Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: 73Thierry, Gort'h et 13 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Firmware pour les processeurs video Lumagen Radiance
Message » 26 Sep 2014 7:25
Date de l'info : 26/09/2014.
Firmware Radiance mini : http://www.lumagen.com/testindex.php?mo ... ni_updates
Pas de nouvelle mise à jour
Firmware Radiance XS : http://www.lumagen.com/testindex.php?mo ... xs_updates
Firmware Radiance XD : http://www.lumagen.com/testindex.php?mo ... ce_updates
Firmware Radiance XE : http://www.lumagen.com/testindex.php?mo ... xe_updates
Firmware Radiance 20XX : http://www.lumagen.com/testindex.php?mo ... XX_updates
Production 091214- Fix for an issue in 091114 having problems with 480/576p reinterlacing giving blank screen or green/pink colors. Fix for an issue with the test pattern color when editing the color gamut via the menu. Update time ~15 minutes @57k from previous firmware
Firmware Radiance 21XX : http://www.lumagen.com/testindex.php?mo ... XX_updates
alex_t
Membre HCFR Contributeur
Inscription Forum: 29 Oct 2005 23:04
Message » 10 Oct 2014 7:22
Date de l'info : 10/10/2014.
Production 100514- Fix for not correctly handling Pal (576i) video on analog inputs and not being able to power up on an analog input. This update is only helpful for units with analog inputs (2124/2144). Update time ~3 minutes @57k from previous firmware
Production 100514- Fix for not being able to power up on an analog input. This update is only helpful for units with analog inputs (2022/2042). Update time ~3 minutes @57k from previous firmware
alex_t
Message » 05 Nov 2014 0:54
Date de l'info : 04/11/2014.
Production 103114- Fix for an issue with optional CRT 3D glasses emitter. Fix for output setup issue with being unable to select desired Style. Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources. Added 24 Hz to the direct vertical rate command ("menu 04"). Update time ~15 minutes @57k from previous firmware
Production 103114- Fix for output setup issue with being unable to select desired Style after being previously set. Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources. Added 24 Hz to the direct vertical rate command ("menu 04"). Update time ~3 minutes @57k from previous firmware
Production 103114- Fix for output setup issue with being unable to select desired Style after being previously set. Added 24 Hz to the direct vertical rate command ("menu 04"). Update time ~3 minutes @57k from previous firmware
alex_t
Message » 12 Déc 2014 19:34
Nouveau possesseur d'un Lumagen Radiance 2020, comment fait-on pour connaitre le firmware de son scaler et faire une mise à jour ?
Ca pourrait peut-être faire l'objet d'une explication en première page. :idee:
Ma salle 7.2.4 terminée : ICI
Lukyfish
Modérateur Home-Cinéma
Message » 13 Déc 2014 10:18
Bonjour à tous.
J'ai une bonne nouvelle en ce qui concerne les manuels utilisateurs Radiance. J'ai l'autorisation de Lumagen de donner à qui me la demandera la traduction française que j'ai effectuée. Cette traduction suit strictement la version anglaise. Elle a donc le même niveau de détail, ni plus, ni moins.
Une petite explication pour préciser les choses
J'insiste sur le fait que je ne travaille pas pour Lumagen. Je n'ai rien touché pour l'écriture des manuels.
Pourquoi cette traduction ? Je reçois beaucoup de sollicitations par MP pour des explications concernant le fonctionnement des Radiance. Je réponds à chaque fois mais à cause de mon travail je ne peux pas consacrer le temps que j'aimerais à ses réponses. J'ai donc décidé de faire une traduction française pour la donner aux personnes qui n'arrivent pas à s'en sortir avec le manuel anglais. Je vous passe les détails mais mon travail a attéri dans les mains de Jim Peterson et il m'a demandé si j'étais d'accord de mettre mon document dans le même format que le manuel anglais. J'ai répondu que oui. Je dois vous avouer que je suis relativement fier d'avoir pu aider Lumagen. Cette contribution est bien entendu très modeste mais elle rendra service à beaucoup d'entre vous. (les puristes de l'anglais trouveront surement des imperfections et j'en excuse par avance)
Pour l'instant, seuls les manuels 20X1, 2143 et 2144 sont disponibles en version française. J'ai demandé à Lumagen de me fournir le document word du 2020 pour que je le traduise. Je n'ai pas de réponse pour le moment.
J'ai aussi traduit le TIP expliquant comment mettre à jour le firmware.
Merci de patienter encore quelques jours car pour le moment je ne peux pas vous donner les manuels, j'attends une confirmation de Lumagen sur un dernier point technique.
Pour info: j'ai aussi garder le format original de mon travail, c'est un document avec un certain niveau d'interactivité (rien d'exceptionnel mais tout de même assez sympa). Je le partagerai avec vous en début d'année prochaine.
Alexandre
alex_t
Message » 13 Déc 2014 16:18
Lukyfish a écrit:Nouveau possesseur d'un Lumagen Radiance 2020, comment fait-on pour connaitre le firmware de son scaler et faire une mise à jour ?
Menu->Info
SW Rev: 103114 -> firmware du 31/10/2014
A mon avis, pas la peine de se prendre la tête avec la MAJ dans un premier temps, il y a d'autres choses à faire avant!
ektor
Inscription Forum: 20 Aoû 2007 20:19
Message » 13 Déc 2014 16:23
alex_t a écrit:Bonjour à tous.
Alexandre
Merci Alex
Cette contribution est loin d'être modeste!
Même si j'ai le XD3D, je veux bien le manuel traduit malgré le fait que je sache lire l'anglais.
Pourquoi? Car faire l'effort intellectuel de traduction + comprendre la logique des menus et de l'ingénieur Lumagen, pas évident.
Comme il est prouvé qu'il est + difficile de faire plusieurs choses en même temps, si on peut enlever le volet traduction, ça sera d'une grande aide!
ektor
Message » 01 Jan 2015 17:02
moi aussi j'aimerai bien avoir le mode d'emploi en francais pour mon lumagen radiance mini hd que je ne peux pas regler car je ne comprends pas grand chose a l'anglais...comment dois je proceder pour telecharger et imprimer le mode d'emploi en francais? quelqu'un peut il m'aider?par avance merci :D
madge
Inscription Forum: 14 Fév 2008 12:31
Message » 30 Jan 2015 8:31
Date de l'info : 30/01/2015.
Production 012515- Fix for an issue with factory reset after enabling 17x17x17 CMS that would give incorrect colors. Adds composite input option to 2124/2144 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2124/2144). Fix for composite input with film mode selected. Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. Update time ~15 minutes @57k from previous firmware
Production 012515- Adds composite input option to 2022/2042 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2022/2042). Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. Update time ~15 minutes @57k from previous firmware
Production 012515- Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits. Update time ~3minutes @57k from previous firmware
alex_t
Message » 08 Mar 2015 7:25
Date de l'info : 08/03/2015.
Production 012515
Production 030115- Fix for test patterns with 3D signal and 2.35 output. Fix for 2022/2042 analog component input when source switches from higher resolution to 480i and the 20XX loses the 480i picture. Update time ~3 minutes @57k from previous firmware
Production 012515
Production 012515
Production 012515
Production 012515
alex_t
Message » 20 Jan 2016 8:58
Date de l'info : 20/01/2016.
Production 011316- The newly added ZY550 rs232 command wasn't working too well and was fixed. The ZQI21 command returned incorrect vres for 4K output modes. If you aren't using these rs232 commands then you do not need to update.
Production 011216- Adds rs232 input aspect query command, "ZQI20". Adds rs232 full information query command, "ZQI21". Adds rs232 command, "ZY550" to reset automatic aspect detection which is useful if user temporarily overrides it and then wants to redetect automatically. Adds "Full" option to reporting mode changes via rs232 in menu under "Other: I/O Setup: RS-232 Setup". Fixes output aspect per input aspect problem with 2.40 input aspect using the 2.35 output aspect. Adds improvements to automatic image based input aspect such that detection is more reliable and also will unzoom to display DVD setup menus, etc when they are detected. If you need documentation on the new rs232 commands before our rs232 tech tip is updated please email us at support@lumagen.com
Production 012515
Production 012515
Production 012515
Production 012515
alex_t
Message » 14 Oct 2016 15:32
Date de l'info : 14/10/2016.
Production 100516- Small improvements from Radiance Pro auto image aspect detection were added.
Production 011316
Production 012515
Production 012515
Production 012515
Production 012515
alex_t
Retourner vers Processeurs Vidéo
