Et pourtant quelques recherches confirment ma théorie :
Setup
Since the tower speakers are self-powered, the XF-48 Home Theater System's setup may be a little unusual. I say "may" because you can feed the towers with line- or speaker-level signals. Theoretically, the XF-48 should do its best with a line-level connection, but I slightly preferred the sound with the speaker-level input.
Either way, the speaker is powered by its internal amplifiers. Read more at
https://www.soundandvision.com/content/ ... kqfXxQS.99Donc au pire si tu reste en 2.0, prends un SMSL AD18, et connecte le en optique. C'est compact et vu que la puissance ne compte pas car c'est l'ampli des Klipsch qui prend tout... pas la peine de mettre des milles et des cents.
