STRA a écrit:Jbl propose desormais sa série 7 amplifiee!
http://www.jblpro.com/www/products/reco ... Ih_yIFPeEc
http://fr.m.audiofanzine.com/enceinte-a ... 35585.html
Pffff... de vieux démons vont me reprendre...
![:ko: :ko:](https://www.homecinema-fr.com/forum/images/smilies/nybbas.gif)
Hugo
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Google Adsense [Bot], haddoken, Moorclos, MrSpock, pp0705 et 85 invités
DTSman a écrit:Quid de l'utilisation de 3*708 passives en frontale dans un HC?
sur AVS, Palewing a écrit:Alright, so I have turned them on not even an hour ago, and I have just gaffer-taped the lights. My impression so far is that I can notice extra "oomph" and deeper punch than the 305s by default (as well they should). When I first turned them on, I thought I still had my EQ on (I had EQd the 305s to compensate a bit for their roll-off), since they had plenty of bass by default. I can also notice a bit more detail/high extension/sharper treble, though still not harsh, at least with what I've tested so far.
I was a bit disappointed in their self-noise, though, since it was of a higher frequency than the 305s, though not higher in volume. But I am very close (less than a meter). If I move 2 meters away, I can still hear the noise with my right ear, if I turn my head to a specific orientation. My right ear is far more sensitive to such things vs my left, though.
I'm going to experiment with the toe-in to see if I can adjust them in such a way that I will be less bothered by the noise. It's still liveable, mind you, and I have already sold my 305s, which are probably being picked up this evening.
Their size is a bit hilarious, though, and the tweeters are currently below ear-level. I'll have to get some stands with better adjustments later.
DTSman a écrit:Up,
Avons nous plus de retour utilisateur de la série 705i / 703i au sein d'une installation HC de dimension modeste. Sur le papier ces enceintes monitoring de proximité pourraient être un choix pertinent.
Avec quel sub de la marque est il recommandé de marier ces enceintes?
