The latest iScan processor provides VRS ClearView for upscaling to UHD/4K and enhancing less-than-perfect video.
UHD/4K TVs are quickly becoming mainstream as prices fall and manufacturers migrate UHD's higher pixel density to their mid-range and lower TVs. But most of the content being viewed on all those UHDTVs is still HD or even (shudder!) SD, so a high-quality upscaler is a must for those taking the UHD plunge. Many UHDTVs have excellent upscalers built in, but some don't.
If your UHDTV isn't up to snuff in the upscaling department—and even if it is—DVDO has an inexpensive solution that is likely to improve the look of HD and SD content, even highly compressed online-streaming content. The company just introduced the latest in its highly regarded iScan video-processor line called the iScan Micro, which implements the acclaimed VRS ClearView technology with adaptive scaling, detail and edge enhancement, mosquito-noise reduction, and video smoothing. In addition, it processes video and graphics independently, optimizing each as needed.
Of course, most AVS members scoff at edge enhancement, but there are a few exceptions—for example, the DarbeeVision Darblet DVP 5000 is found in many AVS members' home theaters, though it does not upscale to UHD/4K. Similarly, the various versions of DVDO's iScan with VRS have long been regarded as superb image processor/enhancers, and I imagine the newest iScan is no different.
The iScan Micro is a tiny device that supports HDMI 2.0 at 18 Gbps and plugs into one of the TV's HDMI ports. (It does not support HDCP 2.2, but that's not important, at least not for a while, since it's only expecting to receive HD and SD signals.) It comes with a remote that lets you select the level of processing, and it sports a port for the included IR sensor, which is important since the unit itself is hidden behind the TV. Even better, it will carry a price tag of only $129 when it ships by mid-year.
Many readers will notice that the iScan Micro is very similar to the Seiki U-Vision, which sells for around $50. Is the iScan Micro 2.5 times better? Only a direct comparison will tell, an exercise I intend to conduct when the iScan Micro becomes available, so stay tuned for that!
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: bull00, LennyF et 7 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
DVDO Iscan Micro 4K/UHD
Voir cette news sur AVSForum : http://www.avsforum.com/forum/37-video- ... ancer.html
- alex_t
- Membre HCFR Contributeur
- Inscription Forum: 29 Oct 2005 23:04
news intéressante, vivement un test, ensuite si il est a plus de 130 euros en france , faut voir car le dvdo iscan mini peut se trouver a 250 euros, bon ce n'est pas le meme style de produit... en tout ca belle initiative de dvdo, une date de sortie prévue ?
- TITOK
- Inscription Forum: 06 Jan 2007 12:55
Je n'ai pas vu d'annonce de date de sortie pour le moment.
a+
a+
- alex_t
c'est un peu un equivalent des cables hdelite active, thor, seiki et philips? en plus poussé...
- totof50
- Inscription Forum: 28 Aoû 2009 15:42
C'est un Mini simplifié quoi ... en tous cas on dirait bien !
Bizarre qu'on en entende plus parler alors que la fiche du produit est disponible sur le site officiel.
http://dvdo.com/iScanMicro/
- Dirty Vincent
- Inscription Forum: 24 Juil 2000 2:00
- Mumakil
- Inscription Forum: 20 Juil 2014 18:07
194 euros, pas donné face au mini a 250
j'espérais un prix légèrement inferieur !
bon est ce quelqu'un l'as testé ?
sinon il est dispo sur amazon Allemagne pour 150 euros
- TITOK
"Bradé" à moins de 89 EUR (hors fdp) sur Vente Privée (vente "point bleu").
Je suis tombé sur ce thread en cherchant des informations sur ce produit justement.
- Sim_v
- Inscription Forum: 11 Sep 2002 10:20
Il est à 150e maintenant sur Amazon.
- MisterYacko
- Inscription Forum: 19 Nov 2009 10:32
il est de nouveau à 102 euros FDP gratuit
https://www.amazon.fr/DVDO-iScan-Micro-C%C3%A2ble-upscaling/dp/B014D0ASFE
- ANGEL
- Inscription Forum: 01 Juin 2000 2:00
Bonjour à tous.
Je déterre ce sujet pour avoir l'avis de possesseurs du iscan micro.
Avez vous comme un cadre de pixel blancs qui forment un cadre autour de l'image lorsqu'il est branché ?
Particulièrement visible lors des scènes claires.
Je pense que mon iscan micro est défectueux.
Merci de votre aide.
- Mastarddedijon
- Inscription Forum: 13 Déc 2016 16:01
C'est peut être un excès de filtres de sharpness cumulés.
Essais de réduire le sharpness de ta source et de ton diffuseur.
J'ai trifouillé tous les réglages de la télé. Oled lg oled 65c6. En fin de compte je pense que c est du à la source. Cube canal sat.
Pas de soucis sur tnt hertzienne. L iscan micro ne fait qu accentuer le problème. Sinon avec le cube en 740p belle image de 2160p sur l écran. Sauf ce maudits cadre... (:
Merci pour ton aide en tous cas.
- Mastarddedijon
Bonjour, j ai testé plusieurs câbles HD active , thor , seiki et franchement il y a pas photos l iscan micro et loin devant....
- jemulle
- Inscription Forum: 30 Oct 2010 11:59
21 messages
Retourner vers Processeurs Vidéo
