Modérateurs: Modération Forum Univers Casques, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
FiiO.
lien ON mag ne fonctionne pas, juste l'image !
pas donné tout de même , le prix d'un smartphone THDG!
Nono - Membre HCFR
- ajr
![:roll:](https://www.homecinema-fr.com/forum/images/smilies/icon_rolleyes.gif)
![:oops:](https://www.homecinema-fr.com/forum/images/smilies/icon_redface.gif)
En tout cas le M15 sera un bon appareil que je vais m'empresser d'écouter dès sa disponibilité!
![:hein: :hein:](https://www.homecinema-fr.com/forum/images/smilies/heink.gif)
alfachris - Membre HCFR
- Inscription Forum: 12 Aoû 2003 21:36
Pour info, FiiO a abandonné l'idée de faire un M15 Pro.
James Chung, FiiO CEO a écrit: Market Information for Unreleased New Products
M15, the grand product of the year and flagship player of FiiO, it will be available for ordering in Jan.
For the M15Pro, here is our unified reply:
At present, we have clearly given up all the plans of M15Pro, because several original plans were rejected by our users who are helping us test the undeveloped devices. The original plans included:
1. Plan A: Replacing the Aluminium Alloy chassis with one made of Copper with the possible upgrading of select components to further enhance the M15. The reason for the rejection was that our users felt it lacks sincerity.
2 Plan B: Changing the AMP to THX AAA-78. It was also rejected by our users for that the power will be much lower than M15.
3. Plan C: Many people expect to change to the THX amplifier, but if we want to use THX 788, the output power will be more than 2 times larger than the M15 since it is for desktop computers. Thus small changes based on the existing M15 can't accommodate. If there is a major change, what will it be? What are the design goals? What are the target customers? How much will it cost? Therefore, it is necessary to re-plan. Even if we decide to release, there will still have a lot of uncertainties and it is a long way to go, so we need to reconsider.
The whole project of M15 Pro is terminated now.
- roland_de_lassus
Bonjour, je viens d'acquérir un Fiio M11. Dans la notice il est dit qu'une protection a été appliquée d'usine sur l'écran. Cella signifie que si celle-ci est rayée ou peut l'enlever et y mettre une autre protection ou il s'agit simplement d'un traitement X appliqué sur la surface de l'écran ?
S'il ne s'agit que d'un traitement X je vais lui commandé une protection d'écran en bonne et dûe forme, comme je le fais avec mon mobile.
hamster - Membre HCFR
- Inscription Forum: 21 Avr 2007 19:27
bonjour ,
ou alors comme sur les smartphones , un traitement du verre gorilla glass 5 ou 6![:wtf: :wtf:](https://www.homecinema-fr.com/forum/images/smilies/confused.gif)
Nono - Membre HCFR
Il faut regarder de près le côté de l'écran, avec une loupe si besoin, pour voir s'il y a une "surcouche" avec par exemple un biseau.
Moi j'ai un X7 II et c'est une protection en verre qui est collée par dessus. J'avais d'ailleurs galéré pour en trouver une de remplacement, c'était plus dispo![:ko: :ko:](https://www.homecinema-fr.com/forum/images/smilies/nybbas.gif)
[Edit] sur le site officiel de Fiio, il est indiqué que c'est comme pour le mien: l'écran de protection en verre trempé est pré-appliqué en usine.
- ssebs
- Contributeur HCFR 2024
- Inscription Forum: 23 Nov 2014 22:30
On dirait bien qu'il y a une surcouche
Et comme casque fermé filaire passif, entre 200 et 400 euros vous me conseillez quoi qui irait bien avec le Fiio M11 ?
Après moult recherche, j'ai retenu :
1. Le Sony MDR-A1M2
2. Le Focal Listen ou Listen Pro
3. Le Meze 99 Classics ou Neo
1. Le Sony MDR-A1M2
vinc59700 a écrit:Merci pour cette réponse rapide !
Le Sony xm3 est compatible avec le codec LDAC (aptx et aptx-HD aussi d’ailleurs), mais il refuse d’être connecté en LDAC avec le FiiO M9. Je n’ai réussi qu’en sbc...
Bonjour je viens de faire l’acquisition du M9 ainsi que du WH-1000-X3 et j'arrive à le connecter en LDAC sans problème avec le M9.
Avez vous regardé du côté des réglages Bluetooth ?
Par contre dans les réglages Bluetooth chez moi ça marche en LDAC "classique" ou "priorité connexion stable". Par contre en "priorité qualité audio" j'ai des coupures alors que le dap est à 50 cm du casque...
des idées ?
- faramisso
- Inscription Forum: 13 Sep 2019 15:33
bonjour , je possede un fiio Q5S depuis quelques jours ( tout arrive
) ..... et vu mon niveau en démat , j'ai quelques questions .
je l'utilise avec abonnement qobuz en streaming .
et il possible selon vous d'utiliser uniquement le DAC du Q5S afin de le brancher sur mon ampli de salon ( Sansui AU999 ) afin de profiter de qobuz sur mes enceintes de temps en temps ?
merci![:wink:](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
![:mdr:](https://www.homecinema-fr.com/forum/images/smilies/icon_mrgreen.gif)
- kéké 26
- Inscription Forum: 03 Juin 2007 17:15
Bonjour Bernard,
C'est ce que je fais sur ma chaîne hifi principale en branchant un câble 3,5mm > RCA sur la sortie casque des DAP.
Ainsi que très rarement, en reliant un câble 3,5 > 3,5mm sur une radio GENEVA.
Bonne journée.
Bonne journée.
- ajr
Le Q5s a une sortie ligne (en haut à gauche de l'appareil): àmha, c'est celle-là qu'il faut utiliser, plutôt qu'une sortie casque variable — avec un câble mini jack 3.5 vers RCA (ça se trouve sur à-ma-zone entre 5 et 35€ selon le degré de certitude que l'on veut acquérir en même temps que le câble).
Cdlt![:wink:](https://www.homecinema-fr.com/forum/images/smilies/icon_wink.gif)
Cdlt
merci ..... bon j'ai reçu mon cable micro usb vers micro usb pour brancher mon samsung J3 au fiio Q5S ..... et le son ne sort que sur le haut parleur du samsung ... pas sur le Odin branché .... une idée ?????
- kéké 26
salut ,oui kéké ,possible, je faisais de même avec mon DAP AP100 ![:bravo: :bravo:](https://www.homecinema-fr.com/forum/images/smilies/thumbs_up.gif)
pas d'idée pour le moment !![:wtf: :wtf:](https://www.homecinema-fr.com/forum/images/smilies/confused.gif)
Nono - Membre HCFR
Ce qui est rare, j'ai utilisé mon Samsung Galaxy S7 comme baladeur avec le petit casque Koss KPH30i ce matin sans aucun problème. Si ce n'est qu'il faut appuyer sur OK lorsque le message de prudence apparaît afin de pouvoir ensuite augmenter le niveau sonore.
Je n'ai rien vu de particulier à faire dans les paramètres du Smartphone, si ce n'est qu'augmenter le niveau de - media- ?
En revenant sur la sortie ligne, je me suis rappelé qu'elle peut être également optique en ajoutant le Q5S à la page d'accueil.
Bonne journée.
Bonne journée.
- ajr
Retourner vers DAP et Amplificateurs Nomades |
