Modérateurs: Modération Forum Univers Casques, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: fouyas, myocastor, ok3d, pierrepauljack et 38 invités
Casques Kennerton (màj)
Message » 11 Fév 2016 15:38
I want to comment on information which appeared at forums that we stopped production of Odin's because of the appeared defects of drivers. Probably, I was understood not correctly. The true reason for a suspension of production - the shortage of accessories, namely, drivers. We make them in St. Petersburg and initially we made 100 pieces (50 couples). We sent the last Odin's from the first party in November. At the end of October, we were ordered accessories for new Odin's (200 drivers). The approximate term of production of drivers makes about 2-3 months: order of magnets, production of a membrane, assembly of drivers, testing, assembly of Odin's. It is very difficult to process, especially considering that each headphone gather manually. Yes, certainly, the arisen problems with several drivers, forced us to finish in addition a design but is absolutely insignificant as all defects were eliminated in the course of preparation of new accessories. I hope, I clearly explained everything :)
Also, I want to report true characteristics of Kennerton Vali. On the site, outdated information which we didn't update from the moment of presentation of the initial version is specified. During this time, the design of headphones very strongly changed. Therefore, I want to report true technical characteristics:
Driver Unit: 50 mm
Frequency Response: 10-28000 Hz
Sensitivity: 100 dB/mW
Impedance: 32 Ohm
Maximum Input Power: 500 mW
Cord length: 2 m detachable 4-pin mini XLR OFC cable (3.5/6.3 mm)
Vasily Berillo
Pro-Commercant
Pro-Commercant
Inscription Forum: 13 Avr 2015 15:50
Message » 11 Fév 2016 19:27
Je tiens à commenter l'information apparue sur des forum disant que nous avons arrêté la production de l'Odin à cause de l'apparition de défauts sur les drivers. J'ai probablement été mal compris. La vraie raison de la suspension de la production est la pénurie d'accessoires, à savoir les drivers. Nous les fabriquons à Saint Petersbourg et initialement nous avions fabriqué 100 pièces (50 paires). Nous avons envoyé les derniers Odin dans la première partie du mois de novembre. A la fin du mois d'octobre, nous avons commandé des accessoires pour de nouveaux Odin (200 drivers). Le temps de production des drivers est d'approximativement deux- trois mois : Les commandes d'aimants, la production des membranes, assemblage des drivers, les tests et l'assemblage des Odin. C'est très dur à réaliser surtout si on considère que chaque casque est assemblé manuellement. Oui, certainement, les problèmes survenus sur quelques drivers nous ont forcé à faire une modification mais c'est absolument insignifiant dans le sens où tous les défauts ont été éliminés pendant la préparation des nouveau accessoires. J'espère que j'ai tout expliqué clairement :)
Je souhaite aussi reporter les véritables caractéristiques du Kennerton Vali. Sur le site, il y a des informations erronées qui n'ont pas été mises à jour depuis la présentation de la version initiale. Pendant ce temps, le design du casque a été
fortement changé. Par conséquent, je voudrais reporter les véritables caractéristiques techniques :
Driver : 50mm
Réponse en fréquences : 10-28000 Hz
Sensibilité : 100 dB/mW
Impédance : 32 Ohm
Puissance admissible maximum : 500mW
Longueur du cordon détachable en cuivre OFC : 2m avec mini XLR 4 pin et Jack 3.5mm / 6.35mm
Pierre PAYA
Inscription Forum: 09 Avr 2011 18:53
Message » 11 Fév 2016 21:25
Merci Vasily ! thanks for your answer and good continuation. You really make a good job. :thks:
cleriensis
Message » 11 Fév 2016 21:31
cleriensis a écrit:Merci Vasily ! thanks for your answer and good continuation. You really make a good job. :thks:
Ben, tout pareil !!! :bravo: :mdr:
kéké 26
Inscription Forum: 03 Juin 2007 17:15
Message » 12 Fév 2016 20:43
A propos d'Audirvana j'ai installé, suite à une série de tests sur mon ADSL peu rapide, la dernière mouture béta fournie par Damien Plisson pour gérer le streaming Qobuz HiRes convenablement. C'est une réussite (peut-être le coup de pouce des serveurs de Xandrie ?).
D'ailleurs le prochain A+ Remote streamera Qobuz.
Ce logiciel est beaucoup travaillé techniquement pour fournir au DAC des données numériques les plus fiables possibles à partir d'une carte d'ordi et Mr Plisson est très réactif en cas de soucis.
Juste noter qu'avec El Capitan j'ai des plantages du MacBook 2015 qui nécessitent la raz du SMC qui pourraient provenir d'un problème de gestion des DACs. Mr Plisson indique que la prochaine maj résoudra ce point.
En comparaison de Daphile, Audirvana Plus permet l'ajout des AU et je pensais aux ToneBoosters (EQ ou Isone).
Qu'en disent les spécialistes ?
cladane
Contributeur HCFR 2018
Inscription Forum: 22 Oct 2013 9:42
Message » 12 Fév 2016 20:45
:bravo: Merci pour ce retour.
yacine60180
Inscription Forum: 17 Fév 2012 14:06
Message » 12 Fév 2016 22:10
Bonsoir, avec mes modestes moyens, voici une FR assez grossière de mon K. Odin, avec un micro portable Phonic PAA3, oreillette gauche (mesurée) plaquée contre l’accoudoir d'un vieux fauteuil en cuir (assez élimé :oops: ) et tige du micro glissée à l'intérieur.
Quelques remarques à faire:
Je dois racheter un fauteuil en cuir (plus présentable) :wink:
La note la plus grave d'une guitare basse (41 Hz) est parfaitement reproduite.
Il y a un creux vers 5-6.3 KHz et un petit pic vers 8-10 KHz
La courbe est plutôt plate entre 40 Hz et 3.15 KHz et tient dans +/-3 dB
Bonne soirée.
Eric
eric65
Inscription Forum: 29 Sep 2010 12:38
Message » 13 Fév 2016 13:20
Attention @yacine que selon les caprices de l'ADSL même avec la dernière mouture optimisée d'Audirvana j'ai des interruptions de flux. J'ai demandé à Mr Plisson de placer un paramètre pour streamer en CD, pour les abonnés Sublime, comme dans les applis Qobuz.
Merci @eric65 pour les mesures.
Le fait d'acheter le RPKV au lieu d'un Égoista devrait vous permettre de changer le canapé, qu'en pensez-vous ?
Le 41Hz ne m'étonne pas du fait que j'ai remarqué que l'Odin descend assez bas dans des enregistrements bien captés. Ainsi un bon test pour l'amateur de piano (Erard de 1837):
http://www.qobuz.com/fr-fr/album/schuma ... 9020219829
(l'Allegro Affetuoso si grave et romantique)
Là le DAC a son rôle à jouer pour fournir la matière à l'ampli et au casque. Très bon pour un Audiomat :bravo: par ex ou TotalDAC ?
cladane
Message » 13 Fév 2016 20:11
Je vais attendre que le cuir des accoudoirs de mon fauteuil soit troué avant d'envisager d'en racheter un autre. :mdr:
Sinon, voici une petite photo (HD) de l'oreillette droite de mon K. Odin, ce matin, avec un joli rayon de soleil, avant que le ciel ne soit envahi de bien tristes nuages chargés de pluie ... :(
Everything is in the picture: a sound, "beautiful", hot, rich, strong, solid, powerful, accurate, fast, clear, detailed and natural.
Eric
eric65
Message » 14 Fév 2016 9:31
Très jolie photo...
... C'est quoi ce petit bout gris sur le bois ??? :wink:
kéké 26
Message » 14 Fév 2016 10:56
C'est un petit bout d'adhésif gris (genre isolant électrique) découpé qui me sert de repère pour régler la rotation des pads dans la bonne position (un angle précis), et ne pas perdre cette position (Nb : il existe un repère identique sur chacun des deux pads) (NB bis : la couture antérieure du pad (la partie la plus mince) doit être alignée avec ce repère) ; dans cette position de rotation du pad, et avec mes réglages, et avec ma physionomie de tête, l'étanchéité des pads est optimale, ainsi que la répartition de pressions sur les tempes, les mâchoires et derrière l'oreille.
Voilà tout ! Ce n'était pas pour être décoratif, quoique l'on est en droit de choisir la couleur de l'adhésif suivant son humeur et ses goûts du jour ! temps gris, pluvieux = adhésif gris :wink:
Eric
eric65
Message » 14 Fév 2016 10:59
OK, merci !!! :bravo:
Moi j'attends mon bandeau de course.... Je devais l'avoir samedi...... J'espère que je l'aurais mardi !!! :roll:
kéké 26
Message » 14 Fév 2016 12:44
Vivement mardi, donc ! :)
Sinon, (cette fois-ci pour dub), tu connais cette étrange association de musiciens (d'un autre temps ?), et le nom des instruments "barbares" qu'ils manipulent bizarrement (en particulier le port de l'archer de l'instrument de gauche (celui avec trop de cordes ?).
Sinon, d'après toi, à l'estime, ces instruments bizarres (je me répète) descendent jusqu'à combien d'Hertz (au plus bas) ?
https://www.youtube.com/watch?v=5Frq7rjEGzs
très belle vidéo d'instruments "bizarres" ... :wink:
Eric
eric65
Message » 14 Fév 2016 16:06
Viole de gambe, guitare et harpe triple des instruments barbares ? :o
roland_de_lassus
Message » 14 Fév 2016 16:43
"Barbare" pour le profane que je suis :wink:
Je n'y connais rien en instruments à cordes (à part le Piano), et encore moins dans les instruments à cordes anciens, et je suis surpris par le nombre de cordes, inhabituel, de ces instruments anciens : 7 pour la viole de gambe , ??? pour la harpe triple, et 4 (?) pour la "guitare".
Une certitude, tous ces instruments anciens sonnent bien avec l'Odin :)
Eric
eric65
