Hello, A new version (7.2.3.0) is available. Please find below some of the improvements since version 7.1:
You can now choose the path for the Cache folder.
Removed play trailer button for books.
Fix issues with the following providers : IAFD, Orgasmik, HotMovies, Fnac , TheGamesDB, Amazon, MusicBrainz, Bing
You can now track what episode you have seen or not using right button on the episode.
You can now group your collections by metadata and in the grid view, we also add a filter on the metadata.
In the music pdf Export we add the tracks.
For the music, we add Deezer as first provider.
We rewrite the music tracks option, you can now add, remove and play tracks. You can also select the file path of each tracks.
When you delete an item from your collections, you have now an option to delete the physical file at the same time.
We add and open/close all menu when you group your items.
We fix issues in the friends and loans modules.
You can now search your book by UPC/ISBN using GoodReads provider.
We add trailers in XML Export.
We fix issues with Barcode Search.
We fix issues with CSV export.
We fix issues with Filmotech import.
And as usual we try to fix bugs and improve performances
http://www.mycollections.fr/Download/myCollections.exe
