Type : Préamplificateur
Marque : Gryphon
Modèle et options : Athena avec option phono mm/mc
Prix de vente : 5600€......5500€
Département où la marchandise est visible : 91
État de la marchandise : parfait
Prix neuf : 13800€
Facture disponible : oui
Date, pays et lieu d'achat : Paris 2015
Numéro de série : sur demande
Documentations conservées : aussi
Description générale : très bon état, voire état neuf
Gryphon Athena :
- True Dual Mono configuration
- Pure Class A operation
- 63,000 microFarad capacity
- Ultra-wideband 3 MHz frequency response
- Zero negative feedback
- DC-coupling with servo-control
- Isolated power supply for non-audio circuits
- Extensive mechanical decoupling
- Extensive local voltage regulation
- Microprocessor-controlled 50-step relay volume attenuator for best sonic performance featuring Vishay Bulk Metal Foil ultra-precision resistors and ultra low capacitance relays
- Fully discrete circuitry using Ultra-short signal path
- Select premium-grade components
- Minimal internal wiring
- Military spec. double-sided up to 70µm copper printed circuit boards
- Two separate Holmgren toroidal transformers, one for each channelGold-plated input-isolating relays
- PCB-mounted sockets eliminate wiring and shorten signal path
- Gold-plated PCB-mounted Swiss Neutric XLR sockets for three balanced sources and two outputs
- Gold-plated PCB-mounted phono sockets with Teflon insulation for 2 inputs and one Tape output
- Wireless communication between Mirage Control unit and Mirage Preamplifier
- Fixed-level AV throughput for uncompromising integration with surround systems
- Microprocessor-controlled menu functions
- Adjustable channel balance, source level matching, start-up and maximum level
- Green Bias control for Gryphon Power Amplifiers
- Vacuum Fluorescent Display with 2 lines and 50 characters
- Adjustable display Lighting (High, Medium, Low or Off)
- Non-magnetic, non-resonant aluminum cabinets
- AMX or Crestron home automation System control software (sold separately)
- 12VDC link input and output
- Flash memory upgrades via PC or key-fob
- Infrared remote control
- EU CE approval
- Designed and built in Denmark
Site web du constructeur : https://gryphon-audio.dk/
6 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 9 invités
bonsoir,possible un échange contre un streamer.
- domaud
- Inscription Forum: 06 Juin 2011 23:35
6 messages
