![Image](https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fwww.nuprimeaudio.cl%2Fwp-content%2Fuploads%2F2020%2F12%2FA300_front_angle-800x400.jpg&f=1&nofb=1)
![Image](https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fwww.on-mag.fr%2Fimages%2Fstories%2F2021%2F01%2FNuPrime_Omnia_A300_01.jpeg&f=1&nofb=1)
https://nuprimeaudio.com/product/omnia- ... aedd0e4327
SPECIFICATIONS
Amplifier
Power: 150W @ 8 ohms; 200W @ 4 ohms (both channels driven)
THD:
<0.02% (AUX IN, 1W, @ 8 & 4 ohms)
<0.01% (OPT IN, 1W, @ 8 & 4 ohms)
Signal-to-Noise Ratio: >95 dB (Digital input, 10W out @ 8 ohms)
Clipping Power: >230W (1kHz @ 4 ohms, both channels driven)
Frequency Response: +0.6 dB/-1dB (12 Hz – 22 kHz)
Channel Separation: >85dB (1 kHz AUX); >105 dB (10 kHz Digital)
Input Sensitivity:
0.85V (AUX & OPT) for 100W @ 8 ohms
0.75V (AUX & OPT) for 100W @ 4 ohms
Standby Power: <0.5W
DAC & Wireless
Bit Depths: 16-32 bit
Streaming Audio Processing Engine: up to 192KHz / 24-bit
IIS/DSD HDMI Input: PCM up to 768KHz/32Bit and DSD up to DSD256
USB PCM/DSD Input: PCM up to 384kHz/32Bit and DSD up to DSD256
Optical S/PDIF Input: PCM up to 192KHz and supporting DoP format DSD64
Optical, Coaxial and analog Pre-Out
MQA*
Bluetooth: Two-Way (Receive and Headphone modes)
Network Connectivity: Gigabit Ethernet RJ45, 802.11 b/g/n Wi-Fi
Streaming Services: Amazon Music, Deezer, iHeartRadio, Qobuz, QQ Music, Spotify, TIDAL, TuneIn, Napster, Ximalaya
Dimension and Weight
Product Dimensions (W x H x D): 280 x 55 x 250 mm (includes feet and extended rear panel terminals)
Product Weight: 3 kg (6.6 lbs.)
Package Dimensions (W x H x D): 440 x 100 x 340 mm
Shipping Weight: 5 kg (11 lbs.)
