hyperspace a écrit:LG à déjà le Dynamic Tone Mapping implémenté au dessus du HDR10 simple, en quoi le HDR10+ est supérieur ?
Il faudra attendre des contenus HDR10+ et effectuer un comparatif pour répondre à ta question.
Selon Rtings...
The 2017 & 2018 LG OLED TVs now support HDR with 'Dynamic Tone Mapping', which is similar to HDR10+ or HDR10 with dynamic metadata. This feature analyses the content frame by frame in real time to adjust the HDR tone mapping curve. This has the advantage of displaying each scene with an optimized HDR effect. With HDR with static metadata, the entire movie used the same tone mapping curve, resulting in some scenes occasionally being too dark or too bright, or simply not exposed correctly to have the best possible HDR effect.
To activate this feature on the LG C8, you need to go in the 'Picture Mode Settings' tab and set the 'Dynamic Tone Mapping' option to 'On'. We prefer leaving it off so as to not modify the content in a way that was not intended by the content creator.
Mais chacun fera selon ses préférences.
