Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: ama13, bagnico, brems, ChrisJohn, danywilde36, dedelynks, Edis, enzo2001, Esscobar, gilll, Google [Bot], Irikte, john-peter 1, midoe, passager57, Pgase, philboun, stasio, tailleur de zone, tonton D. et 146 invités
2023 - Hisense U8KQ Mini-LED 4K TV en 55,65 et 75”
Message » 26 Sep 2023 11:48
lektro a écrit:Bonjour je rencontre des problèmes de lecture sur les applis disney Amazon prime la lecture est saccader
Avez vous des solutions pour résoudre ce problème
Merci..
je regarde Netflix et PrimeVidéo de temps en temps mais je n'ai pas remarqué de saccades connecté en ethernet(RJ45)!
lcdmen
Contributeur HCFR 2024
Message » 26 Sep 2023 20:46
lcdmen
Message » 27 Sep 2023 16:07
Hisense ULED U8KQ - un concurrent inattendu pour le téléviseur le plus rentable de 2023 ?
https://www.benchmark.pl/testy_i_recenz ... -u8kq.html
https://www-benchmark-pl.translate.goog ... r_pto=wapp
lcdmen
Message » 29 Sep 2023 10:07
des réglages pour le U8KQ avec sonde:
just for your information I am not a profesional calibrator it is kind of hobby. I am not sure if i do it completely correct. Also, please, keep in mind that each panel is unique. it means the best settings for one panel can be bad for another :) So i warned you !
The following things were used to do my calibration:
Calman software and manual calibration process
ColorChecker Display plus sensor
RasberryPi PGenerator - pattern generator
Hisense u8k 65" (VA panel)
Calibration was done for RGB limited range (16-235) (black level was set to low on TV manually during calibration process and in calman app, but PGenerator provided full range patterns to avoid double processing), because of it it is valid for all video content and it is technically okay for console gaming as well. But It is not suitable for PC gaming, because PC uses full RGB Range (0 - 255) .
Long story short you can try the following settings
if you want to play console games in SDR
if you watch SDR video content
it would be better to avoid the settings:
- if you want to work or play on your PC
Here is a comparing before and after calibration:
Source:
https://www.avsforum.com/threads/2023-h ... 2/page-236
lcdmen
Message » 29 Sep 2023 18:34
Hisense U8KL ULED for 2024 mini-LED panel with 2000 zones and 3.300 nits max brightness
comment il a eu ces infos quelques semaines avant qu'il soit présenté en chine le 26 septembre dernier ! :hein: :??
Edit:
Hisense U8KL : Que Prépare Le Grand Constructeur Pour 2024 ?
https://hxosplus.gr/vision/hisense-u8kl/
https://hxosplus-gr.translate.goog/visi ... r_pto=wapp
lcdmen
Message » 01 Oct 2023 9:24
Hisense U8K vs LG C3 Lucha de grandes televisores! Miniled vs oled
lcdmen
Message » 03 Oct 2023 14:02
Je possède actuellement le TCL 75c845, mais en raison de trop de bugs du système d'exploitation et de problèmes de mise à l'échelle SD, je pense échanger avec Hisense U8KQ 75. Je suis intéressé par la façon dont il gère le mouvement dans les scènes au rythme rapide par rapport au TCL car je n'aime pas beaucoup les TCL. gestion des mouvements et bugs concernant le système d'exploitation tout le temps, je recherche un nouveau firmware et rien n'est corrigé ..
Je vais devoir faire des compromis avec stremio et un vrai débridage à partir d'un boîtier Android externe en raison de l'absence d'applications Google TV sur le hisense mais J'ai vraiment besoin d'une fonction plus stable du téléviseur dans son ensemble.
Que me conseillez-vous de faire ??
ChrisNik
Inscription Forum: 22 Sep 2023 18:05
Message » 03 Oct 2023 17:48
Salut et bienvenue au forum ChrisNik,
vu qu'il n'y'a pas beaucoup de participation dans ce topic je t'invite à consulter le forum US en attendant des réponses ici:
https://www.avsforum.com/threads/2023-h ... 2/page-247
si tu ne comprend pas l'anglais comme moi utilise un traducteur de site !
lcdmen
Message » 03 Oct 2023 19:36
I don't care about us versions as I am from Greece and u8k here is the same version as mentioned here with vidaa os and many differences in contrast with us version of the tv..
I speak English natively as it is part of my job ..
So it would be more helpful to hear opinions of the European version in particular .
Thanks for your answer
ChrisNik
Message » 03 Oct 2023 20:13
ah OK c'est toi qui voit !
en principe l'électronique et la dalle sont identique !
lcdmen
Message » 08 Oct 2023 12:30
Hisense U8K Hands on review
lcdmen
Message » 09 Oct 2023 11:15
Review TV HISENSE U8KQ
lcdmen
Message » 11 Oct 2023 15:03
J'ai acheté ce Hisense U8K en version 55 pouces pour remplacer un vieux LG Oled, les images de ce dernier n'étaient pas très vives.
Revenant sur le téléviseur Hisense, j'ai été vraiment impressionné par le design, avec des cadres très fins et une barre de son intégrée très puissante. Je trouve que l'écran mini LED de celui-ci a vraiment un contraste et une luminosité exceptionnels avec toute une série d'auto-ajustements qui sont la vraie plus-value pour les utilisateurs pas trop experts dans les réglages comme moi.
Outre le design et la luminosité, l'autre chose qui m'a fait tomber amoureux de ce téléviseur est la barre de son intégrée située dans la partie inférieure, qui en plus d'être élégante et raffinée, prend en charge un son véritablement spatial. J'ai ainsi résolu le problème de l'achat d'une éventuelle barre de son supplémentaire et de l'endroit où la placer dans le salon.
Pour les applis, j'ai été frappé par l'interface de leur système d'exploitation VIDAA, j'ai lu autour de moi qu'il y avait des commandes vocales très pratiques, je vais les essayer prochainement.
Il y a Netflix, Prime Video, Apple TV, Disney+ mais pour pallier le manque de Sky's Now TV j'ai dû connecter un Fire Stick qui n'a malheureusement pas la même vitesse que le système d'exploitation Hisense, j'espère donc que cette application arrivera bientôt aussi.
En général, j'ai été très positivement surpris par les finitions esthétiques, la luminosité maximale et le son puissant avec basses intégrées, autant d'aspects qui me font considérer cet achat comme une mise à niveau de mon précédent OLED, quelque chose qui n'était pas du tout évident, même parce qu'il C'était la première fois que j'achetais une mini LED mais surtout un téléviseur Hisense après diverses suggestions d'amis et de proches.
Je ne peux que recommander ce produit qui présente un rapport qualité/prix vraiment excellent.
https://www.amazon.fr/HISENSE-55U8K-T%C ... merReviews
lcdmen
Message » 14 Oct 2023 10:58
lcdmen
Message » 14 Oct 2023 13:21
lcdmen
Retourner vers Ecrans UHD 4K
