Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Balin, franckprovost83, graftik, kristov, Pasquale, youloulou et 201 invités
Nuprime Omnia A300
Message » 23 Fév 2021 22:47
La mode des amplis tout en un continue avec le Nuprime Omnia A300. Bien que moins cher (un peu moins de 1500 euros) que ses concurrents de chez nad ou lyngdorf, il lui manque la possibilité d'effectuer une correction acoustique.
https://nuprimeaudio.com/product/omnia- ... aedd0e4327
SPECIFICATIONS
Amplifier
Power: 150W @ 8 ohms; 200W @ 4 ohms (both channels driven)
THD:
<0.02% (AUX IN, 1W, @ 8 & 4 ohms)
<0.01% (OPT IN, 1W, @ 8 & 4 ohms)
Signal-to-Noise Ratio: >95 dB (Digital input, 10W out @ 8 ohms)
Clipping Power: >230W (1kHz @ 4 ohms, both channels driven)
Frequency Response: +0.6 dB/-1dB (12 Hz – 22 kHz)
Channel Separation: >85dB (1 kHz AUX); >105 dB (10 kHz Digital)
Input Sensitivity:
0.85V (AUX & OPT) for 100W @ 8 ohms
0.75V (AUX & OPT) for 100W @ 4 ohms
Standby Power: <0.5W
DAC & Wireless
Bit Depths: 16-32 bit
Streaming Audio Processing Engine: up to 192KHz / 24-bit
IIS/DSD HDMI Input: PCM up to 768KHz/32Bit and DSD up to DSD256
USB PCM/DSD Input: PCM up to 384kHz/32Bit and DSD up to DSD256
Optical S/PDIF Input: PCM up to 192KHz and supporting DoP format DSD64
Optical, Coaxial and analog Pre-Out
MQA*
Bluetooth: Two-Way (Receive and Headphone modes)
Network Connectivity: Gigabit Ethernet RJ45, 802.11 b/g/n Wi-Fi
Streaming Services: Amazon Music, Deezer, iHeartRadio, Qobuz, QQ Music, Spotify, TIDAL, TuneIn, Napster, Ximalaya
Dimension and Weight
Product Dimensions (W x H x D): 280 x 55 x 250 mm (includes feet and extended rear panel terminals)
Product Weight: 3 kg (6.6 lbs.)
Package Dimensions (W x H x D): 440 x 100 x 340 mm
Shipping Weight: 5 kg (11 lbs.)
vindermere
Modérateur Installations
Inscription Forum: 06 Déc 2006 19:26
Message » 25 Fév 2021 16:01
C'est quoi comme techno d'amplification ? (J'ai la flemme de chercher...).
Effectivement avec un DSP room correction et 2 ou 3 entrées numériques en plus et c'est le score parfait !
autrichon gris
Inscription Forum: 21 Oct 2009 14:18
Message » 25 Fév 2021 16:48
Classe D mais pas aucun détail sur le module employé. Voici ce qu'on peut lire sur leur site :
A combination of high-power Class-D amplifier, 64-bit quad-core Arm Cortex-A53 processor, NuPrime proprietary SRC chip, Cirrus Logic CS43131 DAC, plus other audiophile-grade components enable the Omnia A300 to achieve world class performance above its peers.
vindermere
Message » 25 Fév 2021 17:25
Effectivement peu clair, mais on sait depuis Nuforce que Jason Lim est plutot bon dans la création de modules de classe D.
autrichon gris
Message » 12 Avr 2021 11:28
https://www.qobuz.com/fr-fr/info/Hi-Fi/ ... mpli184192
Un banc d'essai dudit chez Qobuz. Peu d'infos sur les modules d'amplification...
autrichon gris
