Modérateurs: Le CA de l’Association HCFR, Modération Forum Home-Cinéma • Utilisateurs parcourant ce forum: lophil, macech, papounay, spydex, tedkiller, vwinman et 117 invités
Dune HD Premier 4K Pro
Message » 30 Nov 2023 17:46
Il ne me semble pas qu’un sujet a déjà été ouvert sur ce nouveau lecteur Dune…
2-in-1 Premium Netflix-certified Streaming Media Player + Dune HD Media Center.
Netflix in 4K Dolby Vision & Atmos, AV1, 4GB, Wi-Fi 6, 1Gbit, ISO 4K DV P7 FEL.
2.5" HDD rack. Extremely Feature-Rich Android TV Box.
Hardware and Technologies
S905X4-K media processor (special version with all licenses)
S905X4-K media processor is the most advanced version of the latest media processor from Amlogic which includes all possible technologies and licenses: Dolby Vision, Dolby Atmos, DTS.
4 GB operating memory
Ensures excellent performance and support for the most heavy Android apps.
32 GB flash memory
Provides a lot of space for Android apps and other needs.
1 Gbit Ethernet
Ensures fast data transfer and smooth playback of high bitrate video when using a wired connection to the home network.
Wi-Fi 6
This newest Wi-Fi standard provides a better wireless performance and a better wireless range, when using a wireless connection to the home network.
2.5" HDD rack
You can easily install a 2.5" SATA HDD or SSD into the media player and store up to 5 TB and more media content directly in the media player. HDD hot swap is supported. No tools are needed for HDD installation. Installed HDD can also be accessed from local network via SMB file server function built-in into Dune HD Media Center.
USB 3.0 slave HDD port
You can easily connect the media player by USB cable to a PC for fast and convenient direct file transfer between the PC and the HDD in the media player. No additional power is required, so you can also use the media player as a portable USB HDD.
Front panel display
Gives you even more experience of a classical Dune HD media center. When playing content via Dune HD media center app, shows the current playback position. Also can show the current time.
Dolby Vision and HDR10+
The media player supports not only HDR technology (supported by the previous generation of media players), but also the most latest and advanced Dolby Vision and HDR10+ technologies. In conventional HDR technology, the brightness range is set at the beginning of the film and does not change during the film, so completely dark and completely bright scenes may have insufficient detail. In the latest Dolby Vision and HDR10+ technologies, the brightness range can vary from frame to frame, so the maximum picture detail is provided even in scenes that contain only dark or only light elements.
Dolby Atmos
Dolby Atmos is the most widely used advanced technology for surround sound. Dolby Atmos draws you in deeper, so you hear more and feel more, for a more realistic and immersive audio experience. This media player supports Dolby Atmos sound both when watching streaming services such as Netlix and when playing files from your local library (in formats such as ISO, BDMV, MKV, and so on).
Newest Dolby MAT technology
This media player includes the newest Dolby technology for multichannel surround sound - Dolby MAT. Using Dolby MAT technology, the media player does not just output the fantastic Dolby Atmos audio to your TV or A/V receiver, but also performs partial decoding of the audio directly on the media player. This improves A/V synchronisation, reduces latency, and improves compatibility. Nowadays this approach for audio output is recommended by industry leaders such as Netflix and Google.
AV1 video codec
The media player supports the very newest AV1 video codec, which helps to get up to 50% video quality improvement without increasing video bitrate (or requires up to 50% lesser bitrate for the same video quality). This new video codec is already used by YouTube and will be increasingly important for various services.
YouTube 4K HDR and VP9 profile 2
The media player supports the modern "VP9 profile 2" video codec, which is used by YouTube for HDR content. This makes it possible to watch YouTube videos in maximum 4K HDR quality.
Two USB 3.0 host ports
Allows you to connect USB storage devices (such as flash drive, HDD or SSD) and ensures fast data transfer and smooth playback of high bitrate video. Connected USB storage devices can also be accessed from local network via SMB file server function built-in into Dune HD Media Center.
Dispo pour 199€
duf666
Inscription Forum: 11 Mai 2011 18:07
Message » 19 Déc 2023 16:09
Merci pour la prez'
Les retours sur amazon ne sont pas forcément folichons... Apparemment impossible de lire les menus des BR UHD au format .iso ou structure BR UHD, alors que c'est une des spécificités et avantage des Dune par rapport aux Zidoo par exemple.
Sinon ce serait le top d'avoir une box ultime sur Google TV 12, avec autoframerate fonctionnel sans appli tiers et au comportement hasardeux sur les applis de streaming officielles.
Et le support de tous les formats audio et vidéo : DTS-HD, Dolby TrueHD, Dolby Atmos, Dolby Vision (tous profils), HDR10+...
La box ici présente sur interface Google TV, sans l'appli Dune HD préinstallée apparemment, il faut la télécharger sur le site officiel pour l'installer dessus. Bizarre cette histoire :p
P'tet que les gens sur Amazon qui se plaignent du non support des menus n'ont pas installé cette appli...
Une vidéo des menus :
En fait c'est la même box que la HOMATICS Box R 4K Plus, avec rack hdd 2,5" en +...
Toujours sous android 11 et pas de mise à jour en vue vers la 12...
Tv: LG G3 65" Ampli: Denon AVR-X3600H Enceintes 5.1.2 Elipson Facet (2X14F, 1x14C, 2x6B, 2x 6ATM) + SVS PB-1000 Pro Lecteur Multimédia: Nvidia Shield Pro 2019 + Zidoo Z9X + Dune HD Real Vision 4K + Chinoppo M9702 V3
rere130
Inscription Forum: 23 Sep 2009 11:55
Message » 20 Déc 2023 22:12
Bonsoir je l'ai acheté sur Amazon il y a 15jours un peu compliqué a mètre en route mais très belle qualité d'image (TV plasma Panasonic 65 '').
Le seul soucis on ne peu pas déplacer,copier effacer directement en réseau dommage
Timoulan
Inscription Forum: 17 Oct 2023 15:42
Message » 21 Déc 2023 10:39
:wtf:
Tu as un DD dedans, donc tu peux y accéder par ton explorateur de fichier...
Et puis tu le mappes pour qu'il apparaisse en permanence:
Et puis tu crées et gères les répertoires...
duf666
Message » 04 Sep 2025 15:39
Pas beaucoup de suivi sur ce fil ? :hein: :mdr:
griosu
Inscription Forum: 17 Oct 2007 1:04
