Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bull00, dm, MrBond, pouss71, Richard Lemesle et 33 invités
JVC LX-NZ3 : DLP Laser & simulation 4K
Message » 31 Aoû 2019 16:31
- Video HCFR JVC LX-NZ3 Présentation : https://www.homecinema-fr.com/video-hcf ... sentation/
- Test HCFR JVC LX-NZ3 :
http://pro.jvc.com/pro/pr/2019/consumer ... lease.html
JVC Announces 4K/HDR Compatible DLP Projector
With 3,000 Lumen Laser Light Source
New LX-NZ3 features JVC’s HDR Auto Tone Mapping to optimize HDR images.
LONG BEACH, Calif., August 30, 2019 – JVC today announced a new 4K/HDR compatible home theater projector with a laser light source that provides high resolution, high brightness and long life. The new JVC LX-NZ3 also features JVC’s Auto Tone Mapping to automatically deliver the best possible HDR images.
The new LX-NZ3 uses a BLU-Escent laser light source to achieve 3000 lumens brightness and long life, which makes the projector an ideal choice for use in living rooms and family rooms.
Main Features
BLU-Escent laser light source achieves 3000 lumens brightness and 20,000 hour long life illumination
Thanks to the high brightness, a fully darkened room is not required to achieve excellent image quality, allowing the projector to be used in typical living and family room settings with high ambient light. Regardless of the room design, the projector delivers high quality HDR images with wide dynamic range.
Supports HDR (High Dynamic Range) content
The new projector supports HDR content, both HDR10 adopted for UHD Blu-ray and HLG (Hybrid Log Gamma) adopted for broadcast cable, satellite and live TV. Furthermore, the LX-NZ3 automatically switches to the optimal picture mode based on the signal detected so users can enjoy HDR content without the need for manual adjustments.
Auto Tone Mapping automatically optimizes settings for HDR10 content *1
HDR10 content brightness varies greatly from one release to another. To optimize performance based on content, the LX-NZ3 is equipped with Auto Tone Mapping that reads content brightness metadata (Max CLL / FALL *2) and automatically adjusts brightness settings based on that information.
* 1: In the case of content that does not contain mastering information, it will refer to a fixed value or need manual adjustment.
* 2: MaxCLL (Maximum Content Light Level), MaxFALL (Maximum Frame Average Light Level)
Wide lens shift with ± 60% vertical, ± 23% horizontal range with 1.6x zoom
The LX-NZ3 features lens shift with a wide ± 60% vertical, ± 23% horizontal range, and is equipped with a 1.6x zoom lens that supports a projection distance of 9.8 feet to 15.7 feet for a 100-inch screen. This flexibility allows placement in a wide range of environments without the need for keystone correction, which can degrade image quality.
Dynamic light source control achieves high image quality and  : 1 contrast
With mechanical apertures, there is some delay when adjusting light output, but JVC’s laser light source can control light output instantaneously, so dynamic brightness adjustment is possible with little or no delay. By controlling the output of the laser according to the brightness of the scene, the LX-NZ3 can reproduce images closer to reality. Moreover, when a complete black signal is input, contrast of : 1 can be achieved by controlling the laser output.
High resolution 4K image from a compact projector
The LX-NZ3’s compact size is in part thanks to its use of the 0.47-inch Digital Micromirror Device, which allows the projector to deliver high resolution 4K images from a device that can be easily placed on a shelf, on a table or discreetly installed in a living or family room.
Two cabinet colors available -- black and white
JVC offers the LX-NZ3 in either black or white cabinets, so users can choose a color that best works with their room.
Specifications:
Model Name: LX-NZ3
Color Variation: Black / White
Device: 0.47“ DMD
Resolution: 3840 x 2160
Lens: x1.6Manual Zoom & Focus
Lens Shift: Vertical +/- 60%, Horizontal +/- 23% (Manual)
Projection Display Size: 60inch - 200inch
Light Source: Laser Diode
Brightness: 3,000lm
Dynamic Contrast Ratio: ∞:1
Input Terminals: HDMI: 2(HDCP 2.2 x1,HDCP 1.4 x1), PC: 1(D-Sub 15pin)
Output Terminals: USB Type A: 1(Power Supply 5V/1.5A), Trigger: 1(Mini Jack,12V/0.1A)
Control Terminals: RS232C: 1(D-Sub 9pin), USB Type B (mini): 1(For Service use)
Dimensions: (W x H x D) 405 x 341 x 146 mm
Weight: 6.3kg
The JVC LX-NZ3 will be available in late November for $3,699.95.
Chewee Levelu
Inscription Forum: 25 Aoû 2010 9:38
Message » 31 Aoû 2019 16:46
Quel dommage d'utiliser une puce 0.47!
ektor
Inscription Forum: 20 Aoû 2007 20:19
Message » 31 Aoû 2019 16:55
2nd message sur le sujet et 1ère critique d' un produit pas sorti :o
On ne perd pas de temps comme ça . :hein:
Chewee Levelu
Message » 31 Aoû 2019 17:28
Ceci fait effectivement partie de ce qui sera présenté à l'IFA et il ne m'était pas possible d'en parler avant, mais puisque c'est public...
Alors de ce qui m'en a été dit c'est que ce NZ3 est un produit (pseudo) "4K" qui a vocation a se positionner en entrée de gamme de projecteurs JVC, donc avant le N5...
... et pour ce faire il ne pouvait qu'y avoir un produit de type DLP... que l'on peut apprécies... ou pas. :wink:
Hugo
Hugo S
Membre d'Honneur - Président de l'Association & Relations PROs
Message » 01 Sep 2019 9:57
Chewee Levelu a écrit:2nd message sur le sujet et 1ère critique d' un produit pas sorti :o
Désolé de ma franchise mais on connait les travers de cette puce même si JVC (plutôt son sous-traitant) sait plutôt bien l'intégrer.
D'un autre côté, on peut comprendre l'utilisation de cette puce pour rester dans le budget "entrée de gamme" et il n'est pas question pour JVC de tuer la gamme actuelle avec une puce trop performante.
En tout cas quand on voit ce petit châssis, ça laisse entrevoir des possibilités l'année prochaine chez JVC avec pourquoi pas un N8/NX9 laser et garder un N6 en "second de gamme".
ektor
Message » 01 Sep 2019 10:03
Je pars du principe "qu'il ne faut pas tirer sur l ambulance" tout simplement :idee:
Attendons de voir les 1ers tests, tu ne crois pas ? :wink:
Chewee Levelu
Message » 01 Sep 2019 10:19
ektor a écrit:Désolé de ma franchise mais on connait les travers de cette puce même si JVC (plutôt son sous-traitant) sait plutôt bien l'intégrer.
En tout cas quand on voit ce petit châssis, ça laisse entrevoir des possibilités l'année prochaine chez JVC avec pourquoi pas un N8/NX9 laser et garder un N6 en "entrée de gamme".
Personnellement, je pense que la source Laser va remplacer le bulbe au mercure dans les toutes prochaines années, et quelques soient les constructeurs (Sony, JVC, ...).
Je dis cela, car en Europe par exemple, je sais que la commission européenne met de plus en plus de pression pour complètement arrêter (ou du moins diminuer au maximum) l'utilisation de ce type de lampe au mercure, et cela pour des raisons écologique avant tout.
Quand on voit que JVC sort ce VP laser (qui est censé tenir 20 000 Heures) pour un prix public inférieur à 4 000 $, on peut supposer qu'il est aujourd'hui possible pour les constructeurs d'intégrer une source laser sans que cela ne coûte le prix d'un VW760 par exemple (15 000€).
Ce qui est surprenant de mon pont de vue, c'est que JVC intègre cette techno dans un produit d'entrée de gamme ; car jusqu'à présent, pour avoir une source laser chez JVC dans la gamme grand public, c'était le Z1 ( ou des VP de gamme professionnel basé sur les chassis Xxx00). Personnellement, j'aurai cru que cette source laser serait d'abord apparu dans une gamme intermédiaire (par exemple, un remplaçant du NX9), puis les années suivantes sur les gammes inférieurs (par exemple le remplaçant d'un N7 et N5, voir d'un X7900). Mais apparemment, le choix de la gamme choisi par JVC pour intégrer cette technologie laser a été tout autre. On peut supposer (espérer) peut être que cette technologie laser sera intégré dans la gamme (du moins en partie) qui succédera à la gamme actuelle Nx (pure spéculation de ma part). Et je pense que Sony, qui maîtrise le sujet avec les VW760 et VW860, en fera très certainement de même.
Nous verrons ce que l'avenir nous réserve.
Kaizen
Diffuseur : JVC RS3200 / Daylight 1.1 REFERENCE DBC, Pana 55VT60 et 50GT30 -- Ampli : Marantz SR 7011, Rotel RMB 1075 -- Enceinte : Focal Chorus 826V, 906, Surround Dome, 800sw -- Source : OPPO 203, OPPO 103D , PANA UB420 (les 3 tweakées)
kaizen
Modérateur Home-Cinéma
Inscription Forum: 16 Sep 2009 18:08
Message » 01 Sep 2019 10:33
Surprenant de la part de jvc de garder le mercure sur des projos à 5000 7000 17000 et la 4000 laser ça interpelé aussi sur le coup réel d'un laser.
Ce genre de produit dérive de la concurrence ne fait pas de noir pour moi c'est même pas du 4k .
Intéressant de voir que le.laser peut être abordable décevant que jvc prenne cette gamme pour son entre dans le laser.
Dommage que jvc n'est pas sorti un n7 laser à 9000 euros par exemple.
Après la c'est sans doute du rebadger acer ou benq alors que mettre un laser dans son propre projo dlia ou sxrd doit être plus complexe.
muscle
Broker
Inscription Forum: 24 Déc 2001 2:00
Message » 01 Sep 2019 10:34
Chewee Levelu a écrit:Je pars du principe "qu'il ne faut pas tirer sur l ambulance" tout simplement :idee:
Il ne faut pas tiré sur lamboulance mais vu la matrice c'est croix rouge :mdr:
muscle
Broker
Message » 01 Sep 2019 11:12
Ce n'est pas que du rebadgeage car ce projo bénéficera de l'auto tone mapping et des profils spécifiques liées aux platines Panasonic donc JVC a mis son nez dedans ;)
Avec ce produit, il y a de fortes chances qu'ils trustent les ventes dans cette gamme de projos DLP laser à 4/5K€ au détriment de BenQ, Optoma et consorts ... avec la réputation de JVC et les fonctions spécifiques ci-dessus, stratégiquement ça peut porter ses fruits !
"Remember, remember, the 5th of November."
Danam
Inscription Forum: 12 Fév 2002 2:00
Message » 01 Sep 2019 11:26
Des infos sur le nombre de segments de la roues chromatique?
DTSman
Contributeur HCFR 2022
Message » 01 Sep 2019 11:31
L'intérêt du modèle est surtout sur sa gestion du Tone Mapping en HDR, couplé avec la technologie laser et sa réactivité immédiate sans latence par rapport à un IRIS AUTO.
Dans l'état actuel, seuls, le DLA-Z1 et le LX-NZ3 vont bénéficier de cette fonctionnalité, toutes marques et tous modèles actuels confondus !
A voir si, d'ici la fin d'année, Optoma va mettre à jour son UHZ65 avec cette fonctionnalité.
Dans l'usage du HDR, il semble qu'au final, cet Auto Mapping apporte beaucoup dans l'appréciation général du HDR.
Quand à la puce 0.47, en natif, elle doit avoir les plus mauvaises valeurs de contraste ANSI et On/Off de l'histoire des DLP ! c'est à espérer que JVC ait au moins changé la 0.47 du LX-UH1, par la V2, sinon c'est cadre "parasite" assuré.
Après, c'est sûr que JVC peut écrire contraste On/Off infini avec le laser :wink: , le tout est de voir à l'usage ce que cela donne dès 1% de blanc.
La puce 0.66 aurait sans doute permis de rester dans un très bon contraste ANSI, le laser permettant peut être de pondérer le On/Off.
Si l’Optoma UHZ65 est mis à jour avec sa puce 0.66, il peut tout de même devenir un sacré concurrent.
Il y a un point où tous les possesseurs DLA devraient "baver" sur ce LX-NZ3 ( si,si, :D ) : c'est sur son piqué UHD :mdr: !
Son image UHD razor sharp :wink:
La 0.47 tient ses promesses sur ce point.
Donc pour l'instant, le seul vidéoprojecteur laser ( avec le Z1 ) qui offre un UHD/HDR au piqué de rêve, un ajustement optimal des réglages par rapport aux caractéristiques du film ( Auto Mapping ) et la luminosité requise 3000 Lumens ! :idee:
Si en plus, la version de firmware Auto/Mapping est bien de JVC avec l'expérience du Z1 et pas du BENQ W5700, ça peut peut être apporter quelques surprises supplémentaires.
Quant au fait que la gamme DLA tarde a décliner leur version laser, peut être que la stabilité des matrices dans le temps vis à vis des fortes luminosités est un point à "consolider".
dm
Inscription Forum: 26 Sep 2003 7:07
Message » 01 Sep 2019 11:34
Info non disponible encore pour le nombre de segments.
A priori c'est une base BenQ.
Danam
Message » 01 Sep 2019 15:00
Je comprends ton point de vue :wink: mais les gens doivent savoir sur quel type de produit ils partent exactement.
ektor
Message » 01 Sep 2019 18:15
Et le fait de dénigrer la puce 0,47 sur un VP jamais vu est une info pertinente ?
Que ce soit Benq, JVC ou les autres ont fait le choix de cette puce pour certaines raisons et il me semble bien que ... des VP qui sont sortis avec aucun n' est mort né.
Ce qui prouve bien que le marché et les clients pour ce type de produit existent :idee:
Pardonne ma question mais tu as déjà eu le projo chez toi en avant première ? :lol:
Tout ça pour dire que ce ne sont que des spéculations, le produit n est pas sorti et donc :
ektor a écrit:mais les gens doivent savoir sur quel type de produit ils partent exactement.
n' a pas de sens . :idee:
On en reparle avec grand plaisir quand on aura vu la bête tourner :wink:
Chewee Levelu
