Modérateurs: Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: alcine, Atreillou, Ayrtonprost, Bavuong, Bedouille69-CX-Denon, Benben17000, blackadder68, blopper, cano, ChrisJohn, Cool-Spot, coucouse, dedo, Gary_35, gasgasrud, Google Adsense [Bot], JM JM, kara, kptaine, manimal95, manner, moi95, nriquo, octodurus, passager57, pkoka, Remind, Risel, skallan, sylvio50, ThunderBen, Tia38, toubeau, triangle22, tunlu, vdl1, Xtr3mCat et 248 invités
» 21 Nov 2019 14:18
Est-ce que la correction de l’effet mura supprime aussi le banding ?
![Avatar de l’utilisateur](./download/file.php?avatar=6390_1424341530.jpg)
Yoda
![Membre HCFR Membre HCFR](./images/ranks/membre2.gif)
- Inscription Forum: 22 Fév 2002 2:00
» 21 Nov 2019 15:05
Oui, en théorie.
" The most severe mura effects are horizontal or vertical lines or bands."https://patents.google.com/patent/US8160351"“Mura” defects are contrast-type defects, where one or more pixels is brighter or darker than surrounding pixels, when they should have uniform luminance. For example, when an intended flat region of color is displayed, various imperfections in the display components may result in undesirable modulations of the luminance. Mura defects may also be referred to as “Alluk” defects or generally non-uniformity distortions. Generically, such contrast-type defects may be identified as “blobs”, “bands”, “streaks”, etc. There are many stages in the manufacturing process that may result in mura defects on the display."https://patents.google.com/patent/US8049695"Substrate Color Mura appears as a series of colored bands when a typical prism film is illuminated from under its planar surface and is viewed through the display panel. The bands vary in color with viewing angle, and are the result of the dependence of optical retardation in the prism film substrate on both wavelength and observation angle, and the transmission of these bands through the prisms."https://patents.justia.com/patent/9329312
DanBa
- Contributeur HCFR 2024
![Contributeur HCFR 2024 Contributeur HCFR 2024](./images/ranks/contributeur.gif)
- Inscription Forum: 16 Oct 2007 17:46
Dolby Vision 12 bits en streaming ?
» 23 Nov 2019 13:24
Une présentation de Dolby Vision par Dolby : 12 bits par-ci, 12 bits par-là
http://www.mmsys2019.org/program/slides/walt-husak.pdfhttps://twitter.com/DanielBa78/status/1 ... 0074263552![Image](https://pbs.twimg.com/media/EKDTejvWwAMvv25?format=png)
![Image](https://pbs.twimg.com/media/EKDTej2WkAA9_5J?format=jpg)
Les images des films (des plus grands studios d’Hollywood) étant captées en 16 bits, idéalement le TV devrait recevoir un signal vidéo de 16 bits.
Mais les données en 16 bits sont trop volumineuses pour les divers traitements de la chaîne vidéo de bout en bout depuis la post-production jusqu’au TV : il faut les compresser.
En basant sur la courbe de Barten, Dolby propose une compression visuellement sans pertes en 12 bits PQ.
post179689144.html#p179689144http://www.plani.fr/wp-content/uploads/ ... ures-1.pdfhttps://wolfcrow.com/what-is-aces-acade ... ng-system/Les disques UHD Blu-ray Dolby Vision sont en 12 bits ou en 10 bits.
post180015830.html#p180015830https://www.avsforum.com/forum/465-high ... st58228308![Image](https://pbs.twimg.com/media/D9_hnb9XkAEIsF5.png)
Pour le moment, les services de streaming (Netflix, Disney+, Apple TV+, Amazon Prime Video, iTunes, …) ne diffusent que du Dolby Vision en 10 bits.
Pourtant, il existe un profil de streaming de Dolby Vision en 12 bits (Dual-Stream Dolby Vision) spécifié par DASH.
https://dashif-documents.azurewebsites. ... IF-IOP.pdf![Image](https://pbs.twimg.com/media/EKDTejzXsAAyye1?format=jpg)
Plus de bits, moins de bruits vidéo !
Le traitement vidéo interne des TV Sony HDG avec les dalles de 10 bits est effectué sur 14 bits.
post179688769.html#p179688769post179827239.html#p179827239http://www.sonyinsider.com/2009/09/03/t ... echnology/![Image](https://www.sonyinsider.com/wp-content/uploads/2009/09/img_01.gif)
"Tout traitement d'une image numérique entraîne une perte de données. Le traitement d'une image à une profondeur par couleur plus élevée (i.e. 12 bits ou plus), puis une réduction à la profondeur par couleur de la dalle (i.e. 10 bits) minimisent les pertes de données et permettent un affichage de qualité."
post179828746.html#p179828746
DanBa
» 27 Nov 2019 15:00
est ce qu'il est possible par une mise jour logiciel (et un choix de politique commerciale) qu'une TV SAMSUNG puisse avoir le Dolby Vision et une une TV SONY le HDR10+ ou pas possible lié un pb de puce ou autre..
j'ai pu lire ici que toutes les dalles SONY 10 bits ne sont pas de vrai 10 Bits mais 8 bites + FRC, la gamme XG9505 est t'elle avec un vrai dalle 10 bits ?
je m'arrache les cheveux en hésitant entre un SAMSUNG QE82Q70R et un SONY KD-85XG9505..
Je vous remercie de votre retour.
RIKO14
- Inscription Forum: 01 Sep 2017 13:17
» 27 Nov 2019 15:29
Super, merci !
et pour la question mise à jour DV / HDR10+ sur tv non équipée ?
RIKO14
» 27 Nov 2019 15:43
c'est faisable mais ils le feront pas,pour le DV c'est une question de licence et pour le HDR10+ c'est gratuit mais c'est une histoire entre marques !
lcdmen
» 29 Nov 2019 10:33
DanBa
» 29 Nov 2019 16:59
Hello
Savez-vous si le 65GZ1500E est compatible Dolby Vision MEL ou FEL.
Dans les deux cas, qu'est ce que je gagne/perd avec mes bluray 4K ?
J'ai un Panasonic UB820 comme lecteur. A priori compatible FEL celui la.
Mine-Antichar
- Inscription Forum: 01 Jan 2018 20:07
» 30 Nov 2019 11:31
De ce que j'ai lu, ton téléviseur Panasonic 65GZ1500 est compatible Dolby Vision MEL 10 bits et Dolby Vision FEL 12 bits comme tous les téléviseurs compatibles Dolby Vision actuels, car c’est le lecteur UHD Blu-ray qui décode le Dolby Vision.
A l’heure actuelle, il n’y a pas de Dolby Vision 12 bits en streaming.
post180101183.html#p180101183Mine-Antichar a écrit:Hello
En général, un disque Dolby Vision FEL 12 bits permet une meilleure qualité de rendu visuel.
post180015830.html#p180015830Mine-Antichar a écrit:J'ai un Panasonic UB820 comme lecteur. A priori compatible FEL celui la.
De ce que j'ai lu, tous les lecteurs UHD Blu-ray Dolby Vision peuvent lire les disques Dolby Vision FEL & Dolby Vision MEL.
Le Dolby Vision MEL 10 bits a été introduit pour permettre à plus de processeurs SoC d’être compatibles à Dolby Vision.
Ces processeurs, comme celui de la Xbox One S/X probablement, ne sont pas capables de décoder simultanément les deux flots vidéo : flot vidéo de la couche de base et flot vidéo de la couche additionnelle.
https://forum.avcesar.com/viewtopic.php ... 98#p221491Je ne sais pas si ton 65GZ1500 est capable de décoder simultanément les deux flots vidéo du Dolby Vision Dual Layer 12 bits au cas du Dolby Vision 12 bits en streaming dans un futur hypothétique, ou au cas de la lecture directe des fichiers Dolby Vision Dual Layer 12 bits.
post180090500.html#p180090500post180091691.html#p180091691
DanBa
