Je ne crois plus rtings depuis pas mal de temps, déjà j'ai été très échaudé quand j'ai remarqué dans leurs protocoles de test du contraste, que 75% de la note de contraste est le contraste statique, qui qui avec un LCD que ce soit du LCD VA ou du LCD IPS irait désactiver le Local Dimming réponse absolument personne de sensé et logique !!!!
En suite il m'ont avoué qu'ils ne testaient pas le contraste en Source HDR, mais uniquement en SDR, de plus dans la note de contraste dynamique ils ne donnent pas nécessairement le meilleur taux de contraste du meilleur mode d'image et du meilleur niveau de local dimming.
https://www.youtube.com/watch?v=r_dETpSvAus&lc=UgyQWIQbih1ULjx5a7t4AaABAg.9TICQRC1kWd9TPjCAZAlSWHey!
First of all, we can assure you that we haven't been deleting any comments. The only comments that get deleted from our videos are things like obvious spam and malicious links. We encourage people to ask us questions about our results because we always want to make sure we're trying to deliver the best information we can.
As far as your comment goes, other 8k TVs we've tested performed similarly and we would actually expect this behavior. It can also depend on the size of the screen and test pattern used as well. For example, a 75" TV with a large test pattern and mini LED backlight will help it score better in a test like this. It's likely that our results are not comparable to Keep it Classy Tech because of the panel we got and the difference in our testing methods.
Also, We don't test contrast in HDR and we only test the setting that is the most accurate, not what necessarily has the best contrast ratio (although they are usually correlated).
Using your example with Stop the FOMO, he had a panel that had a 1058:1 contrast ratio and turning on local dimming improved it by approximately 10x (~11000:1). Our unit with mediocre contrast (and still within expectation of what an IPS panel would have) of 638:1 compared to having local dimming on is, approximately 10x more (6534:1). The behavior is actually tracking well between the two and the difference is likely a combination between the panel we got and the difference in our testing methods.
Please let us know if you have any other questions!
En suite c'est avec ce contraste SDR, qu'il vont établir la note de
"HDR Movies" ainsi 23% de la note de CONTRASTE SDR sert à établir la note de
"HDR Movies":
Voilà comment est établie
"HDR Movies":
À partir de la on peut supposer que la note de Local dimming à elle aussi été établie en Source SDR, hors je ne pense pas que la gestion du Local Dimming soit la même en source SDR qu'en source HDR, hors la note de Local Dimming rentre pour 15% de la note de
"HDR Movies".
Je préfère l'évaluation du taux de contrast fait par la chaine youtube
KEEP IT CLASSY TECHquand en Source HDR avec Local dimming sur bas on peut avoir une Luminance du noir à 0,044 Nits sur le LG 75QNED90 ça correspond à un noir parfait.
https://www.youtube.com/watch?v=pQuEMy9J17E Je ne suis pas le seul à ne plus croire Rtings dans leurs note, entre la note et les évaluations et une fois que tu achète le téléviseurs, ça ne correspond pas du tout à ce que tu vois en vrai.
