Quand on voit les modifications liées a la virtualisation, je me demande si on ne va pas avoir de probleme lors du transfert si des Vms et/ou Docker utilisent déjà des ressources matérielles....
Virtualization
libvirt updated to version 6.4.0
qemu updated to version 5.0.0
In addition, integrated changes to System Devices page by user @Skitals with modifications by user @ljm42. You can now select PCI devices to isolate from Linux upon boot simply by checking some boxes. This makes it easier to reserve those devices for assignment to VM's.
Note: If you had the VFIO-PCI Config plugin installed, you should remove it as that functionality is now built-in to Unraid OS 6.9. Refer also @ljm42's excellent guide.
In a future release we will include the NVIDIA and AMD GPU drivers natively into Unraid OS. The primary use case is to facilitate accelerated transcoding in docker containers. For this we require Linux to detect and auto-install the appropriate driver. However, in order to reliably pass through an NVIDIA or AMD GPU to a VM, it's necessary to prevent Linux from auto-installing a GPU driver for those devices upon boot, which can be easily done now through System Devices page. Users passing GPU's to VM's are encouraged to set this up now.
