Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: athoriac, davidtollard@sfr.fr, inf1nity, marc69, Morganita, saturator77 et 377 invités
[2017] Ampli Rotel RAP 1580 - Atmos et DTS X
Message » 08 Nov 2017 21:54
Il est plus âgé...
ggregg
Inscription Forum: 19 Aoû 2007 21:06
Message » 09 Nov 2017 16:15
dommage que pas de calib ?
KASTAS
Inscription Forum: 31 Aoû 2001 2:00
Message » 12 Nov 2017 15:57
Effectivement, pas de calibration automatique, mais on peut régler manuellement les niveaux acoustiques et les distances des enceintes, ainsi que l'égalisation sur 10 bandes. Dans mon environnement les 2 premiers réglages donnent déjà excellents résultats.
ggregg
Message » 21 Fév 2018 19:39
La nouvelle màj est déployée pour l'instant uniquement par connexion Ethernet :
Release Notes V1.78
1. Fixed text inconsistencies in the OSD setup between the HDMI OSD and the front TFT for multi-language.
2. Fixed source input name inconsistency between HDMI OSD and front TFT.
3. Fixed value memory error in ADVANCE SPEAKER SETUP page to avoid userdefined values being reset/lost after a power cycle.
4. Fixed a OSD output display error caused when changing the audio system to 5.1.4 system under multi-language mode to avoid the video of the OSD changing from 480p to 576p.
5. Fixed incorrect RS232 feedback of “volumn_nn!” command after power cycle.
6. Fixed Lip Sync (HDMI Audio Delay) not working properly.
7. Fixed a translucent green mask on HDMI 4~8 source inputs when scrolling the volume knob or after switching to a source with 4K 60Hz video.
8. Removed the audio delay (1~2s) when starting playback for a FAST AUDIO SYNC configured source on COAX and OPTICAL inputs.
9. Optimized Bass Management levels design for improved performance.
a. Test Tone subwoofer output decreased 8dB for improved level setting
b. Adjusted re-directed Bass levels under Multi-Channel Stereo mode for 2, 3, 5,
7, 9, 11 channel settings to match target output curve
10. Optimized HDMI handshake process with some source players and displays to correct video output of 480p or 720p for 4K sources.
11. Fixed 2CH PCM indication on front TFT when streaming multi-channel audio.
12. Improve audio/video sync timing when switching source inputs.
13. Fixed an intermittent 4K video drop/cut error on HDMI 1~3 input on some. (EDID Handshake)
14. Fixed no audio output on HDMI 1~3 input with specified display and source devices, such as: OPPO UDP-203 and VPL-VW1000ES projector. (EDID Handshake). Fixed no ARC audio after hard power cycles with some specified TV (EDID Handshake)
15. Updated HDMI EDID to support Dolby ATMOS on XBOX One S and XBOX One X using “Dolby ATMOS for Theater” driver (requires driver installation on XBOX).
16. Decreased standby power consumption under Quick Power mode.
- End -
ggregg
Message » 19 Mar 2018 14:16
Quelqu'un possède t'il cet ampli? Je me tâte pour me lancer sachant que je recherche un ampli performant en HC et HiFi.
:wink:
LINK1976
Inscription Forum: 25 Déc 2005 17:29
Message » 25 Mar 2018 14:36
J'ai pu essayer la "bête" hier, et en un mot, cet ampli est une merveille de rendu musical. J'ai enfin mis la main sur un ampli qui soit polyvalent, à savoir excellent en home cinema et en hifi. La puissance indiquée n'est pas galvaudé, il transmet exactement ce qu'il y a d'écrit sur le papier, à savoir du 7X100watts, et 2 fois 150 watts, on sent bien la maitrise des enceintes, et quel punch. Ce dont je suis sûr c'est qu'en hifi il fait mieux qu'un Yamaha A-S2100 que j'ai pu écouter dans la semaine, le médium est beaucoup mieux retranscrit et en home cinema, c'est bien simple je n'ai jamais entendu un rendu aussi cristallin et précis, les effets arrivent de partout et son très facilement identifiables, en gros on sait ce que c'est, l'explosion d'une vitre est hyper naturel et ce n'est pas de la bouillie d'aigu.
Le seul manque de cet ampli réside dans l'absence de calibration, il faut donc bien connaitre ses enceintes, et surtout avoir une salle trop compliqué sous peine de passer par un pro pour calibrer la bête via son égaliser paramétrique 10 bandes.
Pour simplifier le trait, ce 1580 serait l'ampli hifi 1592 ROTEL en multicanal.
Je suis à 2 doigts de craquer.
LINK1976
Message » 26 Mar 2018 21:04
C'est vrai qu'au niveau de son il est très performant. Malheureusement, quelques petits bugs persistent malgré le nouveau firmeware. Le service clients (très réactif) m'a conseillé de reflasher la màj suivie de 2 resets usine. On verra ce que ça donnera...
ggregg
Message » 29 Mar 2018 19:26
J'ai eu le service client pour diverses questions, et l'une d'entre elle m'a dissuadé de franchir le pas. En effet, le Rotel convertit le DSD en LPCM, pas de DSD natif donc, dommage. Le successeur devra avoir le DIRAC LIVE et le DSD en natif car là pour le coup, l'ampli est trop cher d'un bon 1000€.
Je vais donc me diriger sur un autre produit, dommage, le son est purement magnifique.
:oops:
LINK1976
Message » 17 Juin 2018 15:47
Le nouveau firmware v1.88 est disponible, mais uniquement à la demande auprès de B&W
Release Notes
● NOTICE: To ensure compliance with local power consumption regulations the NETWORK STANDBY function has been removed from the RAP-1580 Software Version V1.88. RS232 communications remain active and provide full controls for integration with automation systems.
● Improved HDMI handshake process to support “Dolby ATMOS for Theater” audio device mode in XBOX ONE X and XBOX ONE S. Note: Require installation and configuration of the Dolby ATMOS driver on XBOX One X and One S.
● Improved HDMI handshake process to fix no ARC function with some 4K HDR TV displays (e.g., LG65UJ750V, LG55UJ7588).
● Fixed a bug where the unit becomes unresponsive after a period of time if connected to the network and polled periodically.
● Updated new DSP firmware version to 1.9.87 with improved feature listed below:
a). Reduced start-up time.
b). Allowed the DSP firmware to be updated via front USB.
Note: To successfully upgrade from Main V1.79 (or older) to Main V1.81 (or newer) the unit must be upgraded 2 times via the front USB using the same V1.81 (or newer) software. Below shows the first and second upgrade results. 1st time: Version 1.78 (or older) to version 1.81 (or newer). Software Information will show DSP software version as V0.0.0. 2nd time: Version 1.81 (or newer) to version 1.81 (or newer). Software Infornation will show DSP V1.9.87 (or newer).
● Added a software version check during power on and display a message if the software is invalid. The message below will be displayed on both TFT and HDMI OSD if any software versions are not valid.
● Changed the default value of AUTO POWER OFF from DISABLE to 20 MINS to meet the latest EU power regulation.
● Reduced the audio and video output delay at power on and when switching source inputs for all audio configurations and all audio formats.
Je viens de tester et Dolby Vision est bien supporté par RAP. Par contre, quelques erreurs de traductions / affichage persistent.
ggregg
Message » 28 Oct 2018 18:40
La version 2.00 vient de sortir :
The RAP-1580 software has been updated to Version 2.00. This release includes several bug fixes and improvements.
Release details are listed below :
● Fixed few translation errors in French menu.
● Implemented same version upgrades via front USB or Network.
● Changed the available setting options of SIGNAL SENSE from Coax 1~3 and Optical 1~3 to VIDEO1~8 and BT to better support the implementation of SIGNAL SENSE AUTO.
Note that SIGNAL SENSE of VEDIO sources will be activated only when their audio input were digital input including oax 1~3, Optical 1~3 or Bluetooth.
● Implemented SIGNAL SENSE AUTO. When SIGNAL SENSE was enabled but the last listening source was not the configured source, user puts unit into STANDBY mode and SIGNAL SENSE still could monitor the status of the configured source.
For example, VIDEO3 was configured as the SIGNAL SENSE source. The user is listening to VIDEO1 source then she puts the unit into STANDBY mode with remote control. The unit begins to monitor the audio input of VIDEO3 and will wake up and switch to the VIDEO3 input when a signal is detected.
If user uses remote control to turn on the unit then the previous input selection is active as in the example the unit would have VIDEO1 as the input.
If there is audio playing on the configured input when the unit is put into STANDBY the then audio must stop for 10 minutes before SIGNAL SENSE POWER ON is available.
● Implemented an error message “SOFTWARE DOWNLOAD FAIL” to indicate a file download error situation.
● Improved the robustness of iPod connection to eliminate connection lost error.
● Fixed a bug flickering white TFT screen occurs occasionally when the unit boots up with STANDBY VIDEO SOURCE enabled.
● Implemented a feature digital audio inputs(i.e. Coaxial 1~3 and Optical 1~3) should be available when configuring TUNER input setup.
● Improved the booting process to eliminate a possible faulty HDMI version error after the unit boots up with USB source selected.
ggregg
Message » 24 Mar 2019 19:07
Je n’arrive pas à activer le son à travers l’hdmi vers ma tv.
Dans le menu « réglage vidéo »/« audio mode » je n’ai que le choix: « pré-output enable » impossible de choisir : « hdmi audio output enable »
Pouvez-vous vérifier si ce paramètre est disponible pour vous?
saules62
Inscription Forum: 25 Déc 2015 11:58
Message » 24 Mar 2019 20:02
Bonsoir saules,
Dans Réglages Vidéo > Audio Mode > je suis sur Pre-Out Activé.
Et dans Réglage Entrées tu as bien assigné l'entrée audio ?
ggregg
Message » 10 Mai 2019 21:25
ggregg a écrit:Bonsoir saules,
Salut ggregg, je possède le ROTEL 1582MKII 2x200W afin d’alim Mes ARIA 936.. vu ta signature tu possède un RMB 1506 c’est pour alimenter quel enceinte ?
BULOBOX
Inscription Forum: 07 Mar 2011 18:54
Message » 11 Mai 2019 9:44
Salut BULOBOX,
Je suis en 5.1.4 et le RMB1506 alimente les 4 petites au plafond.
ggregg
Message » 08 Sep 2019 17:17
Bonjour vous tous..
Je déterre ce post car je m'intéresse à cet ampli, mais, d'une part je ne sais pas si les quelques défauts auquels vous faisiez allusions ont été corrigés par de nouvelles mises à jour, et d'autres part, si mon intérêt pour cet ampli est vraiment une bonne chose..
Voilà, mon installation est composée de deux B&W 805 connectées à un Accuphase E 406V.
Par ailleurs, en hc j'utilise un ampli Pioneer SC-LX85.. qui commence à subir les affres de l'évolution et le manque de décodages et autres évolutions.. sur lequel est branché l'Accuphase en pré out, mes enceintes principale étant incluses dans mon system hc (je n'ai qu'un petit switch au dos de l'Accuphase à utiliser, soit en mode direct pour la hifi, soit pour amplifier mes enceintes "principale" en hc.)
j'y arrive..
Soit j'opte pour ce Rotel et vends mes deux amplis et au passage simplifie mon system, soit je me prends un autre ampli HC et concerve mon Accuphase qui me comble toujours en hifi
meme si quelque fois je râle de devoir me lever pour le mettre en route ou de passer mon bras entre le meuble hifi et l'ampli à la recherche du (tout) petit connecteur pour switcher l'ampli en espérant mettre la mai dessus du premier coup :siffle:
Donc, simplifier mon installation, en évoluant vers un excellent ampli HC, mais, pas au détriment de mon écoute Hifi.
Qu'en pensez vous
Merci pour vos réflexions qui pourront m'éclairer dans ma décision.
:thks:
Lohengrin
