Marque : LUMAGEN
Modèle et options : RADIANCE PRO 4240 carte 18ghz
Prix de vente : 3800€
Département où la marchandise est visible : 59 Roubaix
Possibilité d'expédition : oui mais préférence remise en main propre
Montant des frais d'expédition : inclus
Prix neuf : 5000€
Facture disponible : oui
Date, pays et lieu d'achat : juin 2017 chez convergent UK
Garantie et date d'expiration : juin 2018
Numéro de série :
Description générale : excellent état
Site web du constructeur :
http://www.lumagen.com/testindex.php?mo ... ro_details
-Up to eight 4k60 UltraHD inputs
-Up to four processed 4k60 UltraHD video outputs at 9Ghz (or two at 18Ghz)
-Inputs and outputs support HDMI 1.x and HDMI 2.0, with HDCP 1.x or HDCP 2.2, at up to 4k60
-9Ghz output pairs are independently programmable for video, audio, or both
-18Ghz output pairs have 1 video+audio out and 1 audio only output
-Modular I/O allows upgrading to new HDMI technology as it becomes available
-Proprietary Lumagen NoRing™ scaling
-DARBEE Digital Visual Presence (DVP) enhancement technology for up to 2K sources
-Vertical keystone correction
-Picture-In-Picture (PiP) and Picture-Outside-Picture (PoP) with 4k sources (future update)
-Supports complete processing of 2D or 3D sources on processed outputs -10 bit front-end, with 12+ bits in calibration pipeline
-Per-pixel SD/HD video deinterlacing
-4913 point (17x17x17) CMS
-Rec2020 colorspace and HDR supported
-21-point Parametric Grayscale calibration
-Anamorphic screen support for up to 4k sources with and without an anamorphic lens
-Supports complete processing of 2D and 3D sources
-Optional dual 12V trigger outputs (only on 444x)
-Rack mountable (2U/1U) case, with optional rack ears
-High reliability external power supply rated at 34 years MTBF by manufacturer
![Image](http://www.image-heberg.fr/files/152215564541077467.jpg)
![Image](http://www.image-heberg.fr/files/15221563811882909896.jpg)
