- du Dolby Vision sur un écran HDR10
- d'une émulation de Dolby Vision sur un écran HDR10, à partir de n'importe quoi (SDR inclus)
https://www.hdfury.com/enjoy-dynamic-dv ... 0-display/
Lire l'article pour la théorie et les témoignages.
Voici les données utiles à la fin :
While all newer sources are all capable to output DV and LLDV, some olders ones might be limited to DV, below is a current list of sources capable to output LLDV.
List of sources capable of LLDV output for any DV content:
– Sony Players (UBP-X700, UBP-X800/M2, UBP-X1100ES …)
– Apple TV 4K
– Shield Pro
– Xbox One X/S
– Panasonic UB820/UB9000
– Oppo 203/205
– Fire Stick/Fire Cube (Netflix/ATV App)
– Chromecast (Netflix)
List of sources capable of LLDV output for DV, HDR10 and SDR content:
– Oppo203/205
– Apple TV 4K
– Sony UBP-X700, UBP-X800/M2
This method can be performed on any HDR10 display using Vertex2/Diva or Maestro. If you own a JVC PJ with custom gamma curve or if you have a PJ that can be manually forced in HDR mode, then you can perform this method using Vertex1, Integral2 and Linker as well.
To get started, we recommend reading both linked threads at the beginning of this post as well as the following guide:
https://www.avsforum.com/forum/86-ultra-hi-end-ht-gear-20-000/2941614-official-sony-vw885es-vw760es-owner-s-thread-212.html#post59355210
Thanx to power user Claw from AVSforum who posted the below info and links:
Options are listed in introduction date order. They are useful to those that don’t want to create their own custom LLDV EDID or create their own color profile in their display device. Don’t mix and match them.
1 – Custom Sony A1 LLDV EDID 5 in combination with Dominic’s A1 custom color profile for JVC. This was the first solution that reduced the red tint we saw when using the A1 LLDV EDID 5. JVC projectors only.
JVC custom A1 color profile download Link:
https://www.avsforum.com/forum/attachme ... 1581466297
Procedure for loading JVC custom color profile:
https://www3.jvckenwood.com/english/dow ... _v1_00.pdf
2 – Mark’s custom BT2020 EDID in combination with BT2020 color profile in any display. This is a good option for those that don’t want to mess with color profiles in your display. Every HDR display should include a BT2020 color proflle.
Custom BT2020 EDID download Link:
https://www.avsforum.com/forum/attachme ... 1581851932
3 – Diva/Vertex2/Maestro Automix mode default DV data block with DCI-P3 primaries combined with a DCI-P3 color profile. This option provides the capability to customize the DV data block field values from the defaults if you have one of the new HDfury devices.
Manni’s JVC-only custom DCI-P3 color profile download link for JVC models that don’t have a built-in DCI-P3 profile:
https://www.avsforum.com/forum/attachme ... 1506168265
4 – Mark’s custom DCI-P3 EDID in combination with a DCI-P3 color profile. This is a good option for those who have an older HDfury device but want to use a DCI-P3 color profile.
Download link:
https://www.avsforum.com/forum/attachme ... 1584451347
Our dev team added a whole new DV section on Vertex2/Diva and Maestro that allow to decipher DV metadata, decode DV datablock and create your own DV Datablock
Ajout du 23/09/2022
1) encore moins cher pour se lancer dans le process : le Dr HDMI 4K, 90€ !
2) pour modifier ses Edid soi-même :
post181000009.html#p181000009
Le moins cher des modèles configurables et automatiques est l'Arcana. C'est aussi le plus simple et avec uniquement les 3 paramètres essentiels.
Assez intéressant, le manuel du HdFury Arcana sur le lldv (à partir de la page 33) :
https://www.hdfury.com/docs/HDfuryArcana.pdf
C'est en anglais, mais c'est assez synthétique sur le fonctionnement des options disponibles sur un HdFury
11 Edid de base avec des nits différents ! (variations sur le 2 – Mark’s custom BT2020 EDID), de 100 à 10000
post180903819.html#p180903819
Encore une nouvelle série d'Edid, de 200 à 1000 cette fois, grâce à BangoO !
post180927261.html#p180927261
Edid préréglés supplémentaires! Un peu plus tordus avec des compatibilités HDR10+ par exemple
http://forum.zidoo.tv/index.php?threads ... ted.86856/
Ajout du 23/01/2022 - procédure complète Sony x90 - Version du 11/06/2022
Bangoo a donné la procédure détaillé pour les Sony x90 (et c'est
![:bravo: :bravo:](https://www.homecinema-fr.com/forum/images/smilies/thumbs_up.gif)
post180944549.html#p180944549
Ajout du 11/02/2022 : réglages jvc n5/n7 - Version du 01/05/2022
thermique85 propose un guide pour les jvc n5/n7 :
post180922548.html#p180922548
