Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 56 invités
JVC DLA-X7900 & X9900 e-Shift UHD (màj)
Message » 10 Oct 2017 13:52
La nouvelle série JVC est maintenant sortie aux US et voici déjà quelques retour
par contre la garantie JVC aux US est de 3 ans ??
sur AVS, Aztar35 a écrit:Of course the X990 is as expected, fantastic. Finally, a display that isn’t a science project but ready to go OTB.
Well, I hope this helps someone as these are my non-technical observations so far:
1)Super bright on a 125 inch Stewart Cima Neve 1.1 gain, in low lamp mode (didn’t measure but best guess is high lamp easily achieves 2000 Lumens, and then some maybe on a new lamp).
2)Text looks razor sharp (in fact everything looks that way as explained below).
3) Convergence/panel alignment is perfect – I mean single-chip DLP perfect. My X750 was great in this area, but this is ridiculous. I’ll say when I first turned it on and looked at the white, pixel shift grid, I did at first see about a 1/8 of a pixel of red fringing in the upper horizontal quadrants, but that was a light emitting aberration and not an alignment issue. I used pixel adjust to try to move the fine pixel red line down but another red line appeared past the white line while the initial red 1/8 pixel red fringing stayed where it was, meaning what I saw was more akin to very mild CA (but this lens is incredible as you’ll see below). I left panel alignment off given convergence was perfect anyway and after the projector warmed up, I re-checked the grid, and this time the red fringing was gone.
4) Bright Corners: On a dark/blank screen, there was absolutely no BC, at least on mine.
5) Sync times seem quicker than on my X750 (not measured)
6) OTB Rec. 709 and DCI-P3average Delta E (have the meter and software, but not measured yet)
7) Eshift5. With it doing the scaling for 1080P source material, it produced a very clean, smooth image. A good test of this feature, however, would be feeding the PJ UHD, but I didn’t have time to try, including HDR.
8) Contrast. I didn’t have time to measure contrast. But I can tell you it’s a very evident improvement over the X750; put it this way, on a blank screen, I had the iris set at -10 (low lamp) and had difficulty discerning my own shadow over the darkened screen. The contrast has been upgraded to mind-blowing!
9) Dynamic Iris. It’s smoother than from what I remember on my X750. I set it to Auto 1 as this gave me a sharper appearance to the picture and never once did I see any pumping.
10) Firing up a few blurays using the PJ’s OTB settings, (except for Auto 1 iris setting with the iris down to -4 and 2.3 gamma) with Natural color and Eshift5 doing the scaling. Many things impressed me comparing to my X750. The first, improved processing: I noticed how “liquidy” smooth and clean the images were. The other thing that struck me was the detail. What a lens!!! I know, it sounds so cliché, but really, I watched a familiar clip and saw things I never saw or noticed on other displays. Shadow detail is outstanding on the X990! And skin tones look natural.
EDIT: I had the opportunity to try some UHD Discs. They looked super detailed with excellent pixel resolution. However, with some UHD material, there was a little more video noise apparent than when compared with the bluray counterpart of the same material (using the same MPC settings).
To sum it up, this projector is the best I've ever owned and seen in operation. Although I haven't seen them all (including the new 4K JVC and Sony lasers), I've seen quite a bit.
Edit Hugo : màj lien AVS, Hugo
vincz
Inscription Forum: 24 Déc 2008 18:40
Message » 10 Oct 2017 14:01
vincz a écrit:La nouvelle série JVC est maintenant sortie aux US et voici déjà quelques retour
Source : http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/2923938-jvc-dla-rs540-x790-x7900-rs640-x990-x9900-20ltd-owners-thread-2.html#post54914642
Idematoa
Inscription Forum: 10 Déc 2006 13:59
Message » 10 Oct 2017 16:58
moudugnou a écrit:je dirai la semaine prochaine à peu près et je confirme le prix. :wink:
En voila deux bonnes nouvelles :love:
Dispo avant la fin du mois et 1OOO €uros de moins que le modèle équivalent de l'année dernière :bravo:
DARCY74
Inscription Forum: 20 Aoû 2008 17:36
Message » 11 Oct 2017 9:46
Je trouve qu'il s'enflamme un peu notre jeune ami américain.. mais ça attise de la curiosité.
Demain si le temps me le permet, je me pencherai sur le 5900, l'eshift est le même.
Cinémotion, enseigne spécialisée en Hifi, Home-Cinéma & salles de cinéma privé
Découvrez ce que les membres de HCFR pensent de nous
moudugnou
Pro-Commercant.
Pro-Commercant.
Inscription Forum: 21 Sep 2003 20:43
Message » 11 Oct 2017 12:54
moudugnou a écrit:Je trouve qu'il s'enflamme un peu notre jeune ami américain.. mais ça attise de la curiosité.
ça m’intéresse!
car pour moi ça sera jvc 5900 ou sony vw260(salle dédiée/écran 3m de base)...il faudrait que j'aille les voir tourner ces 2 là!
pas évident de trouver un projecteur bon en 1080 et en 4k HDR apparemment....
smeagol
Inscription Forum: 08 Oct 2004 20:58
Message » 11 Oct 2017 13:10
ça m’intéresse!
Le rendu hdr commence à devenir plus sympa.. ça dépend aussi de la base d'écran. Mais à part quelques fils, la 4K hdr ne m'a pas encore donné la claque comme du DVD au hé-DVD/Blu-ray
moudugnou
Pro-Commercant.
Pro-Commercant.
Message » 11 Oct 2017 13:45
... un petit scoop... :D
le JVC X7900 prévu en test HCFR, devrait en principe arriver chez son testeur la semaine prochaine @ 18 Oct... :bravo:
Hugo
PS : et MERCI à qui de droit. :thks:
Hugo S
Membre d'Honneur - Président de l'Association & Relations PROs
Message » 11 Oct 2017 13:52
Idematoa
Message » 11 Oct 2017 14:04
Great !!
encore des nouvelles de la serie JVC 900 sur AVS
le HDR a été amélioré avec 2 nouveaux modes et la fonction new DI (HDR dynamique)
donc semaine prochaine, il sera dispo chez tout les revendeurs ?
pas d'info sur le prix du JVC 20ltd ?
vincz
Message » 11 Oct 2017 14:20
J'ai cru comprendre qu'il est à 10K€, mais à confirmer
Diffuseur : JVC RS3200 / Daylight 1.1 REFERENCE DBC, Pana 55VT60 et 50GT30 -- Ampli : Marantz SR 7011, Rotel RMB 1075 -- Enceinte : Focal Chorus 826V, 906, Surround Dome, 800sw -- Source : OPPO 203, OPPO 103D , PANA UB420 (les 3 tweakées)
kaizen
Modérateur Home-Cinéma
Inscription Forum: 16 Sep 2009 18:08
Message » 11 Oct 2017 14:28
Pour ce qui me concerne, je suis toujours étonné de voir des personnes qui associent un projecteur comme le X9900 ici, à un processeur-amplis comme celui utilisé dans ce contexte : Denon X2300... :o
Mais pourquoi pas, tous les goûts sont dans la Nature. :thks:
Hugo
Hugo S
Message » 11 Oct 2017 14:40
Si tu as le temps de jeter un œil (pas trop loin, que tu puisses le récupérer :o ):
- CMD actif (interpolation d'image): le banding est-il toujours présent? (barres verticales, sorte de découpage de l'image visible surtout sur dégradés de couleurs claires, par exemple un soleil dans l'espace)
- avec les JVC actuels, l'eshift avait perdu un réglage (contraste dynamique) donc 3 réglages au lieu de 4 avant, c toujours pareil?
- temps d'accroche HDMI réduit?
ektor
Inscription Forum: 20 Aoû 2007 20:19
Message » 11 Oct 2017 15:01
vincz a écrit:Great !!
Les 4 captures (17 à 20) montrent de bonnes dispositions dans la gestion du HDR :thks: :wink:
Idematoa
Message » 11 Oct 2017 15:04
re Bonjour,
Eh oui... le bébé se présente bien. :wink:
H.
Hugo S
Message » 11 Oct 2017 15:07
Hugo S a écrit:Bonjour,
Hugo
Bonjour Hugo,
Peut être un Marantz AV7704... avec les ampli(s) qui vont bien :lol: :bravo:
Désolé pour le HS
Idematoa
Retourner vers Projecteurs HD
