Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: tonips3 et 10 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
[VENDU] MERIDIAN 861 V4
Message » 02 Sep 2018 13:19
Type : Préampli home cinéma très doué en hifi
Marque : Meridian
Modèle et options : 861 V4
Prix de vente :1000 euros --》800 euros
Département où la marchandise est visible : 24
Première main : non, seconde
Prix neuf : Trééééééés cher à sa sortie (dans les 12000 euros, il me semble)
Facture disponible : non
Date, pays et lieu d'achat : Le bon coin, 2018
Garantie et date d'expiration :plus sous garantie
Numéro de série :
Emballage d'origine conservé : hé oui
The following cards are fitted as standard inside a Meridian 861:
CO00: Control computer card. Complete with Flash memory, RS232 port for control and status, 3 x confi gurable trigger outputs and Meridian Comms.
CD20 & EF20: Internal (no rear panel) 48-bit DSP cards each containing two Motorola 56367 chips running in dual precision mode, each card offering 300 MIPS (million instructions per second) capability.
IE42: Digital Input/Output with 6 x S/PDIF (IEC1937) coax inputs, 1 Toslink optical digital input, multiple input options. Includes 150 MIPS DSP de-jittering facility and upsampling to 24-bit, 96kHz sampling. 2 x 2-channel S/PDIF outputs.
IA00: Analogue Input with 6 pairs of analogue input on RCA phono connectors, including super-quality A/D conversion.
Version 3 to Version 4 upgrade replaced the AB00 card with an EF20 (Same as the CD20 card), featuring a pair of Motorola 56367s running in double precision (48-bit) mode, providing an additional 300MIPS and allowing all processing to be carried out at high resolution. This all adds up to a total of 750MIPS (including 150MIPS of DSP on the IE42 digital input card for dejittering and upsampling) � no less than four times as much DSP power as any other comparable consumer audio product.
To provide audio outputs, one digital output card or two analogue output cards must be fitted. The list of available cards (see price list for updates) includes:
SL00: Slave Patch: 4 x DIN 180 for Meridian DSP Speakers only
OE12: Digital Output: 4 x coaxial for Meridian DSP Speakers only
OA03: Analogue Output: 4 x unbalanced 192kHz-capable on RCA
OA13: Analogue Output: 4 x balanced 192kHz-capable on XLR
TP00: Tape Output: 2 pairs unbalanced on RCA, 1 x headphone out
IA10: Analogue Input: 2 pairs balanced on XLR (IA00 required)
IA20: Analogue Input: 3 pairs unbalanced on RCA (IA00 required)
IA30: Phono Input Moving Coil: 1 pair unbalanced on RCA (IA00 required)
IA35: Phono Input Moving Magnet: 1 pair unbalanced on RCA (IA00 required)
IA40: Multi-channel Analogue Input: 2 x 6 discrete channels on RCA
IA45: Multi-channel Analogue Input: 6 discrete 96/24 channels on RCA
ID20: Digital Input: 2 x coaxial, 2 x Toslink optical
ID25: Digital Input: 4 x Toslink optical
ID30: Digital Input: 3 x AES/EBU on XLR, 1 x AT&T
RF00: LD Input: 1 x RF RCA, 1 x digital coax on RCA, 1 x Toslink optical
VS00: Video Card: 4 composite, 4 S-video, tape and monitor
VS10: Video Card: 8 S in, S and composite out with S to C conversion
VS20: Video Card: 1 component in and out for on-screen display
VS40: Video Card: 8 composite in, with tape and monitor
VS50: Video Card: 3 component in and 1 out on BNC
Site web du constructeur :http://www.meridian-audio.info/show.php?compid=51
Commentaires : Probablement le préampli home cinéma le plus évolutif et le plus doué en hifi. Une merveille à réserver aux home cinéphiles exigeants, et non aux quiches dans mon genre. :siffle:
Pourquoi cette revente : tout simplement car, comme je suis un crétin des Alpes techniquement parlant, je suis inficu de le faire fonctionner correctement, y compris en utilisant le logiciel mconfig (en gros, mconfig le détecte, paramétrage nickel, mais aucun son ne sort).
Cela explique ma revente à 700 euros environ en dessous de l'argus de ce type de bestiole.
Les cartes intégrées : 800 TP 00 : Entrée casque.
800 IA 30 : Entrée phono
800 IA00U : Entrées analogiques
800OA 03 : analog output
800IE 42 Digital input
A la vue des cartes, il s'agit donc d'un appareil plus tourné hifi que home cinéma. Pour entrer en multicanal, il faut donc avoir un switch meridian HD621 ou avoir des appareils Meridian avec multi sorties numériques.
Je suis ouvert également à un échange sur du matèriel hifi ou home cinéma hors enceintes.
[b]Liens divers :
[b]Photos :
MAGISSON
Inscription Forum: 23 Nov 2009 7:50
Message » 07 Sep 2018 6:30
Up
MAGISSON
Message » 10 Sep 2018 8:35
Vente flash à 800 euros !
Jusqu'à quand la vente flash, me direz-vous ? Hé ben ça sera quand je veux !
Mais, me direz-vous bande de petits curieux, c'est une baisse de prix alors ?! Je vous répondrai que non, c'est une vente flash !
Mais alors me direz vous, c'est sûrement un argument marketing totalement creux comme les années 80 ont su nous abreuver pour nous vendre leur camelote (Jacques Seguela, sors de ce corps ! ) juste pour que vous lisiez l'annonce ?
Là vous aurez raison, mais c'est moins chiant à lire qu'un simple up :siffle:
MAGISSON
Message » 02 Oct 2018 21:00
Up et poursuite de la vente flash. :siffle:
MAGISSON
Message » 09 Oct 2018 21:24
Vendu à un bien sympathique forumeur (en espérant qu'il a fait bonne route ).
MAGISSON
Retourner vers Processeur HC
