Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: beb et 25 invités
UGS - Muse edition
Message » 05 Juin 2017 14:57
OK je teste, merci Alex :bravo:
patroussea
Inscription Forum: 25 Fév 2009 12:30
Balanced output, signal out on both phases ?
Message » 13 Juin 2017 22:00
Hi all :)
Have anyone measured that they have signal out on both phases on the balanced output ?
I have NOT (signal on both phases), and we are now debugging this. Alex ,are you sure the code for the Muse volume chip is correct ?
Salut à tous :)
Est-ce que quelqu'un a mesuré qu'ils ont signalé sur les deux phases sur la sortie équilibrée?
Je n'ai PAS, et nous débarrassons maintenant de cela. Alex, êtes-vous sûr que le code de Muse volume chip est correct?
[img]http://s560.photobucket.com/user/Ultimate_photos/media/debugging_1.jpg.html?o=0[img]
Johnny
Ine
Inscription Forum: 02 Fév 2016 10:53
Message » 23 Juin 2017 1:41
HI Alex
I haven´t seen anything on the Wifi board, have you written software for it ? or is this for later ?
Carlos
CeeVee
Inscription Forum: 23 Juin 2017 1:25
Message » 23 Juin 2017 7:16
Hi Johnny,
Is it after I fix the issue with your specific power supply?
On my UGS both phases are working, I have measured this long time ago and will not be able to double check now as I am out of Taiwan till mid of July.
But I don't see why it would not work now.
Hi Carlos,
No, I did close to nothing on this, I just ported the module driver provided by TI in the UGS Muse software environment but did not build any application based on this.
It was more for the case when the board is used in a DAC with WiFi audio streaming, on the preamp it has limited interest.
Do you have anything specific in mind? What is the use case you want to see here?
Alex_twn
Inscription Forum: 10 Nov 2008 6:02
Message » 23 Juin 2017 21:27
Hi Alex :D
The fix with the 2 sec. delay of sending the commands to the Muse chip in software works perfect with my heavy powersupply. Both phases starts up every time I power it up. Thanks a lot ! :D
Johnny
Ine
Balance adjustment with remote ?
Message » 24 Juil 2017 0:46
Hi.
Anyone got the balance adjustment working with the remote control ?
I have been through all the firmwares, but never got this adjustment to work with the remote control.
Alex ?
Google translate:
Salut.
Quelqu'un at-il obtenu l'ajustement de l'équilibre en fonction de la télécommande?
J'ai traversé tous les firmwares, mais je n'ai jamais eu cet ajustement pour fonctionner avec la télécommande.
Alex?
Johnny
Ine
Message » 30 Juil 2017 17:47
Hi Johnny,
I just checked the code and you are right.
Everything is already there for what concerns learning the code and assign it to a remote control button, but then during preamp utilization I forgot to add the decoding of those programmed keys in the main state machine... :).
So when you press the button nothing happens then.
Pretty easy to do, not a big deal, I'll do this when I have a bit of free time.
Alex_twn
Message » 01 Aoû 2017 22:52
Hi Alex :D
Thanks ! I will need a vers.with a 2 sec.delay of the start-up, as you know. Hope you can incorporate that too in the new vers. (for me) ?
Johnny
Ine
Message » 26 Aoû 2017 1:32
Alex_twn a écrit:Hi Johnny,
Hi Alex :D
Had any time to do this fix with the balance control ?
Kind Regards
Johnny
Ine
Message » 03 Oct 2017 15:53
Bonjour Alex, bonjour tout le monde,
J'ai continué à suivre vos exploits depuis le début, je pense que vos réalisations sont à la hauteur de ce beau projet.
Pour ma part j'étais gonflé à bloc, mais après avoir participé à la CG les aléas de la vie ne m'ont pas permis de passer aux choses sérieuses :roll:
Comme je ne prévois pas d'amélioration, je vais mettre en vente les kits qu'Alex m'avait fait parvenir et qui dorment dans un tiroir.
Je propose donc:
2 kits complets (n°1) à 65 € pièce
1 kit n°3 (UC board) à 9 €
2 kits n°5 (modules UGS) à 6 € pièce
Ce sont les prix de la CG, j'offre le port en France métropolitaine.
Quoi qu'il en soit je vais continuer à suivre vos réalisation...
Farfe
Inscription Forum: 05 Nov 2006 13:50
Message » 06 Fév 2018 7:46
Salut Farfe,
As tu vendu ton kit?
Alex_twn
Message » 08 Fév 2018 23:15
Va falloir que je sorte la bestiole de son carton...
beb
Inscription Forum: 02 Mar 2002 2:00
Message » 05 Mar 2018 17:24
Bonjour a tous,
J'ai 2 gars sur DIY audio qui cherchent des kits PCB.
Il y avait des personnes qui ne voulaient plus aller au bout, si vous voulez vendre c'est le moment.
Envoyez moi MP, merci.
Alex_twn
Message » 11 Mai 2018 17:54
Je songe à faire un UGS Muse multicanal mais il me manquerait au moins 2 cartes-mères et 2 modules UGS. Donc si quelqu'un d'autre aurait possiblement un ou deux kits PCB à vendre je serais preneur.
PaulM
Inscription Forum: 16 Nov 2008 3:42
Message » 25 Aoû 2018 19:52
J’ai ressorti les PCB du placard (il est jamais trop tard :D ) mon souci c’est que les booms ne sont plus à jour principalement des résistances et des condensateurs. Vue mon inexpérience dans le domaine quelqu’un pourrait-il m’aider pour savoir quelle caractéristique sont important afin de trouver une ref de remplacement.
Il y a aussi le TPS7A4901 du preamp boards (ref mouser 595-TPS7A4901DGNR)
Bon WE,
terjos
terjos
Inscription Forum: 25 Fév 2006 15:37
