Bonjour, je lance le sujet car il ne semble pas que le sujet ait deja etait couvert ici.
HDFury prepare la sortie de 2 produits HDMI 2.1 avec VRR / ALLM
DrHDMI 8k https://hdfury.com/product/dr-hdmi-8k/
Vrroom 40Gbps https://hdfury.com/product/8k-vrroom-40gbps/
PASS: discord
8K Vrroom 40Gbps
Downscale, Passthru or Upscale VRR or ANY signal while extracting full audio from ANY HDMI source to feed ANY Audio sound system with the best possible audio formats!
WORLD’S FIRST VRR and HDMI 2.1 sound extractor that allows FULL AUDIO from ANY external HDMI source to ANY HDMI/ARC or eARC sound system.
State of the art HDMI 2.1 central that support ANY video and/or audio signal in existence today including VRR, DV, LLDV, HLG, HDR10+, DTS:X, ATMOS and more…
Vrroom allows ANY HDMI source (Blu-ray, UHD Blu-ray, media players, satellite receiver, game consoles, PCs, etc.) to be shown on ANY of the connected displays and ANY sources Full HDMI audio to be played on ANY AVR or sound system.
Features:
World First HDMI2.1 Matrix, Scaler, Splitter, Switcher with full audio extraction for VRR and any signals
Full Audio from ANY HDMI source/output (including VRR signal) to ANY HDMI or ARC/eARC sound system
Full Audio up to Atmos/TrueHD from any HDMI source/output to SONOS Arc or any eARC sound system
Work for ANY HDMI source to ANY HDMI, ARC or eARC sound system
Solve SONOS Arc and other lip sync issue when using external HDMI sources connected to eARC TV
HDMI 2.1 Full Audio/Video passthrough up to FRL5: 40Gbps/1200MHz (FRL6: 48Gbps/1500MHz under testing)
Upscale VRR and ANY signals 2K<>4K and 4K<>8K
Downscale ANY signals 8K<>4K and 4K<>2K
Finally allow DTS sound from source to your sound system even if your TV does not support it.
CEC control from TV at output to source at input
CEC volume control from source to eARC or HDMI sound system
CEC volume control from TV to eARC or HDMI sound system
ARC/eARC retrieval from TV ARC/eARC input to ANY HDMI/ARC or eARC sound system
Support for 1080p120, 1440p120 and 4K120 as well as any VRR signals (Xbox series X, PS5, GPU and others)
Allow DV content playback from LLDV capable source on any HDR10 display for improved picture quality
HDMI2.1 Audio/Video output has a downscaler for improved picture quality on 1080p/2K or 2160p/4K TV
Allow HDCP 2.3 > 1.4 Conversion
Perform Chroma, Color space and Color depth modification if needed
Increase or decrease nits value of HDR metadata in real-time during HDR playback
Live signal info and details on Webserver, APP, OSD or OLED
4 buttons for OLED menu navigation
Relay Port (for automation)
RS232 jack connector (for integration and control, not needed for the average user)
Specs:
HDMI revision: HDMI 2.1 FRL5(1200Mcsc – 40Gbps) + FRL6 is under testing
Vrroom Support: 1200MHz/40Gbps VRR, QMS, QFT, DSC1.2a, HDR10+, HDR, HLG, DV & LLDV, ARC, eARC, ALLM, IMAX
Max Resolution: 4K120 4:4:4 8b, 4K120 4:2:2 12b, 4K120 RGB 10b VRR/HDR, 8K60 422 12b or 8K60 4:4:4 8b
TOTAL I/O: 4 HDMI In, 2 HDMI Out, 1 HDMI eARC Out, 1 HDMI Audio Out, 1 RS232, 1 RJ45, 2 IR, 1 12V Control, 1 Analog Jack & Optical Out.
Pass & Upscale TX0 port: 4K<>8K and FHD 1080p & 2K VRR to UHD 2160p & 4K/DCI VRR
Pass & Downscale TX1 port: 8K<>4K and UHD 2160p & 4K/DCI to FHD 1080p & 2K/DCI
Full HDMI Audio port: Full HDMI/ARC/eARC Audio extraction via 720p/1080p self generated stream to feed any AVR input
Full Audio eARC port: Full Audio up to Atmos over TrueHD from HDMI source at input to eARC sound system such as SONOS Arc
TMDS Switching: Autoswitch support for ATV4K, X1X and others sources continuously sending +5V
Signal Conversion: Resolution, Chroma Subsampling, Color Space, Color Depth, HDCP
HDCP Conversion: Any HDCP to any HDCP with CST1 support
Operating Modes: 40Gbps Matrix, Scaler, Splitter & Switcher with CEC, eARC, ARC and EDID management
Special Modes: CEC Command, HTPC, Disable or replace HDR/HLG, RS232 Macro, DV/LLDV to HDR10 display, Boost HDR nits value, Translate HLG>HDR, HDMI Doctor
EDID Modes: 13 EDID Flags, 5 EDID Algo, 100 EDID Banks (10 custom) + optional LLDV datablock
Control Modes: HDfury Webserver, IR, IP, RS232 for Linux/MAC/Win or push buttons via OLED
Output Control: Fully disconnect any output via software when not in use.
On Screen Display: ON/OFF/timer with choice of text color + Editable custom text and mask. (cover TV channel logo)
OLED: 3.12″ Diagonal, 256×64, 16 blue colors
Vrroom Size: 4.5″L x 7.3″W x 0.9″H – in CM: 11.5 x 18.5 x 2.4
Vrroom Weight: 520g – 1.15 LBS
Input Lag: <1ms (nanoseconds count)
Other info: 3D Support, CEC Pass Through, DSD, eARC (HDMI2.1)
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Den92, Ettore et 23 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Nouveaux produits HDFury HDMI 2.1 1200Mhz 4k 120Hz / 8k 60Hz
- dfx
- Inscription Forum: 28 Jan 2018 22:39
Ce produit reprend donc l'essentiel des fonctionalites du vertex2 18Gbps avec un support complet 4k 120Hz avec ALLM/VRR (xbox series, ps5) et 8k jusqu'a 60Hz.
Autre nouveauté interessante: il ajoute un second port audio compatible eArc pour les barres de son n'ayant qu'un seul port HDMI (comme les barres Sonos ARC/Beam...).
Il y a donc 4 ports HDMI en sortie au total ce qui permet de brancher une barre de son ainsi qu'un preamp/receiver.
Il devrait etre disponible au plus tard en nov. de cette année.
- dfx
De la bombe... Je possède un HDFury Diva dont je suis enchanté.
- Marsupio
- Inscription Forum: 28 Juil 2002 13:26
Marsupio a écrit:De la bombe... Je possède un HDFury Diva dont je suis enchanté.
Hello marsupio,
Oui cela fonctionne plutôt bien apres cela n'est pas parfait non plus.
J'ai pre-commande le vertex 3 aka vrroom en previsions de l'avenir, cela va aussi m'assurer 3 "entrees" pour source vers mon lumagen et vu la penurie de composants, les 1000 premieres commandes sont assurées d'ici septembre pour la suite, espérons que la situation mondiale redevienne normale.
Bien a toi,
- dfx
Oui j'ai quelques bugs des fois sur mon Diva (obligé de rebooter) mais franchement y a pas d'équivalent et je trouve que le produit est quand même unique... Je serai également acheteur du Vroom pour anticiper pour l'avenir.
- Marsupio
dfx a écrit:Ce produit reprend donc l'essentiel des fonctionalites du vertex2 18Gbps avec un support complet 4k 120Hz avec ALLM/VRR (xbox series, ps5) et 8k jusqu'a 60Hz.
Merci pour ces infos. Cela signifie-t-il que ce produit, en plus du Dolby vision via LLDV, (comme déjà possible avec le Vertex 2) permettrait théoriquement d'afficher des jeux PS5 ou Xbox Series X en 4K@120Hz sur un projo type Sony VPL-VW590ES, alors que ce dernier n'a que des ports HDMI 2.0 et en est en principe incapable?
Pardonnez cette question de néophyte, mais je ne comprends pas tout à ce que permettent ces HD Fury...
- Outini
- Inscription Forum: 02 Avr 2003 12:41
Outini a écrit:dfx a écrit:Ce produit reprend donc l'essentiel des fonctionalites du vertex2 18Gbps avec un support complet 4k 120Hz avec ALLM/VRR (xbox series, ps5) et 8k jusqu'a 60Hz.
Je doute que le 590es supporte du 4k a 120Hz mais sinon oui pour les devices qui ont un hardware pouvant le supporter mais un EDID qui ne l'annonce pas, typiquement la serie OLED LG 9 oui ils travaillent dessus.
- dfx
Merci pour la news
Y aura t il un DTM à terme ?
Car à mon avis c'est une suite logique sur un boitier comme les HDFury
jacko a écrit:Merci pour la news
J'aimerai bien mais le vertex 3 aka vrroom ne sera pas en mesure d'effectuer des traitements videos hormis l'upscaling/downscaling 2k <> 4k <> 8k (dans les 2 sens). Certainement une limitation des ASIC utilisés.
Pas de 5k ou autre format (ca aussi j'aimerai bien, tout comme plus de mires pour la calibration).
En fait c'est un splitter/matrice qui se "contente" de regler les nombreux problèmes HDMI EDID, (e)ARC + extraction audio.
Eventuellement via un maj FW, un sous système CEC permettra de manipuler ce dernier (Oppo, je regarde vers toi).
Il ajoute une sortie audio compatible (e)ARC (reprenant donc les fonctionalites de l'Arcana) et surtout les ports "videos" sont "future proof pour longtemps" supportant le FRL5 soit 4k120/8k60 (aka 40Gbps et pourraient etre FRL6 48Gbps a l'avenir mais il n'existe aucune source pour le valider a ce jour).
Le successeur de la Diva (dont l'un des ports video est limite au 1080p) aura lui un FPGA (qui sert dans le produit actuel pour l'ambilight et conversion HDR -> SDR sur le port video 1080p). Il devrait donc permettre des traitements videos et je paris que HDfury aura a coeur d'ameliorer significativement la solution Diva existante.
Malheureusement il ne sortira probablement pas avant 2 ans pour des raisons de couts qui ne permettraient pas de commercialiser un produit a $400.
L'avenir nous dira ce qu'il sera capable de faire.
Pour le moment, un bon DTM reste (et pour quelques mois encore) a aller chercher chez Lumagen (Radiance Pro)
Si cela t'interesse, demo du proto 4k 120Hz avec eARC vers Sonos ARC https://streamable.com/9z160v
- dfx
Un produit prometteur !
bonjour
Je post ce message car je subit des pertes de synchronisation d'image sur mon vidéo projecteur
ma config
Zappiti pro 4k HDR
Zidoo / (et pourquoi pas Shield en remplacement) >>>> Ampli Onkyo >>>>> TV Q950 (hdmi 1) et Projo optoma UHZ 65 LV (hdmi 2)
LG BD 4k
mon soucis est que le boitier déporte de ma Tv renvoie un signal erroné sur le HDMI , et de ce fait mon nouveau projo tout comme mon ancien projo n'arrivent et n'arrivaient pas à synchronise le signal video en sortie d'ampli .. 5 seconde d'image et perte de synchro .. sans cesse
J'ai même croisé les deux sorties afin de voir si cela venait de l'ampli , ou du cable .. idem >>> par contre quand je désactive la sortie allant vers la TV , là plus de perte d'image sur la projo ... donc le soucis ne vient ni du cable, ni de l ampli , ..
sur un post j'avais pu lire une fois que le ou les boitiers HD fury VERTEX 2 ou sont successeur / VRROOM pouvaient peut être solutionner mon soucis en stoppant le signal retour de l HDMI ...
d autre que moi ayant une TV samsung avec un boitier deporté + un projo ont ils les mêmes soucis que moi. (comme si le boitier déporté de la TV restait tout le temps allume même en veille) . J'ai cru lire que le boitier Fury avait une fonction de detection d'appareil reellement en veille empechant de ce fait un retour de signal HDMI inutile et pernicieux
cdlt à vous en attendant vos conseils.
beepbeep
ma config
Zappiti pro 4k HDR
LG BD 4k
beepbeep
- beepbeep5372
- Inscription Forum: 21 Sep 2004 8:59
salut
je lis cela sur le vertex 2 par exemple
achat-scalers/hdfury-vertex-2-t30115902.html
State of the art HDMI central with exclusive output management to accomodate Android TV and similar sink devices doing check while in standby mode.
traduction
Centrale HDMI à la pointe de la technologie avec gestion de sortie exclusive pour s'adapter à Android TV et appareils similaires effectuant des vérifications en mode veille.
cela veut il dire que ce type de boitier shunt le retour d'infos du signal HDMI ( que l'appareil " diffuseur est en veille) >> si j'interprète , cela voudrait dire que le boitier Fury Vertex coupe le signal retour des appareils Android / TIZEN style TV SASMUNG CONNECTEE .. afin de ne pas parasité le signal HDMI .
Donc pour moi , cela donnerait la bonne infos à l'ampli comme quoi la TV sur HDMI 1 est bien eteinte ou pas de retour HDMI >> donc le signal allant vers le OUT HDMI 2 de l'ampli ne se verrait pas pollué par le signal erroné de la TV en veille ?
SUIS-JE dans le bon ? ou est ce que j'interprete mal ?
cdlt
beepbeep
traduction
cdlt
beepbeep
- beepbeep5372
Bonsoir à tous,
Le VRROOM ne semble pas precommandable depuis le shop-eu de HDFury
Du coup, si preco sur le shop-us, quid des frais de douane vers la France?
- neosqual
- Inscription Forum: 04 Juil 2006 14:05
neosqual a écrit:Bonsoir à tous,
Salut
Justement depuis le 01 / 07 / 21... La poste comme les autres j imagine demandent des frais de douanes pour tout ce qui arrive en France quelqu'un soit la valeur.
Dans mon cas commande sur Amazon. fr de deux câbles électrique... Valeur ttc 7€... Ne sachant aucunement que la cde venait directement de la Chine.. On me demande des frais de douanes...
Donc même pour 7€ en venant de l Asie... C est taxe.
Alors un Vrroom de 400 € ou dollars.. Ce sera taxe direct venant de l étranger
Cdlt
- beepbeep5372
Mouais...c'est bien ce que je me disais...et les frais sont composés (de mémoire) d'un montant forfaitaire de frais de dossiers + un pourcentage aux alentours de 20% du prix pour un produit de categorie high tech. Ca fait cher...
Du coup, pourquoi n'est il pas precommandable sur le store EU?
Seul le nouveau Arcana semble dispo a la vente pour 199e.
Je ne connais pas bien ce produit. Mon besoin est juste de splitter mon signal 4k60 via hdmi 2.1 venant de la PS5 vers mon installation type Ambilight qui ne comprend que le hdmi 2.0 en 1080p.
Le Arcana semble avoir 1 IN qui prend hdmi 2.1 et 2 OUT.
Mais puis-je gérer les EDID des sorties pour lui demander de splitter en 2 OUT avec 1 OUT en passthrough et 1 OUT downscalé en 1080?
Si oui, alors ca me suffira. Juste besoin de downscale du 4k en 1080p sur une deuxieme sortie splittée
Mais rare sont les boitiers gérant le hdmi 2.1 pour ce genre d'opération...
- neosqual
Retourner vers Processeurs Vidéo
