Pour ma part je suis content que le changement se fasse plus vite, j'ai hate d'essayer leur nouvelle puce.
Voila le message de futeko :
It is with much disappointment that we have to report that Himedia have discontinued Q5 4K3D.
We were informed of the news late last week with it running contrary to what we had been previously told. The delay in us making a public statement about it was to give Himedia a chance to issue their own / reconsider.
The decision has been prompted by HiSilicon not wishing to continue production of the HiSilicon Hi3798C chipset.
It seems nonsensical to us to discontinue Q5 4K3D when it has become established as the best option for high-end video via Android, but it's not our decision.
Q10 4K3D sales will continue until Himedia run out of stock. We will have more Q10 4K3D next week.
I would speculate that this decision during CES was due to the very positive feedback received about the new V200 Himedia/HiSilicon products launching in April. Hopefully it's an indication that these products will be outstanding.
However, nobody knows for sure what the new HiSilicon products will be like at launch. Based on almost every other product ever it's unlikely they will be the perfect finished article. For this reason, if you want a product with nearly 2 years firmware development behind it that works great now for 3D/7.1 then you may want to buy a Q10 4K3D whilst you can. They won't be around for much longer.
Himedia will continue to support Q5/Q10 4K3D as evidenced by the new firmware last week.
Bonjour a tous,
- Je vous presente ma derniere acquisition, le Himedia Q5 4k/3D, une box qui a deja environs 18 mois de vie.
![Image](http://www.himediatech.com/images/Q5ivindex.jpg)
Site Officiel :
http://www.himediatech.com/q5iv.html
Lien Officiel Himedia Q5 4k 3D:
Ou l'acheter en Europe :
- Vous avez le site Futeko, qui vend les produits Himedia, ils ne vends que les modeles europeens, il installe les derniers FW avant la livraison.
http://www.futeko.com/browse.php?cat=featured
Le lien des mise a jour pour la version Europeenne
http://www.futeko.com/newforum/index.php?topic=493.0
La derniere en date du 30 decembre 2015, c'est la 3.0.3
HiControl
Une apk pour controler votre box Himedia avec votre smartphone
![Image](http://www.himediatech.com/images/inside_9.jpg)
http://www.mediafire.com/download/9yjnh ... ol_hmd.apk
HiShare
Une apk pour diffuser le contenu de votre smartphone sur une tv
![Image](http://www.himediatech.com/images/inside_10.jpg)
http://www.mediafire.com/download/8duh6 ... e2.0.7.apk
Caracteristique :
Chipset Model HiSilicon Hi3798C
Max Resolution 4K30
Chipset Family ARM Cortex A9
Cores 4
Chipset Ghz 2
GPU Mali450(x8)
OS Version KitKat
RAM (GB) 2
Flash Memory (GB) 8
USB Host 3
2 USB Version 2.0
1 USB Version 3.0
SD 1
SD Card Type SD
Other Storage External SATA
Bluetooth No
Wired Network Gigabit
Wireless Network Wi-Fi(n)
HDMI 1
Composite Video 1
HDMI Version 1.4
Stereo L/R Audio 1
S/PDIF TOSLink 1
S/PDIF Coaxial 1
Video Formats (Codecs) MPEG1/2/4 up to 4K30, H.264/AVC up to 4K30, H.265 up to 4K30, VC-1, REALVIDEO 8/9/10 up to 4K30
Audio Formats (Codecs) MP3, WMA, AAC, APE, FLAC, WAV, DTS,
Dolby Digital, AC3 up to 7.1.
3D SBS Yes
3D Top Bottom Yes
3D Frame Packing Yes
3D Frame Sequential No
Blu-Ray 3D Yes
DVD ISO Yes
Blu-Ray ISO Yes. BD-Lite
Dolby Digital Downmix Yes
Dolby Digital Passthrough Yes
Dolby TrueHD Downmix Yes
Dolby TrueHD Passthrough Yes
DTS Downmix Yes
DTS Passthrough Yes
DTS-HD MA Downmix Yes
DTS-HD MA Passthrough Yes
Kodi Android
Play Store Yes
Fan No
Supplied Remote IR
Largeur (mm) 170
profondeur (mm) 115
Hauteur (mm) 25
IMPORTANT :
•Make sure you get the English-branded version of Q5 or Q10. (as firmwares are different)
•Install latest Q5 firmware.
•After reboot, in HiMedia settings, set HDMI output to 'RAW', HBR to 'RAW 7.1', and 1080P24HZ to 'On'. Under Image Quality, set Display Mode to 'Normal' and ExpressXEngine to 'Optimal'
•Grab latest Kodi APK (the ARM version) and install.
•Launch Kodi, let it sit for a minute, then quit out.
•Install HiMediaWrapper APK & set-up as instructed here. This file is necessary to have Kodi use HiMediaPlayer to play your videos, especially for 3D ISO's and HD audio.
•For the few 3D titles that have right-eye first, after playback starts in HiMediaPlayer, bring up the on-screen menu to find left/right swap option. You'll also need to use the player menu to enabled 3D SBS or 3D TAB modes for those MKV's (as HiMediaPlayer ignores Kodi's 3D file naming)
Maximum image sharpness?
For maximum image sharpness Q5/Q10/M3 screen scale should be set to maximum and your TV/projector should be set to Screen Fit. On the Q5/Q10/M3 go Settings - Display - Screen Size Position and set all dimensions to the largest possible. Settings for your TV/projector will differ according to brand, but on a Samsung TV press the P.SIZE button on remote until you get to 'Screen Fit'.
Source forum kodi:
http://forum.kodi.tv/showthread.php?tid=221407
HiMedia Q5/Q10's Key Strong Points:
•Very reliable, with good firmware support (also, some of us are in direct communication with HiMedia engineers)
•Excellent PQ, thanks to included Imprex Processing Engine. Gives Q5/Q10 Oppo-like PQ, with Darbee Darblet-like video processing (at fraction of cost)
•23.976 framerate support
•Full HD audio bitstreaming support
•Very forgiving of less-than-perfectly ripped Blu-rays, or those with errors
HiMedia Q5/Q10's Key Shortcomings:
•Poor VC-1 29.970 playback (some 2D music/concert Blu-rays unplayable)
•External player solution, so not seamless within Kodi (but, its BD-lite menu is better than Kodi's)
•Lack of MKV chapter support
A l'ouverture de la boite :
- Une petite boite de qualite, elle demerite pas comparer au produit minix par exemple, je dirai que c'est comparable, a l'interieur il y a tout ce qu'il faut pour installer et mettre en route le Q5.
![Image](http://img15.hostingpics.net/pics/171109DSC01676.jpg)
![Image](http://img15.hostingpics.net/pics/617333DSC01677.jpg)
![Image](http://img15.hostingpics.net/pics/706839DSC01678.jpg)
![Image](http://img15.hostingpics.net/pics/481627DSC01679.jpg)
![Image](http://img15.hostingpics.net/pics/657097DSC01680.jpg)
![Image](http://img15.hostingpics.net/pics/556342DSC01684.jpg)
![Image](http://img15.hostingpics.net/pics/316244DSC01685.jpg)
![Image](http://img15.hostingpics.net/pics/797970DSC01686.jpg)
- La box est vraiment petite, je m'attendait a plus gros quand on voit les photos sur le net, elle est un peu plus large que la Minix, profondeur et epaisseur sont a peu pres identique, la Minix est peut etre un peu plus epaisse et profonde.
- Il y a 4 patins en caoutchouc blanc, la box ne bouge pas d'un pouce, et en plus elle est relativement pesante pour une box android, peut etre a cause du boitier en aluminium.
Mise a jour :
Premiere chose a faire, mettre a jour la box android, il faut installer toutes les mise a jours une par une, pour ma part j'en ai eu 5 a faire, partant de la 1.07 pour aller a la 3.0.2.
![Image](http://img15.hostingpics.net/pics/150503DSC01688.jpg)
- Le menu est a base de tuiles dans le meme genre que le Minix, sauf qu'ici le lien est direct, on clic sur la tuile kodi et il s'ouvre, c'est simple et efficace.
![Image](http://img15.hostingpics.net/pics/194039DSC01690.jpg)
La Telecommande
- Elle est d'excellente qualite, bien meilleur que les modele minix surtout la A2 lite, les touches répondent imediatement, la qualite de fabrication est excellente, ca craque pas, et a voir les photos sur le net je ne m'attendai pas a cette qualite, vraiment tres satisfait.
![Image](http://img15.hostingpics.net/pics/642338DSC01683.jpg)
Exemple avecle reglage par default :
![Image](http://img11.hostingpics.net/pics/882167DSC01878.jpg)
![Image](http://img11.hostingpics.net/pics/277658DSC01879.jpg)
A suivre....
