Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Moisson et 23 invités
Préamplis 2014/2015 - le match !
Message » 22 Fév 2015 20:15
il faut ajouter surement le préampli HD le moins cher du moment qui est un clone de l'UMC200 d'emotiva le Nakamichi Dragon 7.1 qui coûte 199 livres !
http://www.nakamichi.co.uk/products/nakamichi-7-1-power-processor
Specification
Multi-signal inputs and outputs
DAB/DAB+/FM Tuner
Bluetooth Audio Streaming, with APT-X support
Support wide range ways of audio processing, including HD formats, such as Dolby TrueHD, DTS Master, Dolby Digital Plus, DTS HRA and SD formats such as PRO-LOGIC Dolby DIGITAL, DOLBY DIGITAL-EX, DTS, DTS-ES, DTS NEO:6
Support multiple HDMI video formats
Supports HDMI CEC Control and has HDMI ARC Audio Channel
Professional OSD. Any operations of the unit can be seen on the TV display.
USB port to connect to PC for software upgrading, parameter setting, preferences selection.
Customized setting and memory
Full function remote control (included)
Automatic Intelligent Room Calibration (Free Microphone Supplied)
Audio Management: Front, Centre, Surround, Rear Surround, Front Height and Subwoofer Speakers have adjustable crossover points in 20 steps from 40Hz to 250Hz
Crossover slopes can be set at 12db or 24db per Octave
11 Band Parametric Equalizer
Bi-Amping feature for front L and R channels
vindermere
Modérateur Installations
Inscription Forum: 06 Déc 2006 19:26
Message » 25 Fév 2015 10:23
Bien joué d'avoir ajouté le Nakamichi Dragon :wink:
Est ce un vrai appareil symétrique ?
patjero
Inscription Forum: 17 Sep 2003 2:34
Message » 19 Mar 2015 11:15
aucune idée, je n'arrive pas à trouver l'info.
vindermere
Message » 19 Mar 2015 11:17
sinon autre pré ampli mais cette fois ci très cher (9700 euros) l' Audiocontrol Maestro M8
4K Ultra HD pass-through and upscaling capabilities;
Balanced XLR audio OUTPUTS for premium audio performance;
Dual Balanced XLR audio INPUTS;
HDBaseT Outputs via optional AudioControl signal extender component;
Seven HDMI inputs and dual HDMI outputs – ARC (Audio Return Channel) Compatible;
Proprietary room correction with signal alignment, level and equalization – assignable on a per source basis;
Dolby Volume technology for superior balance;
Compatibility and integration with leading control systems including Savant, Crestron, Control 4 and RTI;
Custom Install control ready with Ethernet, RS232, 12 volt trigger and IR control options;
AudioControl iOS Control App available free on the iTunes Store;
Programmable Remote control provided; AudioControl’s 40 Year Focus on audiophile quality, made in the USA and a bullet-proof 5-year warranty program.
vindermere
Message » 25 Mar 2015 19:41
patjero a écrit:Bien joué d'avoir ajouté le Nakamichi Dragon :wink:
Non, vu sur son topic :wink:
kbil69
Message » 25 Mar 2015 19:55
En même temps, les Marantz, Onkyo and co sont également des "faux symétriques"... :oldy:
Je serais curieux de connaitre la liste des "vrais symétriques"! Il ne doit pas y en avoir des masses...
jeff51
Message » 25 Mar 2015 21:38
en vieux le lexicon mc12 b
sylvain07
Inscription Forum: 16 Avr 2004 18:48
Message » 25 Mar 2015 23:57
Merci Sylvain pour l'info! :wink:
Et en récent à moins de 10000€??
jeff51
Message » 26 Mar 2015 0:14
rien :mdr:
patjero
Message » 26 Mar 2015 8:11
patjero a écrit:rien :mdr:
+1
sylvain07
Message » 26 Mar 2015 8:38
C'est bien ce qu'il me semblait... :mdr:
jeff51
Message » 26 Mar 2015 9:54
Emotiva XMC-1 !
Magnetar UDP800 / Lumagen Radiance Pro 4242 / JVC DLA-N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal SM6 Be & 1000 Be + 4 x Focal 300 / 2 x Subs DIY Beyma 18LX60 V1 / Amplis HPA / Etudes, traitements & calibrations pros
SYLEX
Membre HCFR Contributeur
Message » 26 Mar 2015 10:33
c'est vraiment du vrai symétrique xmc-1 ?
patjero
Message » 26 Mar 2015 10:49
A priori, c'est ce qu'ils disent...
"Introducing the AV preamp that redefines everything you know about home theater—on every level. With custom Dirac Live™ 7.2, Ultra HD 3GHz HDMI, and a balanced audiophile-grade signal path, this made-in-the USA masterpiece goes head-to-head with AV preamps costing 10X as much."
SYLEX
Message » 26 Mar 2015 20:53
merci pour la précision :wink:
patjero
