Type : 1 préampli + 1 Ampli
Marque : NAKAMICHI
Modèle et options : AV1 pour le préampli et AVP1 pour l'ampli
Prix de vente : 1300 euros l'ensemble ou possibilité d'échange avec un ANTHEM MRX520
Département où la marchandise est visible : 89
Possibilité d'expédition : non(ampli beaucoup trop lourd,environ 37 kg)
Facture disponible : oui
Date, pays et lieu d'achat : 10/04/2015 sur NAKAMICHI UK
Garantie et date d'expiration :jusqu'au 10/04/2017
Emballage d'origine conservé :oui
Préampli AV1
Multi-signal inputs and outputs
DAB/DAB+/FM Tuner
Bluetooth Audio Streaming, with APT-X support
Support wide range ways of audio processing, including HD formats, such as Dolby TrueHD, DTS Master, Dolby Digital Plus, DTS HRA and SD formats such as PRO-LOGIC Dolby DIGITAL, DOLBY DIGITAL-EX, DTS, DTS-ES, DTS NEO:6
Support multiple HDMI video formats
Supports HDMI CEC Control and has HDMI ARC Audio Channel
Professional OSD. Any operations of the unit can be seen on the TV display.
USB port to connect to PC for software upgrading, parameter setting, preferences selection.
Customized settings and memory
Full function remote control (included)
Automatic Intelligent Room Calibration (Free Microphone Supplied)
Audio Management: Front, Centre, Surround, Rear Surround, Front Height and Subwoofer Speakers have adjustable crossover points in 20 steps from 40Hz to 250Hz
Crossover slopes can be set at 12db or 24db per Octave
11 Band Parametric Equalizer
Bi-Amping feature for front L and R channels
HDMI 1.4 input and output
4-Way HDMI inputs, 1-Way HDMI output and 1 HDMI Quick Switch
All legacy video inputs can be scaled and output over HDMI at up to 1080p, YUV, RGB, supports DVI mode, Supports HD Audio, 8CH LPCM
Supports HDMI CEC control
Supports HDMI Arc Audio control
Supports the following video inputs and outputs: HDMI/DVI 480p, 576p, 720p50, 720p60, 1080i50, 1080i60, 1080p50, 1080p60 and 1080p24
Ampli AVP1
Amplifier Gain: 29dB Input Sensitivity: 1.1Vrms, 47Kohm Power Output: 250W with 4ohm load, 2 Channels Driven 170W with 4ohm load, All Channels Driven 150W with 8ohm load, 2 Channels Driven 110W with 8ohm load, All Channels Driven Signal to Noise Ratio Unbalanced Output: ≥107dB Balanced Output: ≥110dB THD+N: ≤0.06% (Rated Condition: A weighting) Frequency response: 10hz-60Khz (+/-3dB) Other Power: AC110 to 230V, 50/60HZ Power Supply: high output toroidal transformer with 90,000uF storage capacitance Max Power Consumption: <1900w Standby Power: <0.5W Nett Weight: 32 kg/70.5 lbs Gross Weight: 34.6 kg/76.2 lbs Packing Size: 570mm x 616mm x 330mm Unit Size: 430mm (W) x 450mm (D) x 200mm (H) Supplied with RCA inputs and fully balanced XLR inputs High Quality Binding posts, accepts 4mm banana plugs or heavy gauge speaker cables
Site web du constructeur : http://www.nakamichi.co.uk/
livré avec tous les accessoires d'origine + 7 câbles XLR.
excellent état et fonctionne à merveille,mais besoin d'un intégrés qui est plus WAF
je vends l'ensemble,donc non dissociable.
7 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 15 invités
VENDU : Ensemble NAKAMICHI : 1 préampli AV1 + 1 Ampli AVP1
- mine2rien89
- Inscription Forum: 07 Nov 2004 17:52
Vente séparée possible:
Préampli AV1 : 450 euros fdpi
Ampli AVP : 750 euros fdpi
- mine2rien89
baisse à 900 euros le lot ,à prendre sur place. ![:bravo: :bravo:](https://www.homecinema-fr.com/forum/images/smilies/thumbs_up.gif)
- mine2rien89
7 messages
