Combien de casques un peu difficiles ont retrouvé tout leur allant et leur équilibre grâce au RME ADI-2 DAC.
Sinon, rappel d'un amplificateur déjà cité sur ce fil au sujet duquel il serait très intéressant d'en savoir un peu plus : https://www.sono-audio-pro.com/fr/ampli ... e-24v.html
Bonne journée.
58 messages • Accèder à une page • 1, 2, 3, 4
Modérateurs: Modération Forum Univers Casques, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 8 invités
Quel ampli casque pour mon nouvel orthoplanar?
- ajr
Sennheiser HD 4.50 BTNC
In terms of sound, they are good, well balanced and clean. The ANC is also good for the price. However, they are not very comfortable, and every single head movement tends to break the seal between the cushions and your head, which as you would imagine is quite disturbing as it lets a lot of outside noice in. Also, theres this weird thumping of your footsteps when you walk, this is to do with the ANC, almost all ANC headphones have this... the only pairs which dont have this issue are beats studio 3, sony ch700n and the XM series. The HD 4.50 also do not go very loudreversephonelookup.onl/ curated.onl/nba-reddit/ pcbuilder.onl/pcpartpicker/.
I would definitely recommend the sony ch700n for that price. They all round better. They go very loud, the ANC does not make that annoying thumping with every step you take, and they sound very clean with punchy bass. The seal of the cushions is not perfect but better than the Hd 4.50, and they are also far more comfortable.
If you are willing to spend a bit more, then definitely get yourself the Sony 1000XM2. They are regularly on sale not that the XM3 are out, and are still the 2nd best ANC headphones I’ve owned, and I’ve owned pretty much every top end ANC headphones at some point. And if you wanna have the best possible ANC headphones money can buy, the XM3 are a no brainer.
Hope that helps.
Hope that helps.
- Charlis
- Inscription Forum: 05 Fév 2020 6:28
Bonjour Charlis et bienvenue sur le forum HCFR,
Bien que hors sujet, merci pour cette contribution.
Bonne journée.
Bonne journée.
- ajr
bonsoir
je suis à la recherche d'un ampli hyper dynamique pour conduire mon verum one et cela à moindre cout
merci pour vos conseils
- FLORILEGE
- Inscription Forum: 18 Fév 2021 11:37
FLORILEGE a écrit:bonsoir
hyper dynamique ?
puissant ,timbré, dynamique , et comparé à des amplis à + x000 euros, le
https://www.audiophonics.fr/fr/amplific ... 14573.html
j'en ai eu des amplis, mais celui là , sans considération de prix c'est juste enorme , connectique, versatilité (il tient avec honneur tous mes casques), puissant (trop ? jamais plus de 10 h en mode bas gain) ,et bien sur prix, car là on frole l'indéscence vis à vis de la concurrence
sinon un lake people G3 mais c'est sans comparaison possible selon moi
- glamsam
- Inscription Forum: 13 Juin 2007 20:37
Bien vu Laurent,
le RQP parait exceptionnel !
La musique avant tout.
renecito - Contributeur HCFR & Modérateur HiFi et Univers Casques
- Inscription Forum: 28 Juin 2011 14:42
renecito a écrit:Bien vu Laurent,
sur qu'il te plairait celui là René , toi qui aime les belles choses au bon prix ,je connais un gars sur TN qui l'a aussi et qui a le meme constat que moi, cet ampli drive des casques à + 2xxx euros sans rougir face à la concurrence
- glamsam
Il est également vendu chez AliExpress sous la marque WEILIANG modèle E600 avec trois versions sur le changement de l'AOP d'entrée :
https://fr.aliexpress.com/item/33040446809.html?spm=a2g0w.12057483.detail.3.1922218fuf2sGM
Version 1: JRC 5532DD.
Prix : 75,66 €
Version 2: MUSES 8920.
Prix : 83,71 €
Version 3: MUSES 02.
Prix : 105.45 €
Il faut rajouter 23 € de frais d'expédition
N.B. La version Audiophonics correspond à la version 2
Prix : 75,66 €
Prix : 83,71 €
Prix : 105.45 €
renecito a écrit:Il est également vendu chez AliExpress sous la marque WEILIANG modèle E600 avec trois versions sur le changement de l'AOP d'entrée :
Prix : 75,66 €
Prix : 83,71 €
Prix : 105.45 €
je sais,eux au moins montre l'intérieur et explique tout sur les composants utilisés ,le prendre chez audioph permet de s'assurer d'une garantie fiable en cas de soucis, en tout cas cela fait reflechir sur le prix des amplis ....meme constat avec mes deux dacs ,un à 250 prix neuf ,l'autre à +800 euros , et je préfére ....devinez lequel ?
- glamsam
merci beaucoup pour vos réponses!
c'est super!il vaut mieux dix qui trouvent plutôt qu'un qui pédale dans semoule...
- FLORILEGE
il me semble que les amplis op sont montés sur un boitier ce qui permet de bidouiller ces derniers si je ne m'abuse....
- FLORILEGE
d'ailleurs, ils devraient faire cela pour les condos, les résistances, les transistors, les transformateurs et l'on pourrait tout bidouiller ........ intuitivement !
58 messages
• Page 4 sur 4 • 1, 2, 3, 4
Retourner vers Amplificateurs Casques
