Type : cable secteur
Marque : Wireworld
Modèle et options : Silver Electra 7
Prix de vente : 200 € pièce
Département où la marchandise est visible : 74
Montant des frais d'expédition : inclus dans le prix
Première main : 2 eme
Prix neuf : 500€
Facture disponible :
Date, pays et lieu d'achat :
Numéro de série :
Documentations conservées :
The Silver Electra 7 is a near reference standard power cord designed to give you exceptional performance in high-end AV systems. Silver Electra features Ohno Continuous Cast (OCC) Silver-Clad conductors and Silver-Clad Copper alloy.
Wireworld power cords are designed to solve a completely different set of problems to audio and video cables. An ideal audio or video cable would pass the entire frequency range without alteration. However, an ideal power cord would pass only the 50Hz or 60Hz AC power, while blocking all other frequencies, to prevent power line noise and harmonics from degrading the sound and imaging quality of the system.
Wireworld power cords feature superior shielding & moulded IEC plug featuring silver-clad copper alloy contacts as standard, except Platinum Electra which is fitted with wired IEC utilising OCC® silver-clad copper contacts.
All of the Series 7 cables feature Composilex 2 insulation technology, which minimizes the triboelectric noise produced by conventional insulation materials. Many understand that insulation materials influence the performance of a cable. Wireworld created unique polymer composites designed specifically to optimize fidelity. The benefits of Composilex 2 are especially noticeable on Series 7 Power cables where the reduced interference preserves the purity of the original sound thereby greatly improves performance. These new materials push the boundaries of there expectations for fidelity by letting us hear, see and feel more than ever before.
To achieve that objective, they developed the Fluxfield Technology™, a unique internal structure incorporating Composilex® 2 insulation materials, which maximizes inductive and capacitive fi ltering to absorb power line noise and damp the electrical resonances that other cords and power conditioners cannot tame. Among the innovations of this design are dual low-impedance shields, which are closely coupled to the conductors to cancel unwanted energy.
Site web du constructeur :
Wireworld Silver Electra 7, Power Cable
Length: 1m
Flat design, 7/8 inch wide x 3/8 inch thick and is very flexible to make installation easier
Wire Gauge: 12 AWG
Materials: Ohno Continuous Cast (OCC) Silver-Clad conductors
Insulation: Composilex 2 Insulation reduces interference and greatly improves performance
Globe-Grip Plug, making life easier for you to remove the power cable from your equipment with ease
Suitable for use in any application requiring an IEC(C13) connector
High current handling capabilities
Lifetime Warranty
3 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 6 invités
RESERVES les deux...
- totof50
- Inscription Forum: 28 Aoû 2009 15:42
les 2 cables sont vendus
on peut fermer
on peut fermer
- totof50
3 messages
