Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 12 invités
Discussion sur les amplis et blocs de puissance multi-canaux pour le HomeCinéma
Earthquake Sound - Cinenova Grande 7 ( x 330 /8ohms)
Message » 06 Fév 2018 10:56
Earthquake Sound Cinenova Grande 7
Une Amplification dédier au home-cinéma avec ces 7 x 330 watts sous 8 ohms
et pourquoi pas en Hi-Fi ! :lol:
Quelques caractéristiques reprit sur leurs site , permettant de mesurer la dimension de machine :
http://www.earthquakesound.eu/home-audi ... rande.aspx
1450 watts into 1 ohm. RMS
1000 watts into 2 ohm, RMS
660 watts into 4 ohm, RMS
330 watts into 8-ohm, RMS
1500 watts bridge-link into 8 ohm RMS
2500 watts bridge-link into 4 ohm RMS
2800 watts bridge-link into 2 ohm RMS
XLR and RCA inputs
Frequency Range: 1W + /-0.1dB: 20Hz to 20kHz
Signal-to-noise ratio: 122dB at 1kHz-121dB at 5kHz / 120dB at 10kHz
Input impedance: 27,000 ohms.
4000VA ferrite OFC low regulation transformer with separate secondary windings.
Damping Factor: 1.600
Cinénova Grande BR exceed effortlessly technical standards set by THX, DTS and Dolby Laboratories.
Channel Separation: at least 120 dB.
Max. Input voltage: 1.9 volts.
THD: 1kHz, 8 ohms: 0.001%
12v trigger ( can be switched automatically from your preamplifier or other components with 12v trigger output).
Built-in Crossover: selectable between high-pass and low-pass or disengaged. 20Hz - 5kHz infinitely variable.
The crossover allows you to determine how much bandwidth your speakers to reproduce
. Use the amplifier to bi-amping two channels can be made to reproduce bass / midrange frequencies and two channels for the treble and the last channel might.
drive a large passive subwoofer. All this without using any crossovers.
Oversized, gold plated 7-way output terminals.
Weight: 61,5 kg. Carrying handle on the front panel. Proper lifting technique is recommended.
Handmade in the USA.
Available in black
Que dire de cette amplification avec de tels caractéristiques , limites monumentales comme :
- 330 watts par canal -
- un interrupteur disjoncteur utilisé dans nos maison ,de 20 amps, pour sa sécurité primaire
- 61,5kg
A part un risque de se faire mal au dos pendant son installation , le reste est que du bonheur .
J'ai découvert , avec plaisir , un produit qui rassure :
- Un colisage sans faille faite en bois , garni de mousses de qualité , sécurisant sérieusement un produit de 62kgs , pendant son transport .
- Un câble de tension dédier, enfin conforme à une machine de cette force : fiches moulés sur un cable de 3 x 12AWG ( 3.31mm²)
dés les première écoutes j'ai trouvé :
- Une amplification puissante , dynamique , articulé à souhait .
toutes les qualités d'une d'amplification de type numérique
+ Un signal complet dans tout les registres , permettant au même titre de véhiculer l'émotion .
une qualité que l'on retrouve surtout dans l'analogique .
le contrat est rempli :bravo:
Une machine de conception moderne, conforme à l'actualité :
- Optimisation de sa consommation d’énergie ( chauffe peut )
- Une sécurité total : la notre et celle de la machine : MARS technology (Magnetically Actuated Reanimation System)
- Construction avec des matériaux noble comme : la bobine de 4000Va en cuivre OFC à un prix concurrentiel .
à suivre : le déroulement de son arrivé dans sa nouvelle demeure
à bientôt avec vos commentaires et impressions
7 x modules d'amplification identique
thermique85
Membre HCFR Contributeur
Inscription Forum: 17 Nov 2007 16:17
Message » 06 Fév 2018 10:57
Quelques Photographies à son arrivé
même prévenue de l'arrivé d'un colis de 88kgs , cela reste impressionnant ( pour moi :wink: )
remarqué la qualité du colisage !
thermique85
vue de devant
Une fois déballage fait , vues de la bestiole
quasi identique à mon Meridian 558 qui à lui 10kg de moins
vue arriére
comparaison avec le Meridian 558
thermique85
Mise en place
attention à votre dos :wink:
posé sur le diable de levage
Le câble de tension du Cinenova Grande 7
thermique85
Message » 06 Fév 2018 10:58
Earthquake Sound a pour les amateurs d'ampli , une autre offre , en moins puissant et moins chère .
Son petit frére qui est le :
CINENOVA 7 qui fait quant même 7 x 250watts / 8 ohms .
http://www.earthquakesound.eu/home-audi ... ova-7.aspx
produit qui reste à découvrir !
thermique85
Message » 06 Fév 2018 11:34
Meridian 558.2 à 3 canaux .... :siffle:
sacré bête ce 558.2
J'en ai moi même un exemplaire
PS : diable avec fonction élévateur
Bien pratique
vinsize
Broker
Inscription Forum: 17 Juil 2003 19:05
Message » 06 Fév 2018 12:49
Historiquement en 30 ans j'ai eu :
intégré Denon / Yamaha
Thule Audio
Luxman M03- C03
Meridian 557 et 558
Nuprime MCH- K38 et STA-9
Nota : la problématique avec le Pack Teufel Theatre 10 , c'est qu'elles sont très gourmandes en énergie .
se qui fait que , rien est simple avec elles
je vais essayé de vous exprimer mes déboires :
Mes premiers ampli qui manquaient de puissance d'alimentation , mettaient les Medium en retrait , pour aller jusqu’à vous fatiguer les oreilles avec les aiguës.
= Un Son passable en musique et manquant de punch dans les films .
Ampli de puissance type analogique traditionnel : belle puissance / alimentation
= Un son sympa en : musique , concert , donnant de l'émotion à vous faire hérisser les poils .
beau instrument , mais Son , qui pourrais être encore plus détaillé pour aller plus loin .
Découverte juste avant le "Cinenova Grande 7" : amplis de puissance de type Numérique de dernière génération .
pour la musique et en concert :
ils m’ont offert de la dynamique , du détail , de l'articulation , avec un son chaleureux .
son hyper propre et peut être trop pour mes enceintes , car du coup je m’ennuyai dans mon fauteuil : Jazz / rock .
bien :P
Lors du passage à la musique classique et concert philharmonique ...... , c'est à se moment que j'ai trouvé les limites de la construction type "numérique" avec mes enceintes .
passages difficiles en écoute avec les même travers que mes débuts en HC . :(
pour le cinéma :
c'est simplement magique : articulé , punch , beau medium , équilibré ect...
=un bilan avec des + et des - . :-?
Mes Ampli Meridian restant ma meilleur option .
Mes impressions avec Cinénova Grande 7
de part ces caractéristiques données , je pouvait cumuler les meilleurs compétences des trois technologies . !?
Il a un lourd défi à tenir !
Première journée d'écoute
j'ai commencé par des phases test, avec :
1995 - Iron Maiden - The X Factor - - Blood on The World's Hands
enfin une guitare puissante , détaillé , vivante , pour passer ensuite à une monté en puissance qui vous donne un pepps d’enfer .
ça c'est fait , je prend :bravo:
un film d'animation numérique , très poussé , dans le domaine graphique et sonore :
Lichtmond - The Journey
Le son est agréable , avec des effets spéciaux super cadrés .
très bon moment qui me permet d'affiner mes gains sur mes différents canaux .
Toujours bonne pioche avec cet ampli :bravo:
Film : Oblivion
il y a du punch dans le son .
les voix sont mieux définie , plus articulé .
effets spéciaux plus prenant , car mieux définis dans l'espace .
et comment vous dire :oops: ....., le moins , dans cette demo est , de constater que mes caissons suivaient plus au rythme en matière de présence ( puissance).
j'avais un petit peux prévu la chose :siffle: , mais à se point !
diy-caissons/upgrade-teufel-uncle-doc-2-x-38-en-clos-t30085720.html
bref :zen:
les concerts étant déjà sympas je continue :
a-ha - MTV UNPLUGGED - Summer Solstice
groupe sympa des année 80 , avec se concert intime vraiment agréable .
tout est propre , détaillé , vivant , un son qui laisse à penser "naturel "
L'ultime test
un concert de musique classic , un des tueurs des amplis Numerique .
mes amplis analogique étant pas beaucoup plus à l'aise , mais de façon différente .
Beethoven Symphonies 7 - 9
j'ai vécu un grand moment d'émotion :
les instruments positionné , analysable quasi un par un , on ressent toutes la construction de l'orchestre .
les voix , appréciable dans leur détail .
le cœur beau , mesurable dans les détails , monté en puissance énorme ( limite fort , mais tellement bon :oops: )
ect , ect .... .
Voila pour les premières impressions
j'y retourne , car j'ai un concert sur le feu qui m'appelle :P
à bientôt
thermique85
Message » 06 Fév 2018 12:57
vinsize a écrit:Meridian 558.2 à 3 canaux .... :siffle:
sacré bête ce 558.2
bonjour à toi
je confirme , c'est une belle bête
juste que j'ai 2 canaux à réparer pour une bêtise de ma part .... :oops:
vinsize a écrit:PS : diable avec fonction élévateur
Bien pratique
pratique d'avoir des outils parfois .
et c'est sur , que sans lui je prenais un risque énorme pour mon dos .
d'où les Photos
le problème des 62 kg étant pas le poids proprement dis , j'ai porté plus lourd , mais c'est dans la manière de le prendre ....
tu prend une bonne suée , même avec le diable , crois moi :wink:
il est en place et vue le resultât , il est bien partie pour y rester :love:
thermique85
Message » 06 Fév 2018 17:18
C'est quel tarif at home cet engin?
ma salle dédiée
calova.dts
Modérateur Installations
Inscription Forum: 19 Sep 2003 18:55
Message » 06 Fév 2018 17:29
salut à toi .
cela fait plaisir de te lire
tu as remarqué que je suis tes conseils !
calova.dts a écrit:C'est quel tarif at home cet engin?
en prix public , il est à 5012 euros + le transport ( 100 euros env )
après ,pour un prix prix , c'est suivant :wink:
regarde tes MP
thermique85
Message » 06 Fév 2018 17:46
Par rapport au Meridian de le situ comment ?
Je trouve le Meridian vraiment très agréable jamais agressif musical
La force tranquille, jamais agressif
vinsize
Broker
Message » 06 Fév 2018 18:03
vinsize a écrit:Par rapport au Meridian de le situ comment ?
je suis tout à fait d'accort avec toi .
c'est pour cela que le fait de vouloir changer était un vrais chalenge .
à la maison avec mon systéme en place , le Cinénova Grande 7 a réussis à enrichir , en globalité , la qualité du son
je ne sais pas , si j'ai réussis à être claire dans mes propos , sur test juste avant ton premier post .
retourne voir :wink:
le Cinénova Grande , c'est un Meridian ++ en puissance , remis à niveau avec les outils de maintenant permettant d'aller plus loin dans le son , avec un prix plus démocratique :zen:
en plus avec ces 7 canaux , je n'ai maintenant qu'un ampli au lieux du Meridian 558 + Meridian 557
thermique85
Message » 06 Fév 2018 22:28
Mais c'est juste un monstre ton truc là! Un ampli à l'ancienne, en somme.
J'avais regardé le modèle du dessous à une certaine époque. Faudrait voir (entendre plutôt) si c'est assez musical.
ektor
Inscription Forum: 20 Aoû 2007 20:19
Message » 06 Fév 2018 22:34
Comment as tu réussi à l'extraire de la caisse ?
vinsize
Broker
Message » 06 Fév 2018 22:42
J'ai vu que tu as hésité avec un ampli emotiva et je voudrais savoir pourquoi. Car j'ai l'intension d'en prendre un de chez eux car le rapport puissance prix est plus abordable, donc ton avis m'intéresse ! ;)
Arkann
Inscription Forum: 10 Aoû 2010 18:09
Retourner vers Amplis de puissance HomeCinéma
