I want to comment on information which appeared at forums that we stopped production of Odin's because of the appeared defects of drivers. Probably, I was understood not correctly. The true reason for a suspension of production - the shortage of accessories, namely, drivers. We make them in St. Petersburg and initially we made 100 pieces (50 couples). We sent the last Odin's from the first party in November. At the end of October, we were ordered accessories for new Odin's (200 drivers). The approximate term of production of drivers makes about 2-3 months: order of magnets, production of a membrane, assembly of drivers, testing, assembly of Odin's. It is very difficult to process, especially considering that each headphone gather manually. Yes, certainly, the arisen problems with several drivers, forced us to finish in addition a design but is absolutely insignificant as all defects were eliminated in the course of preparation of new accessories. I hope, I clearly explained everything
Also, I want to report true characteristics of Kennerton Vali. On the site, outdated information which we didn't update from the moment of presentation of the initial version is specified. During this time, the design of headphones very strongly changed. Therefore, I want to report true technical characteristics:
Driver Unit: 50 mm
Frequency Response: 10-28000 Hz
Sensitivity: 100 dB/mW
Impedance: 32 Ohm
Maximum Input Power: 500 mW
Cord length: 2 m detachable 4-pin mini XLR OFC cable (3.5/6.3 mm)
