Coco68 a écrit:Kodi 19 s’est installé tout seul chez moi.
Attention car pas de son en bitstream après cela,il faut modifier par raw dans le paramètre passtrought.
Je suis en IEC et j'ai toujours du passthrough bitstream.
D'après les forums sur KODI, le RAW n'est pas terrible et est 99% moins bien que le mode IEC...
"Above is written: Android does everything. We just give it the "raw" audio bits (forceraw). It packs it by itself and sends it out. In ForceRAW version, the IEC packing step happens by the Android system without any influence by us. So the DD+ you see does not necessarily have to be the maxbitrate you send in. But as most users only believe quality is good when they see a green light or DD+ on their AVR, etc. - just ignore it
![:-)](https://www.homecinema-fr.com/forum/images/smilies/icon_smile.gif)
If kodi is in IEC mode (which is the default, cause Android's packer has a lot of disadvanteges (no 44.1 dts support, etc.) kodi takes the RAW packets and adds them into IEC frames and only after that sends them out to Android. Our IEC packer supports much more formats than the Android packer, especially there are big disadvantages in Android's DTS (nothing besides 48 khz works), there are disadvantages in DD+ as nothing besides 5.1 DD+ with lower bitrate works and so on.
Edit: I clarified some things by giving examples and also stated why "I see DD+" and hope it's 1:1 passthrough is not true."
