Modérateurs: Modération Forum Loisirs, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 1 invité
Un forum dédié aux échanges sur : apprendre, se cultiver, des formations, etc...
Le post des nouvelles des étoiles...
Message » 25 Jan 2022 9:52
JWST
Pour ceux qui veulent connaitre la suite:
https://www.nasa.gov/nasasciencelive
Robert64
Contributeur HCFR
Inscription Forum: 12 Sep 2006 15:40
Message » 25 Jan 2022 19:25
WJST
Commentaires Nasa:
....The analysis shows that less propellant than originally planned for is needed to correct Webb’s trajectory toward its final orbit around the second Lagrange point known as L2, a point of gravitational balance on the far side of Earth away from the Sun. Consequently, Webb will have much more than the baseline estimate of propellant – though many factors could ultimately affect Webb’s duration of operation.
Webb has rocket propellant onboard not only for midcourse correction and insertion into orbit around L2, but also for necessary functions during the life of the mission, including “station keeping” maneuvers – small thruster burns to adjust Webb’s orbit — as well as what’s known as momentum management, which maintains Webb’s orientation in space.
The extra propellant is largely due to the precision of the Arianespace Ariane 5 launch, which exceeded the requirements needed to put Webb on the right path, as well as the precision of the first mid-course correction maneuver – a relatively small, 65-minute burn after launch that added approximately 45 mph (20 meters/sec) to the observatory’s speed. A second correction maneuver occurred on Dec. 27, adding around 6.3 mph (2.8 meters/sec) to the speed.
The accuracy of the launch trajectory had another result: the timing of the solar array deployment. That deployment was executed automatically after separation from the Ariane 5 based on a stored command to deploy either when Webb reached a certain attitude toward the Sun ideal for capturing sunlight to power the observatory – or automatically at 33 minutes after launch. Because Webb was already in the correct attitude after separation from the Ariane 5 second stage, the solar array was able to deploy about a minute and a half after separation, approximately 29 minutes after launch....
Source: Blog Nasa
Robert64
Contributeur HCFR
Message » 25 Jan 2022 20:15
Du coup, il pourra rester plus longtemps en service, ou ajuster plus précisément et plus souvent son orbite ?
Sietch31
Inscription Forum: 16 Nov 2005 6:44
Message » 25 Jan 2022 20:18
Sietch31 a écrit:Du coup, il pourra rester plus longtemps en service, ou ajuster plus précisément et plus souvent son orbite ?
C'est çà!
C'est la réserve de carburant qui fait la durée de vie.
Robert64
Contributeur HCFR
Message » 26 Jan 2022 18:59
JWST
WEBB IS ORBITING L2
Next Steps: Cooldown, Alignment, Calibration
Nominal Event Time: Launch + 30 days
Status: Webb is in L2 Orbit and Cooling
Telescope deployment is complete. Webb is now orbiting L2.
Ongoing cooldown and eventual instrument turn-on, testing and calibration occur.
Telescope mirror alignment and calibration also begin as temperatures fall within range and instruments are enabled.
Stay tuned...this page will track these milestones and keep you informed of where Webb is on the path to our first science images.
The telescope and scientific instruments started to cool rapidly in the shade of the sunshield once it was deployed, but it will take several weeks for them to cool all the way down to stable operational temperatures.
This cooldown will be carefully controlled with strategically-placed electric heater strips. The remaining five months of commissioning will be all about aligning the optics and calibrating the scientific instruments.
Source : Nasa
Robert64
Contributeur HCFR
Message » 27 Jan 2022 16:17
Une équipe chargée de cartographier les ondes radio de l’Univers rapporte la découverte d’un objet inhabituel et surprenant, qui ne ressemble à aucun autre objet connu. Situé à environ 4000 années-lumière de la Terre, il libère régulièrement une incroyable quantité d’énergie. Les astronomes qui l’ont découvert pensent qu’il pourrait s’agir d’un tout nouveau type d’étoile à neutrons, dotée d’un champ magnétique ultra-puissant.
https://trustmyscience.com/astronomes-d ... s-energie/
Loug
Inscription Forum: 22 Nov 2006 22:07
Message » 27 Jan 2022 18:58
De toutes manières, on connait encore assez peu de choses sur ces astres exotiques, étoiles à neutrons, magnétars, pulsars, etc....
Pour beaucoup, ce n'est que des modèles théoriques. Donc, des surprises de ce genre, il risque d'y en avoir pas mal d'autres. Ce qui permettra de recaler les modèles.
Robert64
Contributeur HCFR
Message » 27 Jan 2022 19:37
Il faut que Zeus arrête de se friter avec ses collègues ! Non mais ! :lol:
beb
Inscription Forum: 02 Mar 2002 2:00
Message » 28 Jan 2022 20:26
beb a écrit:Il faut que Zeus arrête de se friter avec ses collègues ! Non mais ! :lol:
Faut s'en méfier de ce gars!
Un jour, on va se prendre sur lag' une super novae qu'on n'aura pas vu venir!
Et là, Chichxulub à côté, c'est un pétard mouillé!
Quand au JWST, rien de bien nouveau pour le moment
Robert64
Contributeur HCFR
Message » 28 Jan 2022 23:05
du coup je suis tombé sur :
La résonance orbitale est, en astronomie, la situation dans laquelle les orbites de deux objets célestes A et B, en révolution autour d'un barycentre commun, ont des périodes de révolution T A et T B commensurables, c'est-à-dire dont le rapport T A / T B est un nombre rationnel
4:2:1 Io-Europe-Ganymède (lunes de Jupiter), l'unique résonance de Laplace.
https://fr.wikipedia.org/wiki/R%C3%A9sonance_orbitale
Loug
Message » 29 Jan 2022 11:22
Willy Benz: "Il faut être prudent dans la recherche de vie extraterrestre"
https://www.rts.ch/info/sciences-tech/1 ... estre.html
C'est sûr que quand on voit la propension de l'être humain à s'être construit une société moderne Titaniquesque, pas sûr que d'autres formes de vie "avancée" soient plus malignes... Quoique, peut-on encore faire pire (à part comme il le pense, s'être déjà auto-détruites)? :hehe:
Sa remarque sur les milliardaires fait probablement écho à Musk par exemple, qui s'est fait plein de potes chez les astronomes justement.
ssebs
Contributeur HCFR 2024
Inscription Forum: 23 Nov 2014 22:30
Message » 29 Jan 2022 11:28
Loug a écrit:.....
Si tu veux t'amuser à recenser toutes les résonances dans le système solaire, il y a du boulot!
D'autant plus que c'est un phénomène qui semble simple mais ne l'est pas du tout.
Le plus rigolo est le couple Pluton/Charon: au départ, c'est tout simple, juste deux petites planètes qui tournent autour de leur centre de masse commun en se présentant à chacune la même face. Mais si tu fais intervenir les autres petits corps qui orbitent dans le coin, ça devient vite indémm...able.
Encore plus compliqué si on tient compte des précessions.
Très intéressante est la page de discussion entre deux pros à propos de la pertinence des résonances d'ordre élevé. Il y a encore un peu de controverse sur le sujet...
Robert64
Contributeur HCFR
Message » 29 Jan 2022 20:07
ssebs a écrit:Willy Benz: "Il faut être prudent dans la recherche de vie extraterrestre"
Il a raison!
Quand on regarde notre histoire, et à peu près partout sur notre Terre, chaque fois que deux civilisations de niveaux différents se sont rencontrées, ça c'est mal terminé pour la moins avancée. Perso, tant qu'on n'en sait pas plus sur les voisins, je resterais discret.
C'est un peu la limite de l'exercice: tout ce que nous pouvons imaginer est forcément frappé d'anthropomorphisme, car les humains sont la seule référence que nous ayons. Or, il ne faut pas oublier que nous sommes le résultat de 3 milliards d'années d'une évolution dans laquelle le milieu a joué un rôle prépondérant. Et il n'y a aucune raison que si des êtres vivants sont apparus ailleurs, ils aient des points communs avec nous.
Par exemple pour nous une civilisation "avancée", c'est forcément en science et technologie, mais est-ce la seule possibilité?
Et quand à la question "y a-t-il de la vie ailleurs?", eh bien malgré Drake, Fermi, le programme Seti, on n'en sait toujours strictement rien.
Ce qui d'ailleurs pose un petit problème théorique:
Il existe un "principe cosmologique" qui stipule qu'il n'y a pas dans l'Univers de lieu particulier et toutes les théories cosmologiques reposent là dessus.
Si la Terre est le seul lieu où existe la vie, elle devient un lieu remarquable et le principe s'effondre. :siffle:
Robert64
Contributeur HCFR
Message » 30 Jan 2022 10:30
En voyant la vidéo des satellites de Jupiter, cela m'a rappelé la Römer et le calcul de la vitesse de la lumière, déduite de la variations des éclipses de Io en fonction de la distance Terre-Jupiter.
Ils avaient les idées et du temps pour les prouver , à l'époque !!!
Ceux qui ne savent rien en savent toujours autant que ceux qui n'en savent pas plus qu'eux
Abonnez vous à votre groupe régional: "Résidents de ............."
Thierry.P
Modération Rencontres
Inscription Forum: 20 Sep 2001 2:00
Message » 30 Jan 2022 10:45
Thierry.P a écrit:En voyant la vidéo des satellites de Jupiter, cela m'a rappelé la Römer et le calcul de la vitesse de la lumière, déduite de la variations des éclipses de Io en fonction de la distance Terre-Jupiter.
Römer n'avait pas vraiment déduit la vitesse de la lumière mais déduit qu'elle était finie et pas infinie. :wink:
wopr
Retourner vers Se cultiver_apprendre
