Modérateurs: Modération Forum Installations, Modération Forum Haute-Fidélité, Modération Forum Univers Casques, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
Audyssey MultEQ XT, XT32, PRO, Applet, MultEQ-X (màj)
Sur le site d’Audyssey:
« Audyssey Labs October 29, 2009 19:37
Movies are mixed in rooms calibrated for film reference. To achieve the same reference level in a home theater system each speaker level must be adjusted so that –30 dBFS band-limited (500 Hz – 2000 Hz) pink noise produces 75 dB sound pressure level at the listening position. A home theater system automatically calibrated by Audyssey MultEQ will play at reference level when the master volume control is set to the 0 dB position. At that level you can hear the mix at the same level the mixers heard it.
Audyssey Dynamic EQ is referenced to the standard film mix level. It makes adjustments to maintain the reference response and surround envelopment when the volume is turned down from 0 dB. However, film reference level is not always used in music or other non-film content. The Dynamic EQ Reference Level Offset provides three offsets from the film level reference (5 dB, 10 dB, and 15 dB) that can be selected when the mix level of the content is not within the standard.
0 dB (Film Ref): This is the default setting and should be used when listening to movies.
15 dB: Select this setting for pop/rock music or other program material that is mixed at very high listening levels and has a compressed dynamic range.
10 dB: Select this setting for jazz or other music that has a wider dynamic range. This setting should also be selected for TV content as that is usually mixed at 10 dB below film reference.
5 dB: Select this setting for content that has a very wide dynamic range, such as classical music. »
- ambolik
- Inscription Forum: 17 Sep 2018 16:41
Alors j'ai refait une calib, avec l'appli cette fois-ci, et c'est la précédente (directement avec l'ampli) qui avait du foirer...
Le niveaux pour les surrounds ont été abaissés de 7 dB
Pas étonnant qu'il y avait un tel déséquilibre
Ca va déjà bcp mieux maintenant, je trouve que le dyn EQ apporte qqchose, je préfère avec, mais même à présent ça booste tout de même un peu trop les surrounds...
J'ai mis à 10 dB pour que soit plus cohérent, mais à 0 dB, les surrounds sont encore un peu trop fortes je trouve (tests avec le Sound unbound callout en dts X).
Du coup c'est déconseillé de régler à 5 ou 10 pour un film...?
Comme dit précédemment, je fais des tests notamment avec des Démo DTS ou ATmos, notamment la Sound unbound callout dts, est-ce qu'il se pourrait que ça ne soit pas mixer au même niveau de référence qu'un film, mais plutôt à 10 dB par exemple (du coup ça serait cohérent...)
ambolik a écrit:0 dB (Film Ref): This is the default setting and should be used when listening to movies.
- souz2
- Inscription Forum: 09 Jan 2009 15:35
Normalement pour un film, le Dyn EQ se règle à 0.
- ambolik
Je te conseillerais surtout de voir ce que cela donne en regardant des films que tu connais bien.
Les démos c’est sympa mais cela reste des démos,ce sont des films qui tu vas majoritairement regarder
Et oui on ne parle pas assez souvent des calibrations qui peuvent avoir foirees !
Il faut essayer d’avoir une sorte de protocole personnel,chez moi c’est en mettant les mesures à 50cm que les calibraions me donnent le meilleur résultat.
Et bien entendu il faut un pied de micro qui soit à la bonne hauteur etc.
Ne pas hésiter à faire chauffer un peu les électroniques,et avoir un un peu un référentiel film ou musique pour voir si le détail,la dynamique,la spatialisation sont corrects.
Quand une calibration s’est male passée chez moi je l’étends et cela m’est déjà arrivé !
Et j’ai dès le début préféré la calibration avec l’appli
Coco68 - Modérateur Home-Cinéma
- Inscription Forum: 30 Nov 2010 22:14
J’ai besoin d’aide, je souhaite acheter une licence Audyssey PRO pour un 8802.
Est ce toujours possible ?
Comment faire ?
Je ne trouve pas, comment faire sur le site Audyssey ?
Je suis à la recherche de renseignements...
Merci par avance pour votre aide
Comment faire ?
- vinsize
- Broker
- Inscription Forum: 17 Juil 2003 19:05
vinsize a écrit:Bonjour
Comment faire ?
Parce que tu ne va pas au bon endroit : https://installer.audyssey.com/Home.aspx
Vu que le programme Pro ne sert plus vraiment les intérêts d'Audyssey qui est passé sur autre chose le lien est évidemment presque confidentiel ...
- jacko
Merci ...
je viens de payer la licence 149$ !
Que j’ai associé à mon kit audyssey Pro
(Numéro du kit est un no à 5 chiffres)
J’ai renseigné le numéro MAC de mon 8802A
J’ai générer et reçu la clef pour la suite
« licence key »
N’ayant pas de PayPal, j’ai payé en CB les 149$
J’espère ne pas avoir trop de frais bancaire....
« licence key »
- vinsize
- Broker
vinsize a écrit:Merci ...
« licence key »
Les licences Audyssey Pro ne sont pas associé au kit micro.
Toute personne ouvre un compte Audyssey Pro.
Le numéro de série du micro permet le téléchargement du fichier de correction ce qui certifie d'avoir le kit.
149$ c'est par appareil identifié par l'adresse MAC qui permet d'avoir une clef attribuée uniquement à cet appareil.
Cette clef est à renouveler tous les mois, c'est heureusement gratuit.
Donc pour chaque appareil une adresse MAC, une clef spécifique et une licence.
- jacko
Bonjour je suis éventuellement intéressé par l'achat d' un Denon avr x4500 H en remplacement de mon NAD T 758 V3 j'ai un pack Klipsch et un sub SVS PB 1000
qu'en pensez vous?
qu'en pensez vous?
- Nadcuges
- Inscription Forum: 10 Sep 2019 12:21
Qu’est ce qui ne te convient pas sur le nad ?
Il a la réputation d’être très bon pour un intégré ?
Coco68 a écrit:Qu’est ce qui ne te convient pas sur le nad ?
envie de changer de signature sonore !
est ce que niveau puissance le 4500 h sera suffisant?
- Nadcuges
Tout dépend de tes enceintes et de tes attentes.
Tes enceintes marcheront c’est certains mais pas à leur plein potentiel .
Le 4500 a déjà l’xt32?
Coco68 a écrit:Tout dépend de tes enceintes et de tes attentes.
oui le XT32 pour le 4500 !
j'ai un pack KLIPSCH En 5.1.4
- Nadcuges
C’est une bonne chose l’xt32, la correction du caisson marche bien.
Je pense que le 4500 aura peut-être moins de réserve de puissance et sera certainement moins rond que le nad.
Le plus simple serait de t’en faire prêter un,pas toujours évident mais au moins tu serais sur.
Coco68 a écrit:C’est une bonne chose l’xt32, la correction du caisson marche bien.
ah justement c'est ce que j'aime !!
merci !!
et si je lui adjoins des blocs de puissance ?
- Nadcuges
