Qui n' est rien d' autre qu' un clone de l' Emotiva XPA Gen3 - 7 canaux ( avec des choses en plus
![:hehe: :hehe:](https://www.homecinema-fr.com/forum/images/smilies/whistle.gif)
avec Vu-mètres sauce Advance Acoustic .
Ce qui s' explique simplement par le fait que les Vu-mètres Advance Acoustic et les cartes des XPA gen3 sont fabriqués par ToneWinner
Cette marque propose de nbx autres produits, forts intéressants.
Le Tone Winner AD7300-2.0 un bloc de puissance 7 canaux,
![Image](http://www.tonewinner.com/english/Uploads/article/original_img/1502778334.jpg)
Topology: Fully discrete, dual differential, high current, short signal path Class A/B - Class "H" power supply.
Numbers of Channel: 7 Channels - High powered single channel modules.
Audio Specifications: 240 Volts Test Results:
Power Output: ( Rated Power; THD <0.1% @ 240V (Tested @ AC 240V) - (AC 240V Will Increase the output wattage and maintain the THD<0.1%.)
324 watts RMS/channel; 20 Hz – 20 kHz; THD<0.1%; 8 Ohms; one channel driven.
584 watts RMS/channel; 20 Hz – 20 kHz; THD<0.1%; 4 Ohms; one channel driven.
307 watts RMS/channel; THD<0.1%; 8 Ohms; two channels driven.
500 watts RMS/channel; THD<0.1%; 4 Ohms; two channels driven.
190+ watts RMS/channel; THD<0.1%; 8 Ohms; all Seven channels driven.
Power Bandwidth (at rated power; 8 Ohm load): 20 Hz to 20 kHz (+ / – 0.1 dB).
Broad-Band Frequency Response: 10 Hz to 70 kHz +0/-2 dB.
THD + noise: < 0.006%; at 100 watts RMS; 1 kHz; 8 Ohms.
Signal to Noise Ratio (8 Ohm load):
> 106 dB; ref FTC rated power; unbalanced input (A-weighted).
> 91 dB; ref 1 watt; unbalanced input (A-weighted).
Minimum Recommended Load Impedance (per channel): 4 Ohms (which equals one 4 Ohm load or two paralleled 8 Ohm loads).
Damping Factor (8 Ohm load): > 149.
Input Sensitivity (for rated power; 8 Ohm load): 1.5 V.
Gain: 28 dB.
Maximum Power Consumption: 1128W at 240V
Power Supply: 110V-240V- 15 Amps-20 Amps Auto Switching Class "H"Power Supply.
Material: Aluminum
Modules: Separate Heatsinks for individual modules.
Color: Black
Front Panel: Analogue meter with blue LED lights and Red Needle.
G.W: 26.3KGS ( 57.98 Lb)
Unit size: 17.48 L X 17.32 W X 7.76 H Inches
Package size:22.52 L X 22.52 W X 12.64 H Inches
Accessories: 120 Volts - 15 Amp Power cord cable Included
Warranty: 2 years warranty
![Image](http://www.tonewinner.com/english/Uploads/attached/image/20211021/20211021075819_13138.png)
![Image](https://sc04.alicdn.com/kf/H4345e400daa8470b9c444e8f1b7721c2y/242226567/H4345e400daa8470b9c444e8f1b7721c2y.jpg)
![Image](https://sc04.alicdn.com/kf/Ha5b8318422ef416881b1795128ca1b42S/242226567/Ha5b8318422ef416881b1795128ca1b42S.jpg)
![Image](https://sc04.alicdn.com/kf/Hc47cf785c0b0435c9a147cd71b1005c8k/242226567/Hc47cf785c0b0435c9a147cd71b1005c8k.jpg)
![Image](https://sc04.alicdn.com/kf/H503330af4ef443c1b59813bb25cfdd041/242226567/H503330af4ef443c1b59813bb25cfdd041.jpg)
![Image](https://sc04.alicdn.com/kf/H7518b91bec3346f798f8ec29642b0590h/242226567/H7518b91bec3346f798f8ec29642b0590h.jpg)
![Image](https://sc04.alicdn.com/kf/H978035c3121f48c789a88981e88719bc1/242226567/H978035c3121f48c789a88981e88719bc1.jpg)
Gain: 28 dB.
Material: Aluminum
Color: Black
