(traduction en-dessous)
"Good sound or accurate sound ? If you look at some of the reviews we published, if you want to make an amplifier which people will say "that sounds really nice", give it a hefty dose of second harmonic distortion. You can see it, I mean it has a bent transfer function but second harmonic distortion that is not accompanied by a lot of intermodulation makes everything fatter and warmer and nice.
We have a review of a Cary amplifier in december issue, which has 3% second harmonic distortion for like 5W. And our reviewed said "you know, it sounds just like a single ended triode amp". Well of course it does, it has the same bent transfer function ! The Audio Research amplifier we reviewed in october has the same sonic signature but the distortion is like 10 times or more lower, but I listened to that amplifier and I know what it's doing and yet my goodness I enjoyed the sound, so when you say one sounds good or sounds accurate, they're two different things. The Benchmark AHB2 amplifier that we reviewed in november 2015 and has just been rewritten by Jane Austin in our october issue, that is an astonishing amplifier; its basic performance is better than my Audio Precision analyzer, and when I measured it, the Audio Precision guy was actually on the phone helping me with some sort of hacking to get the Audio Precision analyzer to be able to measure what the Benchmark amp is doing. However, it doesn't sound as nice as the Audio Research. Is that because it's better or because it's doing something wrong that we were unable to find ? And if we are unable to find it, why does it matter ? You know the whole thing is just tricky ! And of course the blind listening test say all the same thing anyway, so..."
"Loudspeakers, what do I know what they do ? If you look at the KEF (LS50 wireless, ses enceintes actuelles NDLR), it has beautifully controlled dispersion, the sound it puts out to the side rolls in a beautifully controlled manner, no hot spots in any frequency range, flat response, within regular, good limits, no resonances in the cone. A lot of speakers I measure, you keep seeing this, - Rogers LS3/5 is typical of this -, you see its freq response, and then between around 1.3K and 3KHz a little blip; well that is basically where the sound is going out from the cone , hits its surround, flex back and you get a little resonance anti resonance thing going on. You see that a lot still in loudspeakers, I don't know why speaker manufacturers aren't more bothered about that. Maybe it's not that important, you get a bit of nasal coloration, but you tend to adjust to colorations; it's like looking through glasses with a tint, after a while you don't notice there's a tint."
Traduction (perfectible):
Bon son ou son précis ? Si vous regardez les critiques que nous avons publiées, si vous voulez faire un amplificateur pour lequel les gens diront "ça sonne vraiment bien", donnez-lui une bonne dose de distorsion de seconde harmonique. Vous pouvez le voir, je veux dire qu'il a une fonction de transfert courbée mais la distorsion de la seconde harmonique qui n'est pas accompagnée de beaucoup d'intermodulation rend tout plus "gras", plus chaud et agréable.
Nous avons une critique d'un amplificateur Cary dans le numéro de décembre, qui a une distorsion de seconde harmonique de 3% pour environ 5W. Et notre testeur disait "vous savez, ça sonne comme un ampli single ended triode". Evidemment: il a la même fonction de transfert courbée* ! L'amplificateur Audio Research que nous avons examiné en octobre a la même signature sonore, mais la distorsion est au moins 10 fois plus basse, mais j'ai écouté cet amplificateur et je sais ce qu'il fait et j'ai apprécié le son, alors quand on dit qu'un son est bon ou précis, ce sont deux choses différentes. L'amplificateur Benchmark AHB2 que nous avons testé en novembre 2015 et qui vient d'être revu par Jane Austin dans notre numéro d'octobre, c'est un amplificateur incroyable: ses performances de base surpassent celles de mon analyseur Audio Precision, et quand je l'ai mesuré, le gars d'Audio Precision était au téléphone pour me donner des astuces afin que l'analyseur Audio Precision puisse mesurer ce que l'ampli Benchmark fait. Et pourtant, le Benchmark ne sonne pas aussi bien que l'Audio Research. Est-ce parce qu'il est meilleur ou parce qu'il fait quelque chose de mal que nous n'avons pas pu trouver ? Et si nous sommes incapables de le trouver, en quoi cela importe-t-il ? Vous voyez, tout cela est compliqué. Et bien sûr, le test d'écoute en aveugle dit la même chose de toute façon, alors..."
"Les haut-parleurs, qu'en sais-je ? Si vous prenez le KEF (LS50 wireless, ses enceintes actuelles NDT), il a une dispersion superbement contrôlée, le son qu'il émet sur le côté s'atténue d'une manière magnifiquement contrôlée, pas de points chauds dans n'importe quelle gamme de fréquence, réponse plate, dans les bonnes limites, pas de résonances du cône. Beaucoup de haut-parleurs que je mesure, vous continuez à voir ceci (la Rogers LS3/5 en est typique): vous voyez sa réponse en fréquence, et entre environ 1,3K et 3KHz une petite altération; c'est simplement le son qui sort du cône, frappe son environnement immédiat, rebondit et vous avez un petit effet résonance anti-résonance qui se produit. On voit ça dans beaucoup de haut-parleurs encore aujourd'hui, je ne sais pas pourquoi les fabricants de haut-parleurs ne s'en soucient pas davantage. Peut-être que ce n'est pas si important, vous obtenez un peu de coloration nasale, mais vous avez tendance à vous adapter aux colorations ; c'est comme regarder à travers des verres avec une teinte, après un certain temps vous ne remarquez plus qu'il y a une teinte."
https://youtu.be/NdjO9ZIx8ag?t=2295
* traduction probablement inexacte, je ne sais pas ce qu'il veut dire par "bent transfer function"
