
Et voilà déjà le nouveau Dune...
Même boîtier que le récent Dune HD Premier 4K Pro.
8K Dolby Vision & HDR10+ Media Player
with Android, 2.5" HDD rack, 8+64 GB memory, 1Gbit, WiFi6.
New flagship line of Dune HD 8K models (next generation after RTD1619DR models).
High-End video quality, 8K, AV1, YouTube 8K HDR,
Dolby Vision VS10, HD audio, ISO 4K DV P7 FEL, AFR.
Note: This media player is excellent for Hi-End media playback from HDD or NAS. Support for Android apps and streaming services is a non-primary function without guaranteed compatibility (see more details here).
Caractéristiques principales
New line of cutting edge 8K media players from Dune HD
The new flagship 8K line is based on the newest top S928X media processor, has full 8K support, very powerful hardware and various other advantages. At the same time, this line keeps the most important features of RTD1619DR models. Top picture quality, Dolby Vision VS10 technology, full support for all formats of HD audio, advanced support for playback of Dolby Vision files, support for full menu in ISO images and disc structures.
Hi-End S928X media processor with 8K, AV1, VS10
The newest S928X media processor is the most advanced and the most powerful media processor from Amlogic. It includes Dolby Vision VS10 engine for outstanding picture quality, supports true 8Kp60 decoding and true 8Kp60 output, includes the newest AV1 video codec, and has top performance overall.
Full 8K video support
8K is a next generation video format, which offers 4 times as many pixels than 4K. 8K format gives the most immersive viewing experience and delivers a truly smooth and crisp image. The media player supports both 8Kp60 HDR video decoding and 8Kp60 HDR video output. The media player can downscale 8K content to any resolution and upscale any content to 8K resolution. YouTube 8K HDR is supported.
Codec vidéo AV1
The media player supports the new AV1 video codec, which helps to get up to 50% video quality improvement without increasing video bitrate (or requires up to 50% lesser bitrate for the same video quality). This new video codec is already used by YouTube and will be increasingly important for compatibility with various video services and content sources.
Top performance
The media player has a very powerful CPU and GPU. The CPU includes four 2.0 GHz ARM A55 cores, a "big" 1.9 GHz ARM A76 core (with very high performance), and also an extra core for system needs. The resulting CPU performance is up to 2x more than in RTD1619DR. GPU has been upgraded to Mali G57. Combined with super-fast LPDDR4X and super-fast eMMC, this gives blazing fast overall system performance. Total Antutu score exceeds 300,000 points, which is significantly more than in the previous generation media players.
8 GB operating memory
This huge amount of operating memory gives the best performance even in the most heavy use cases. 64-bit Linux kernel allows the efficient use of 8 GB RAM for caching of system and apps code and data. Apps launch, run and switch quicker. More memory can be used for graphics caching, which further improves the performance of the user interface.
64 GB flash memory
A giant storage space for the most heavy apps, for system needs (such as storage of movie posters), and for internal storage which can be used for any purpose. For example, you can store media files in the internal storage and even share them to the local network via the built-in SMB file server.
Dolby Vision et HDR10
The media player supports not only HDR technology, but also the most latest and advanced Dolby Vision and HDR10+ technologies. In conventional HDR technology, the brightness range is set at the beginning of the film and does not change during the film, so completely dark and completely bright scenes may have insufficient detail. In the latest Dolby Vision and HDR10+ technologies, the brightness range can vary from frame to frame, so the maximum picture detail is provided even in scenes that contain only dark or only light elements.
Processeur vidéo Dolby Vision VS10
The advanced Dolby Vision VS10 video processing engine ensures maximum image quality when playing any type of content (SDR, HDR, Dolby Vision) with any type of video output signal (SDR, HDR, Dolby Vision). In particular, it improves the quality of conversion between Dolby Vision, HDR, and SDR. This gives benefits even when using the media player with TVs that do not support Dolby Vision, including Plasma TVs, and especially when using projectors.
Profil Dolby Vision 7 FEL
The media player supports direct playback of Dolby Vision profile 7 FEL double-track and double-layer files. This is the most advanced Dolby Vision format. The media player plays video in this format using both tracks/layers. The important Dolby Vision information from the second track/layer (Dolby Vision RPU metadata) is transmitted to TV together with video data from the first track/layer. The passed video data uses 10-bit color depth - the maximum color depth supported by OLED-panels in OLED TVs, i.e. this fully uses the capabilities of OLED TVs. Combined with the full use of Dolby Vision metadata this gives an excellent Dolby Vision picture on the TV screen.
Prise en charge la plus large des formats de fichiers Dolby Vision
Dolby Vision is supported for all popular file formats (MKV, MP4, TS, M2TS, ISO, movie folder structure). All popular Dolby Vision profiles (P5, P7 MEL and FEL, P8) are supported. The media player supports the largest number of variations of Dolby Vision file formats of any other media player.
Lecture des structures ISO/dossier Dolby Vision
The media player supports direct playback of movie ISO/folder structures in Dolby Vision format (MEL and FEL). The extended Dolby Vision information is used and transmitted to the TV to improve the picture quality. This is possible due to the unique video playback and output engine created by Dune HD.
Full support for HD audio
The media player can output all formats of HD audio (up to Dolby TrueHD and DTS X) to HDMI in bitstream passthrough mode. Additionally, the media player can decode all formats of HD audio to multichannel PCM (up to 7.1 channels).
Audio playback with original sample rate
The media player can play high-quality music files and output audio to HDMI and S/PDIF preserving the original audio sample rate. Sample rates from 44.1 to 192 kHz are supported.
2.5" HDD rack
You can easily install a 2.5" SATA HDD or SSD into the media player and store up to 5 TB and more media content directly in the media player. HDD hot swap is supported. No tools are needed for HDD installation. Installed HDD can also be accessed from the local network via built-in SMB file server.
USB 3.0 slave HDD port
You can easily connect the media player by USB cable to a PC for fast and convenient direct file transfer between the PC and the HDD in the media player. No additional power is required, so you can also use the media player as a portable USB HDD.
Entire case as a heatsink for super-efficient silent cooling
The S928X processor is a very powerful processor. It needs very efficient cooling to achieve the maximum performance without any speed down. The media player implements the best passive cooling approach, which uses the entire metal case as a huge heatsink. Heat is very efficiently transferred from the processor directly to the metal case via a special heat transfer element.
Quiet fan for extra HDD cooling
Besides the passive cooling solution, the media player also has a quiet fan, which helps to ensure HDD longevity under maximum loads.
Android 11
For Android applications, the media player uses a modern Android version 11. This increases system performance and gives improved compatibility with the newest Android apps.
Autres avantages clés par rapport aux concurrents
Meilleure lecture de film ISO/structure de dossier de sa catégorie
Dune HD media players have the best-in-class support for playback of movie ISO/folder structures, including full support for disc menu, 4K, DV, HDR10+, HDR10, HD audio. Movie ISO/folder structures can be played from any source - local drive (USB, SATA) or network drive (SMB, NFS). A special engine helps to ensure smooth playback of the entire movie w/o any audio/video interruptions even when playing movies with complicated structure.
Changement automatique d'image/de résolution
The media player can automatically switch output framerate and resolution to match the played content. This helps to ensure absolutely smooth video playback and use the best way for video resolution upscaling (resolution upscaling by the media player or by the TV).
Changement d'image/de résolution sans scintillement
Dune HD media players implement its own advanced flicker-free approach for automatic framerate and resolution switching, which performs video mode switching before the start of file playback (rather than after). Most other media players perform video mode switching after the start of file playback, which causes unpleasant flickering.
Multichannel DSD and other advanced music formats
You can play music in various advanced formats, including multichannel FLAC, WavPack, APE, ALAC and even multichannel Super Audio CD (SACD). SACD music files, encoded using the advanced DSD audio codec, are supported in all popular formats (ISO, DFF, DSF), including both stereo and multichannel files, including files which use the DST compression. Multichannel DSD files can be output to HDMI as multichannel PCM. Stereo DSD files can be output to HDMI and S/PDIF as stereo PCM.
Widevine L1 for premium video services
Support for Widevine Level 1 DRM (the most advanced DRM level) makes it possible to watch premium online video services with HD and Ultra HD video quality. Media players w/o Widevine Level 1 support can only output low quality (standard definition) video in many such services.
Optimized OS
Since the media player does not have Google Android TV certification, the operating system in the media player is optimized to eliminate the unneeded burdens and limitations. In particular, the media player does not create unneeded Android folders on connected HDDs, system performance is not decreased by Android indexing files on the connected HDDs, and so on.
Technologie Dune HD Android Playback Accelerator
Cette technologie unique gère intellectuellement les ressources du système d'exploitation Android afin de minimiser l'influence de ce dernier sur le moteur de lecture multimédia et d'assurer une lecture vidéo et audio fluide et de haute qualité.
Système d'exploitation Dune HD basé sur Linux
Le lecteur multimédia utilise un système d'exploitation hybride unique, composé d'un système d'exploitation Dune HD basé sur Linux (pour garantir un fonctionnement stable et une lecture fluide des médias) et d'un système d'exploitation Android (pour prendre en charge les applications Android), qui fonctionnent simultanément.
Ecosystème Dune HD
Basées sur le SDK et les API de Dune HD, diverses applications optimisées pour la télévision, des plugins, des extensions, des habillages d'interface graphique, des solutions de gestion de collections, des intégrations avec des systèmes domotiques sont disponibles via la boutique officielle de Dune, des vendeurs tiers et l'énorme communauté d'utilisateurs.
Dune HD UI
La célèbre interface utilisateur de Dune HD, développée et peaufinée pendant plus de 12 ans, spécialement optimisée pour l'utilisation sur les écrans de télévision et l'utilisation via une télécommande standard, réglée pour la meilleure convivialité possible, rend l'utilisation du lecteur multimédia facile et pratique.
Dune HD organisateur de films et encyclopédie de films
“My Collection” function organizes a user's movie collection into a nice looking catalog. A comprehensive movies encyclopedia provides the information about hundreds of thousands of movies with detailed descriptions, posters, cross-links between movies and persons, trailers, direct links to online video services, etc. The advanced file browser automatically recognizes movies.
Application mobile Dune HD
L'application mobile unique de Dune HD (Dune Control) pour les appareils mobiles iOS et Android offre un accès complet à toutes les fonctions du lecteur multimédia Dune HD d'une manière très pratique et puissante. Elle remplace entièrement la télécommande IR standard, permet de naviguer et de choisir le contenu multimédia directement sur votre appareil mobile (le menu affiché sur l'appareil mobile reflète le menu affiché sur l'écran du téléviseur), et comprend la section Lecture en cours pour un contrôle pratique de la lecture du contenu multimédia.
Maison intelligente
Le lecteur multimédia fournit une puissante interface de contrôle IP et offre de nombreuses options d'intégration dans les systèmes de maison intelligente et de domotique, tels que Control4 et Crestron.
Historique prouvé des mises à jour de logiciels sur une très longue période
Dune HD is known for its reputation to listen to user's feedback and provide software updates for many years. For example, for some old models, software updates with additional functions have been provided for more than 10 years already. This is possible due to the unique "single code base" approach, which means that firmware for all Dune HD models is based on the same software (continuously developed and improved according to user's feedback).
Autres caractéristiques clés
1 Gbit Ethernet
Ensures fast data transfer and smooth playback of high bitrate video when using a wired connection to the home network.
Wi-Fi 6
This newest Wi-Fi standard provides a better wireless performance and a better wireless range, when using a wireless connection to the home network.
Built-in Bluetooth 5.2
The built-in Bluetooth interface allows you to easily connect various remote controls, wireless keyboards, mice, joysticks, audio speakers, headphones, headsets and other devices. The new Bluetooth version 5.2 improves performance and compatibility.
Bluetooth remote with microphone, IR learning and AirMouse.
The included Bluetooth remote controls the media player via a radio channel, includes a microphone (for voice search in applications which support it), and has IR learning function (allows you to configure the remote control to control not only a media player, but also a TV or other equipment). The AirMouse function allows convenient control of Android applications not optimized for controlling via a conventional remote.
Contrôle IR
The media player has the built-in IR receiver and can be controlled also by IR commands. This means you can use a 3-party programmable or learnable remote of your choice to control the media player, or integrate the media player with your smart home via IR. For example, you can integrate the media player with a smart speaker by using an IR emitter device controlled by the smart speaker.
Front panel display
During file playback, the display shows the current playback position. Also it can show the current time. Display mode can be adjusted in the menu.
duf666
Inscription Forum: 11 Mai 2011 18:07
Message » 25 Déc 2023 21:43
Dommage, pas de lecture des ISO 3D, sinon, je me serais laissé tenter...
Quoique, si, comme je le comprends ("All popular Dolby Vision profiles (P5, P7 MEL and FEL, P8)"), il est capable de décoder toutes les normes de dolby vision, ça pourrait être pas mal... pour ceux qui veulent du DV
Information is not knowledge
fz
Inscription Forum: 16 Avr 2004 22:39
Message » 25 Déc 2023 21:59
La proportion restante de personnes regardant de la 3D à la maison n'a pas dû peser lourd lors des choix de Dune...
duf666
Message » 26 Déc 2023 12:02
Ah bah cherchez l'erreur : le premier 4k est certifié netflix, le nouveau pro 8k ne l'est pas :wtf:
fz
Message » 26 Déc 2023 12:59
Dune n'est plus que l'ombre de ce qu'il était, il sorte de nouveaux produits qui font rêver mais le logiciel ne suit pas. Je possède un 4K solo dont je suis globalement satisfait, mais le firmware n'est pas finalisé on a toujours pas les métadonnées qui s'affiche ainsi que la durée réelle du film hors celle de IMDB.
Je leur ai écrit en septembre à ce sujet, il m’ont répondu.
"A new firmware with the support for "metadata displayed via mediainfo" and some other improvements is expected in Oct/2023,
these improvements have been already implemented for the latest Android TV models and now we are adopting and porting these improvements to all previous models as well."
The abilities to create own sagas and change covers is in development and will become available later.
Nous sommes en décembre et toujours rien.
C'est bien dommage, car se sont les seuls box qui gèrent correctement les BD menu.
delennsheridan
Inscription Forum: 25 Déc 2021 11:49
Message » 26 Déc 2023 14:10
fz a écrit:Ah bah cherchez l'erreur : le premier 4k est certifié netflix, le nouveau pro 8k ne l'est pas :wtf:
Si je puis me permettre, ce n’est pas le même usage. Dune HD Homatics Box R 4K Plus, est plus spécialisée Netflix et autres. Cependant, ils sont en train de renouveler leur gamme en 8K. Donc les certifications vont, à espérer, suivre. Pour le prix, si on compare avec les derniers lecteurs Zappiti, la Dune HD Homatics Box R 4K, est très au-dessus, surtout pour la lecture de très gros fichiers sur NAS en Wi-fi. Quant à dire que les logiciels ne suivent pas, je n’ai pas constaté cela. Au contraire, la qualité d’image est très supérieure à un Signature à 2600€.
sylvain48
Inscription Forum: 13 Mai 2021 12:46
Message » 26 Déc 2023 14:54
Je n'ai rien contre la qualité de l'image qui est très bonne, je parle simplement du reste (Métadonnées, possibilité de changer l'affiche, le FanArt, la gestion des sagas, une meilleur gestion des vus non vus), chose qu'ils nous promettent depuis longtemps et qui n’arrive pas.
delennsheridan
Message » 26 Déc 2023 14:57
delennsheridan a écrit: on a toujours pas les métadonnées qui s'affiche ainsi que la durée réelle du film hors celle de IMDB.
Quand vous lancez le film vous avez 3 infos :
- La durée totale
- La position en temps réel
- Le temps restant
What else ?
"Dune n'est plus que l'ombre de ce qu'il était" :lol: :lol: :lol:
Revendez le, vous trouverez des Zappiti à pas cher.
sierra1959
Inscription Forum: 16 Mar 2021 19:12
Message » 26 Déc 2023 15:20
Je n'ai pas (4K, Dolby Vision, HDR 10+ etc.) et surtout la vrais durée qu'on aurait avec mediainfo, chose que je n'ai toujours pas sur mon "Dune HD Pro Vision 4K Solo" à + de 400 €. vous pouvez me dire que ce n'est pas important mais pour moi ça l'est quand je paie aussi cher.
Peut-être que sur les modèles de 2023 cela apparait alors pourquoi ne pas l'implémenter sur les modèles précédent.
delennsheridan
Message » 26 Déc 2023 16:21
Le Solo 4k affiche la durée effective ou restante suivant le réglage !
J’en ai un…
Quant au reste, HDR ou Dolby Vision la plupart des téléviseurs l’indique.
Le format hd ou 4k, tu dois bien le savoir quand tu fais tes rip…
De plus, rien ne t’empêche de l’indiquer dans le nom du répertoire dans lequel tu mets le film.
Maintenant si tu es à 2-3 minutes près sur la durée d!un film, je ne peux pas t’aider…
duf666
Message » 30 Déc 2023 19:09
D'autres modèles Dune sont prévue pour 2024 ?
Hubu
Inscription Forum: 02 Jan 2020 16:47
Message » 30 Déc 2023 21:44
Attention, ce modèle ne supporte pas la lecture du Dolby Vision P7 MEL ou FEL contrairement à ce qu'on pourrait croire. Comme pour les modèles précédents, ce lecteur est compatible avec, sait lire un fichier en DV P7 (STDL ou DTSL), mais ne le transmet pas entièrement.
Il manque un second décodeur vidéo HEVC pour la lecture (et donc la transmission) de la couche MEL ou FEL. Seule la couche HDR10 et les RPUs sont transmis au téléviseur/projecteur.
Ce nouveau lecteur n'a, à mon sens, pas d'intérêt pour la majorité des gens. Je ne crois pas qu'on soit majoritairement équipés en 8K, il n'existe aucune source disponible (à part des démos j'entends), et les autres petites améliorations comme le support de l'AV1 sont soit très optionnelles voire inutiles (aucun fichier film/série n'est en AV1 sauf sur sur YouTube et peut-être d'autres services de streaming que je ne connais pas, mais cette box n'est pas faite pour le streaming), soit ne justifient pas la différence de prix.
Les specs techniques sont plus hautes, mais pour de la lecture 4K60 en BD ISO/BDMV, soit le maximum aujourd'hui disponible (et encore, le 4K60 est exceptionnel) un Real Vision avec 2GB de RAM suffit, et coutait 200€ à sa sortie (j'en ai pris deux, je ne regrette pas !).
Alors OK ici il y a un emplacement HDD 2.5" interne et une connectique un poil meilleure, mais c'est pas fou.
Personnellement, je suis déçu, je ne comprends pas trop l'intérêt de ce lecteur puisqu'il n'a même pas tous les avantages/compatibilité avec les services de streaming pour ceux qui en ont besoin.
Du coup, ça risque de venir remplacer la gamme actuelle à un prix plus élevé, avec des specs pour l'instant inutiles, et toujours un manque criant du support complet du Dolby Vision.
Dommage !
Moonly
Inscription Forum: 17 Déc 2021 16:48
Message » 30 Déc 2023 22:11
Nous n’aurons pas la prise en charge complète du DV sur un lecteur multimédia avant longtemps, pas uniquement pour cause de limitation matériel mais aussi parce que Dolby refuse pour le moment de donner une telle licence pour les SOCs dédiés à ce type de lecteur.
Temearoo
Membre HCFR Contributeur
Inscription Forum: 11 Déc 2011 2:44
Message » 30 Déc 2023 22:27
Moonly a écrit:Attention, ce modèle ne supporte pas la lecture du Dolby Vision P7 MEL ou FEL contrairement à ce qu'on pourrait croire. Comme pour les modèles précédents, ce lecteur est compatible avec, sait lire un fichier en DV P7 (STDL ou DTSL), mais ne le transmet pas entièrement.
Dommage !
Avec un compte rendu d’une telle qualité, et que je partage à 100%, le meilleur hommage qu’on puisse te faire serait de clôturer ce sujet car si tu avais voulu signer l’arrêt de mort de ce nouveau lecteur Dune, je ne vois pas ce que l'on pourrait dire de plus pour y arriver ! :bravo: :thks:
schmoupie
Inscription Forum: 15 Déc 2006 1:37
Message » 31 Déc 2023 0:40
Ne vous méprenez pas, je ne cherche pas à enterrer ce lecteur, je pense qu'il a un public, et ce n'est pas parce que c'est potentiellement un public de niche qu'on doit condamner ce lecteur, il fera sûrement des heureux !
Ici, je me questionne plus sur la gamme de produits que Dune compte mettre sur le marché, et surtout l'éventuel remplacement de la gamme à base de puce Realtek (dont la Real Vision) par cette nouvelle gamme plus puissante, et potentiellement plus chère, alors que pour la lecture de fichiers, la gamme actuelle remplit déjà toutes les cases, hormis le support complet du Dolby Vision qu'on risque de ne jamais voir arriver.
C'est le positionnement du lecteur et de la gamme qui va en découler qui m'interroge. On verra bien. ;)
Moonly
