Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: boby6kiler, imarco, michael63, papounay, Temearoo, thivame et 67 invités
POPCORN HOUR A-500 & PRO 4K VXP DAC DSD HEVC NMJ Iso2D/3D
Message » 21 Juil 2016 8:59
Firmware version Officielle
http://www.popcorn-hour-fr.com/forum/sh ... p?tid=9183
Changelog complet
Firmware Release Notes:
- Fixed PGS drop during multiple ts seamless transition
- Fixed certain APE version 3.97 or earlier unable to start playback issue
- Fixed some ASS next line tag unable to take effect issue
- Set ASS border color to default black if primary color happens to be same as border color
- Fixed SRT color tag unable to display at correct position when encoding in other languages like Greek
- Fixed WAV PCM 5.0 wrong channels mapping issue
- Fixed Youtube video with pipe character title crash issue
- Fixed some PGS subtitle show wrong position and corrupted subtitle display issue
- Removed redundant 1KB size indicator for BDMV or DVD folder
- Added support for multi-channels ALAC codec (M4A). Note: Gapless playback and ID3 support will implement later.
- Fixed PGS sometimes display too fast issue
- Fixed some FLAC skip few seconds during gapless transition
- Fixed WAV 3, 4, 5 and 7.1 channels unable to start playback issue
- Changed LPCM 3 channels layout from 2.1 to 3.0
- Fixed BDMV or BDISO, M2TS, TS unable to auto stop playback or repeat after finish issue
- Fixed some MPEG AVI playback has no video display issue
- Fixed vobsub 3D rendering issue
- Fixed vobsub and sub idx sometime not being rendered issue
- Fixed external subtitle out of sync after seeking in BDISO or BDMV issue
- Fixed 25fps HEVC video not showing issue when framerate sync turn on
- Fixed setting display to 4K output causing no display upon reboot issue
- Fixed NMJ Wall and List view browsing error issue
- Fixed some FLAC causing static sound and skip during gapless playback transition issue
- Fixed SACD ISO with upper case extension (ISO) unable to start playback issue
- Fixed Component output resolution issue
- Fixed SACD DST (Stereo) playback issue
- Fixed TVMode + Color key not functioning issue
- Disable HDMI CEC completely
- Fixed inconsistent TV mode before and after playback when framerate sync is on and TV mode is set to auto
- Fixed 3D text subtitle sometimes have 500ms - 1s delay issue when subtitle rendered back to back
- Fixed PGS with fading effect unable to display properly issue
- Added LAME Padding handling for MP3 seamless playback
- Fixed FLAC, WAV and MP3 seamless playback with short clips have small glitch issue
- Fixed now playing Lyrics panel rendering issues
- Added ID3 Year tag into get_current_aod_info API
- Changed now playing artist, album, genre and audio resolution label to icon display
- Significant improvement on NMJ Wall and Listing loading speed
- Fixed some vobsub rendering problem
- Fixed some ATMOS MKV file passthrough no sound issue
- Fixed TrueHD passthrough sometimes have no audio output after switching audio track issue
- Added audio sampling info
- Applied rsize=8192 for NFS mount
- Added DSD Gain option
- Added External Video Scaler option
- Added PCM SPDIF option to allow HDMI output PCM up to 24 bit
- Fixed some MP4 encounter crash issue
- Fixed some H264 MP4 playback have no video display
- Fixed some FLAC have noise in gapless playback issue
- Fixed DSD gapless have minor pop sound before next song start playback issue
- Fixed BDMV unable to get subtitle entry when it placed at same level as BDMV folder
- Fixed some video clips show wrong fps info issue
- Fixed SSA or ASS has vertical top alignment overlapped timestamp causing crash issue
- Fixed position tag in SRT unable to show properly in full-scale OSD
- Fixed color tag in SRT unable to take effect
- Fixed SRT with SSA position tag (0,0) causing crash issue
- Fixed SSA or ASS position is not relative to video frame aspect ratio
- Fixed some video clips with no audio stream keep trigger rebuffering issue.
- Fixed SAMBA share cannot save credentials in shortcut or Home Add On
- Fixed MKV AAC multichannels playback have no audio output issue
- Fixed some HEVC MKV causing video freeze issue
- Added XAVC support
- Fixed LG 4K OLED TV doesn't switch back to 2D after stop the 3D playback issue
dreamy
Pro-Commercant
Pro-Commercant
Inscription Forum: 08 Nov 2004 0:07
Message » 21 Juil 2016 15:37
Plus très actifs les topics Open Cloud :zzzz: Ça leur permettra peut etre de réfléchir....
plouf34
Inscription Forum: 26 Sep 2007 13:04
Message » 21 Juil 2016 16:31
Belle mise à jour une fois de plus !
Je suis persuadé que le A500 et le Vten sont les meilleurs appareils pour la lecture 3D et le rendu des sous titres, le nombre de mises à jour concernant ces deux points est réellement impressionnant.
@Plouf34 : c'est effectivement beaucoup plus calme et c'est très bien comme ça.
Idargos
Inscription Forum: 25 Avr 2009 18:02
Message » 02 Aoû 2016 9:37
Review assez complète sur le Forum AVS
http://www.avsforum.com/forum/39-networ ... eview.html
dreamy
Pro-Commercant
Pro-Commercant
Message » 02 Aoû 2016 15:03
J'hésite à me prendre le A500 car je cherche un (très) bon lecteur de fichier MKV (ma Freebox rencontre de micro-coupures du son avec les mkv, c'est un problème connu chez Free depuis plus de 4 ans mais le dossier n'avance pas...)
Quelqu'un à pu un peu plus le tester ?
J'aimerai savoir si il y a des soucis de lecture sur les gros fichiers au format MKV
Merci d'avance pour vos retours (si il y en a)
Sebass
Inscription Forum: 01 Déc 2005 14:37
Message » 02 Aoû 2016 19:11
actuellement j'ai un A 410 j'hésite pour passer au A 500, quelles sont les points d'amélioration qui pourrait me faire basculer selon vous?
da.man
Inscription Forum: 15 Aoû 2013 21:51
Message » 02 Aoû 2016 20:07
Des mise à jour de NMJ ont eu lieu et cela a changé la langue. Je me retrouve avec une interface en Chinois à la place du Frnaçais. Comment changer la langue ! :hein:
Hifi : PCH A500, ONKYO PR-SC5009, NAKAMICHI 682ZX, AIWA AMR 200 DAB+ & Nubert NuPro A200 , HC : Panasonic DMP-400, Hisense 55U7KQ, SidneyAR12 (Hypex700),, BLON B20+ Hidisz AP80 + iBasso.Chanteur : ContreTénor
gbaya
Inscription Forum: 14 Avr 2003 18:47
Message » 04 Aoû 2016 22:25
da.man a écrit:Bonjour,
Ça va t obliger a apprendre le chinois...lol
Image : LG G1 77 pouces,
Son : marantz 8015, 2 kef ls50, 1 kef r2c meta, 2 surround cabasse Eole4, 1 sub rel 1508 predator, un arendal 1961 1s
Source panasonic 820
fredz1432
Inscription Forum: 04 Fév 2011 10:13
Message » 04 Aoû 2016 23:06
Pas beaucoup de retours sur le 500 et 500pro ou pro M..
Ni en utilisateurs ou en tests ???
Y a t il des sites de tests j'ai rien vu sur le Web ? ou des utilisateurs ? ou personnes en veux de ces bijoux !!?
:wtf:
aquila
Inscription Forum: 27 Fév 2006 23:00
Message » 04 Aoû 2016 23:17
Tu as une review cinq posts plus haut du A500. Pour le A500 pro, les premiers exemplaires viennent juste d'être livrés, les premiers tests ne vont pas tarder :wink:
Idargos
Message » 18 Aoû 2016 22:02
dreamy
Pro-Commercant
Pro-Commercant
Message » 24 Aoû 2016 10:00
Boot sur Android 6 disponible sur le A-500 PRO
Changelog
Android OTA Update Steps:
1. Power off the A-500 PRO/A-500 PRO-U
2. Toggle the dual boot switch to Android
3. Power up the device and boot into Android
4, Copy the downloaded file into the root directory of the USB thumb drive
5. Plug the USB thumb drive into USB port of A-500 PRO/A-500 PRO-U
6. Launch System Updater app in home screen
7. In System Updater, turn on Wipe Data and Wipe Cache option
8. Select the downloaded OTA file from USB thumb drive with OTA Package menu
9. Click Start Install to start the OTA update process
1. Éteignez l'A-500 PRO / A-500 PRO-U
2. Basculer le boot sur Android
3. Démarrez l'appareil
4, Copiez le fichier téléchargé zip à la racine de la clé USB
5. Branchez la clé USB dans le port USB de l'A-500 PRO
6. Lancez la mise à jour système de mise à jour de l'application sur l'écran d'accueil à droite
7. Système de mise à jour, activez Validez les données et l'option Cache
8. Sélectionnez le fichier OTA zip situé à la racine de clé USB
9. Cliquez sur Installer pour lancer le processus de mise à jour OTA
http://www.popcorn-hour-fr.com/forum/sh ... p?tid=9240
dreamy
Pro-Commercant
Pro-Commercant
Message » 28 Aoû 2016 21:54
un ami vient de recevoir son A500PRO mais il lui est impossible de le faire fonctionner avec son vidéoprojecteur SONY VPL-HW45ES.
Il démarre bien puis image noir.
quand il teste sur une télé tout se passe bien...
le problème doit venir d'une configuration de sortie d'image lais aucune idée d’où cela peut venir...
si vous avez une idée merci beaucoup.
TATAOUINE974
Inscription Forum: 03 Fév 2012 16:13
Message » 30 Aoû 2016 18:52
Personne n'aurait la réponse au problème de compatibilité avec le vidéoprojecteur sony ?
TATAOUINE974
Message » 31 Aoû 2016 12:19
Il n'aurait pas un câble Active HD ou autre cable actif à base de chipset Marseille ton ami par hasard ? :hehe:
Parce que l'écran noir c'est exactement le genre de problème que j'avais avec ce genre de cochonnerie... ;)
De mon côté aucun problème de démarrage avec mon petit projo BenQ... ;)
Même pas terminé le câblage audio de ma salle de cinéma j'ai tellement la tête dans le guidon j'en peux plus...
Entre les travaux, le boulot, les enfants... La nouvelle maison est :love: :love: :love: mais j'ai perdu 5 Kg depuis 15 jours... :o
Juste eu le temps de tester la sortie casque du A-500 Pro mais vraiment pas de quoi faire un compte rendu pour le moment...
En résumé c'est plutôt pas mal, mais j'ai pas eu le temps de creuser vu que les enceintes ne sont même pas connectées...
En plus j'ai un nouveau caisson de basse de la mort qui tue : un XTZ 12.17... :love: :love: :love:
basthi
basthi
Inscription Forum: 15 Mai 2006 23:12
