il faut ajouter surement le préampli HD le moins cher du moment qui est un clone de l'UMC200 d'emotiva le Nakamichi Dragon 7.1 qui coûte 199 livres !
http://www.nakamichi.co.uk/products/nakamichi-7-1-power-processor
Specification
Multi-signal inputs and outputs
DAB/DAB+/FM Tuner
Bluetooth Audio Streaming, with APT-X support
Support wide range ways of audio processing, including HD formats, such as Dolby TrueHD, DTS Master, Dolby Digital Plus, DTS HRA and SD formats such as PRO-LOGIC Dolby DIGITAL, DOLBY DIGITAL-EX, DTS, DTS-ES, DTS NEO:6
Support multiple HDMI video formats
Supports HDMI CEC Control and has HDMI ARC Audio Channel
Professional OSD. Any operations of the unit can be seen on the TV display.
USB port to connect to PC for software upgrading, parameter setting, preferences selection.
Customized setting and memory
Full function remote control (included)
Automatic Intelligent Room Calibration (Free Microphone Supplied)
Audio Management: Front, Centre, Surround, Rear Surround, Front Height and Subwoofer Speakers have adjustable crossover points in 20 steps from 40Hz to 250Hz
Crossover slopes can be set at 12db or 24db per Octave
11 Band Parametric Equalizer
Bi-Amping feature for front L and R channels
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: BAIOKO et 31 invités
Préamplis 2014/2015 - le match !
- vindermere
- Modérateur Installations
Bien joué d'avoir ajouté le Nakamichi Dragon
Est ce un vrai appareil symétrique ?
- patjero
- Inscription Forum: 17 Sep 2003 2:34
aucune idée, je n'arrive pas à trouver l'info.
- vindermere
sinon autre pré ampli mais cette fois ci très cher (9700 euros) l' Audiocontrol Maestro M8
4K Ultra HD pass-through and upscaling capabilities;
Balanced XLR audio OUTPUTS for premium audio performance;
Dual Balanced XLR audio INPUTS;
HDBaseT Outputs via optional AudioControl signal extender component;
Seven HDMI inputs and dual HDMI outputs – ARC (Audio Return Channel) Compatible;
Proprietary room correction with signal alignment, level and equalization – assignable on a per source basis;
Dolby Volume technology for superior balance;
Compatibility and integration with leading control systems including Savant, Crestron, Control 4 and RTI;
Custom Install control ready with Ethernet, RS232, 12 volt trigger and IR control options;
AudioControl iOS Control App available free on the iTunes Store;
Programmable Remote control provided; AudioControl’s 40 Year Focus on audiophile quality, made in the USA and a bullet-proof 5-year warranty program.
- vindermere
patjero a écrit:Bien joué d'avoir ajouté le Nakamichi Dragon![]()
Non, vu sur son topic
- kbil69
En même temps, les Marantz, Onkyo and co sont également des "faux symétriques"...
Je serais curieux de connaitre la liste des "vrais symétriques"! Il ne doit pas y en avoir des masses...
- jeff51
- Inscription Forum: 29 Mar 2007 16:50
en vieux le lexicon mc12 b
- sylvain07
- Inscription Forum: 16 Avr 2004 18:48
Merci Sylvain pour l'info!
Et en récent à moins de 10000€??
- jeff51
patjero a écrit:rien
+1
- sylvain07
C'est bien ce qu'il me semblait...
- jeff51
Emotiva XMC-1 !
Magnetar UDP800 / Lumagen Radiance Pro 4242 / JVC DLA-N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal SM6 Be & 1000 Be + 4 x Focal 300 / 2 x Subs DIY Beyma 18LX60 / Amplis HPA / Etudes, traits & calibs pros
Placement Enceintes & Écran
SYLEX - Membre HCFR Contributeur
- Inscription Forum: 11 Oct 2002 13:47
c'est vraiment du vrai symétrique xmc-1 ?
- patjero
A priori, c'est ce qu'ils disent...
"Introducing the AV preamp that redefines everything you know about home theater—on every level. With custom Dirac Live™ 7.2, Ultra HD 3GHz HDMI, and a balanced audiophile-grade signal path, this made-in-the USA masterpiece goes head-to-head with AV preamps costing 10X as much."
merci pour la précision
- patjero
